Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Make prints darker mf6530 - Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Printer is printing to light for my needs...has a new toner
Verify the toner cartridge.Open the glass platen cover and make a copy,not used an original,if the cpy is a full black papier thr toner density is OK,Clean the polygon unit glass.Enter in program and perform a test page.
Apr 04, 2013 | Canon MF6530 Black and White Copier
I use my MF6530 Laser Copier Printer to print checks and it will frequently print on the reverse side of the paper.
hai I give print to printer 2 side in single page, first two page print well but another two page print in opposite direction in the same paper (example1,2 page one side and 3 ,4 pages in other side but reverse direction. it mean you turn the paper to next side, you see opposite direction ) please help me to avoid this problem.
Jul 22, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Canon mf6530 shows "download connected."
you will need a service suport tool to rewrite the software on this machine.
It is necesary to contact a CANON tech to perform this operation, if you try to do it yourself you might damage it more.
Jun 06, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Canon imageclass mf 6530 blank pages change toners still blank what is the cause of this problem
you have problem with laser shuter on laser unit. It needs to be fixed or replaced.
This is canons factory fault, and if the machine is under waranty call service.
Hope that helped!
Jul 19, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Canon imageclass MF6530
try ( add.function & #) service mode and then find clear all
Feb 26, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Printing in color
Because is not a COLOR printer, it's monochrome!!!
Jul 16, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Canon Imageclass MF6530
the imageclass MF6530 cannot print in color it can only print in black and white. the only thing that this machine can do with color is to scan color documents to your computer otherwise it is a black and white copier and printer with color scan.
Jan 02, 2008 | Office Equipment & Supplies
Canon imageClass MF6530
This is a "monochome printer" ie B/W, double sided is called duplex select this option on printer driver on pc
Dec 01, 2007 | Canon imageCLASS MF6530 Monochrome Laser...
Printing envelopes
You will probably have to change your paper settings on the printer itself to proceed without an error. In the additional settings>Paper Size> change it from Ltr to Envelope.
Sep 17, 2007 | Canon imageCLASS MF6530 Monochrome Laser...
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
20 people viewed this question
old marine
old marine
