Question about Therapure Four Person Inflatable Round Hot Tub
Every time I put the bubbles on it trip?? Can anyone help?
  • James Feragola
    James Feragola May 12, 2014
    Hi Karen Dupre, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • 1,631 Answers
The air blower (bubbler) has water in it? This will cause it to trip, or it may just be shorting to ground without water in it, this too is common and will cause a trip.
Posted on Mar 07, 2015
It worked fine the last time I used it, now it will not make bubbles. What should I do?
Review- Deluxe Bubble Bliss Foot Spa by Hometics ...
? 5:14
https://www.youtube.com/watch?v=LUBHAmA0y3A
Apr 17, 2014 - Uploaded by Calla
I love this bubble spa, its great for anyone who is on their feet all day, Its ... my machine quit working for the bubbles ... My mom bought one yesterday, but it does not bubble. ... make them a little larger so you could submerge your whole foot in ... I'm curious if you've ever used essential oils during your foot ...
The Next Best Thing to a Jacuzzi - Epinions.com
www.epinions.com/.../HoMedics_Bubble_Spa...2/.../130896793220
Jan 29, 2016 | Homedics Fb-50 Bubble Bliss Deluxe Foot...
Put seal kit through steer pump
The bubbles usually mean you have air in the lines.
Jul 01, 2013 | Cars & Trucks
Low coolant level in 2003 yukon after radiator flush
When coolant gets drained and refilled air bubbles are often trapped inside the cooling system. If you imagine pouring a soft drink and you see all the little bubbles sticking to the sides of your glass, you'll get the idea. After driving those bubbles eventually "burp" their way up to the top, and consequently the coolant level drops. Top it up one more time and my guess is you'll be good to go.
Dec 23, 2011 | 2003 GMC Yukon XL
My suitcase on petz5 wont let me put a bubble blower back its annoying and i want to get rid of it.Please oh please help me!!!!
Okay, get out another bubble blowing box, and then put the first bubble blower in the box with the second one. You can put two in one box and put them away together. Hope this helped!
Sep 28, 2011 | Ubi Soft Catz 5 (Windows) (680901) for PC
Mspa hot tub, fault code fef...........i have changed both pump and control panel on the first model i had to no avail! company then sent me a whole new tub, which i now some 6 months later doing the same!...
Try cleaning debris from water outlet screen(upper ouput port) unscrew screened grey cap, code is for rise in water pressure in unit, or its a faulty pressure switch, i figured this out on my own , company offered no support whatsoever, even on warranty
May 08, 2011 | Home
My breaker is conected to a hot tub. tub was working fine in auto mode. Turned on jets and breaker tripped. will not reset can you help me
I am assuming this is a GFCI circuit breaker? If it is it will have a "test" button on the breaker. When you say "jets" i'm assuming you mean when you turn on the blower to make the air bubbles? It could be you have a problem with the blower motor. When you start the blower, it trips the breaker. Be sure the blower is in off position when you reset the breaker. The most common fault though on a spa/hot tub is with the heater. If the element goes bad, and current flows to ground, it will trip the GFCI breaker. Again try and turn all functions off. Reset breaker, and then turn on one at a time till the breaker trips. First the pump, then the heat, then the blower.
Oct 06, 2010 | Square D Trilliant 40 Amp Circuit Breaker...
Screen will not tun on
Put the set on for several hours and let the electronics warm up. It is possible that some capacitors have dryed and putting on the set for sometime can build up the charge and help to retain the circuit to perform in order. This is all what could be done and hope you have not started on the trip. It is important that any electronics units must be in action at least some time as some low quality components can malfunction with aging in course of time. If this wont solve then you will need help to open and probe for fault inthe power/ display unit. Good luck Good day
Jul 30, 2010 | Eddie Bauer B00008PC3T Portable DVD Player...
Lost instructions for bubble console pre school game
hi tim im having some problems with bubble at the moment its unreal i have some phillips codes dont know if they will work however ill give them to you anyway
0503 0539 0646 0671 0675 0854 0885 1158 1260 1267 1812 1813 1818 1911 1914 if you stick the set up dvd in n watch the first time set up bit it explains everythin you need to know i there hope this helps you out!
Dec 20, 2008 | Toys
What products to us in my jet bath
Bubble bath is definitely out of the question. Provide any of the products that you are using do not have a detergent base or bubbles so to speak, you can use them. Depending on how many times a week you use it you might want to get a cleaner that they use on hot tubs from you local pool distributer. I hope this helps you.
Nov 26, 2008 | Whirlpool Pearl Navarre 7242 True Bathtub...
Therapure Four Person Inflatable Round Hot Tub Logo
159 people viewed this question
Top Therapure Pool & Spa Experts
Raymond Richards
Raymond Richards
David Harrelson
David Harrelson
Tom Chichester
Are you a Therapure Pool and Spa Expert? Answer questions, earn points and help others
