Samsung E550 sound bar says check sub woofer. Samsung says faulty power cord due to wear and tear. Don't seem logical since power cord has never moved in 14 months. ????
    Genius:
  • Audio Player... Master
  • 1,054 Answers
Is the light blinking on the subwoofer?
Posted on May 12, 2014
Raveler
  • 36 Answers
SOURCE: sw 300 powered sub woofer
It sounds like your subwoofer acts as a receiver in its own right. Many low-budget home theater systems act this way, and it may in fact have a Dolby Pro Logic II encoder in it. Your best bet is to hook up either the speakers it came with, or purchase speakers from your local audio visual store. Check its power rating per speaker (in watts) in your manual, and purchase speakers that are rated for it.
The "red and white" input you mention are RCA connectors, and should allow you to connect a source to your system. If you have any more specific questions, please post them here.
Posted on Jan 01, 2008
  • 54 Answers
SOURCE: Sub woofer flashing red and green
sir,,i think there is something wrong with the connections or the cross over,,,kindly check it out or mjaybe the cone of ur speaker is damage,,,hope too help you thnkss??
Posted on Jan 29, 2008
simplemitch
  • 752 Answers
SOURCE: bose acousticmass 15 sub-woofer making a noise
The sub contains the amp for the other speakers. But it sounds like the amp has a seriously damaged section and will probably have to be serviced by Bose.
Posted on Aug 05, 2008
  • 124 Answers
SOURCE: No sound for Velodyne ct-100 sub woofer
Sounds like a dead amp. You could check the xformer output and the amp IC's with a VOM.
These amps do not cost a lot, about $40.00. and are easy to replace.
Contact Velodyne
Posted on Mar 26, 2009
  • 396 Answers
SOURCE: HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Posted on Nov 06, 2009
Samsung sub woofer # ps-wx810 will not connect to sound bar # ht-x810
Smash away. I don't think you can connect a wireless piece to a sound bar. This may be out of my wheelhouse, but I don't think so.
Feb 22, 2016 | Samsung HW-E450C 40" AirTrack Sound Bar...
How can I resolve this?
Hi Gary
This can happen infrequently due to either the iPad needing a restart (iPhone 5's and 5s's) have similar issues.
There are two things to try;
1) Turn your samsung sound bar off, and pull out the power cord out of the wall, now this may sound unnecessary but the logic behind that is to have it clear any potential "error code" or crashed script which is powering the bluetooth transmitter in the sound bar. You do this for ca. 60 seconds, 30 will do too but we just want to be sure. Once that is done plug the bar in again and power it on and see if it works now.
2) Restart your iPad, this has the same logic behind as step one, but in this situation i'd like you to turn both off starting with your iPad.
It is not uncommon especially depending on the iOS your running on your iPad for the bluetooth transmitter not to see the bluetooth sources around you.
To turn your ipad off push the sleep/power button at the top right of your ipad for 10-15 seconds. Until you see the swipe to turn off. Let it shut down completely after you swiped it to turn off. (this can take a minute) Once you see the spinning wheel on your ipad disappear start with unplugging your Samsung Sound Bar. As in step one follow the same procedure until its back on. Now turn your iPad back on with the sleep / power button and wait till its fully loaded.
Now in the settings>bluetooth you should in theory see your sound bar again. If you still encounter problems don't hesitate to let me know.
Have a great weekend
Philipp
May 05, 2014 | Samsung HW-E550 Crystal Surround Air Track...
MX6050D Subwoofer Issues
Hello, welcome to Fixya!
Fault is either from the main system or the sub-woofer itself.
You need to test both unit in order to detect which of the two is giving the fault, so that you can concentrate on the faulty unit.
Test the woofer with a AA battery or any other battery. Put your ears close to the woofer and observe if you will hear any sound. If the woofer makes sound, then it means the woofer is working, but if it doesn't make sound, then it means the woofer is defective. Or you can disconnect one of the working speakers and connect the woofer to that part. If there is no sound, then obviously, the woofer is defective.
If the woofer seem to be working, then the unit needs to be tested also.
Connect one of the working speakers to the sub-woofer's section of the main unit. If the speaker doesn't bring out sound, check the system's menu settings, check the volume and make sure the sub-woofer volume is raised to the highest level and not on mute. ( Note that most Theater systems has separate volumes for each speakers). If the volume is raised to the highest level and there is still not sound from the woofer part, then it means the woofer channel has burnt. It could be a fuse or a defective channel. At this point, I think you need help from a repairman.
I hope the above is clear.
Regards.
Nov 17, 2011 | Audio Players & Recorders
Two speakers hum noise
Very doubtful that hum issue is ground potential difference from multiple power outlets as power cord is not grounding type (it is transformer isolated). I do agree that it is good practice to connect all audio equipment to common power strip though, especially with pro sound. Check the audio cords connecting your speakers to the coumputer sound card: 1) Make sure they are connected to the correct jacks and plugged in all the way, 2) wipe the connectors off with a clean paper towel wetted with a smidge of WD-40, 3) replace cords if all else fails. I have also seen solder joints fail on the power supply capacitors (due to vibration) causing hum -- but leave this repair to an electronics technician due to dangerous voltages.
Sep 25, 2010 | Altec Lansing AVS 500 Computer Speakers
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Sound is pulsing.
You probably have the power bar thing too close to the sub woofer, this will cause a pulsing sound! :D
Apr 04, 2009 | Creative Labs I-Trigue 2.1 3300 Computer...
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
123 people viewed this question
 Grubhead
Grubhead
