Question about Brother LS-2125 Mechanical Sewing Machine
My machine is not stitching im not sure its the top or bottom
Model number ls-2125
    Novelist:
  • 268 Answers
Most likely explanation is you need a new needle, right way around (flat of the needle to the back of the machine), fully up in the needle clamp. Try a size 12/80 first... it's the needle the machine was timed for.
If you continue to have problems, a better description (or photos) would help.
Maybe some more helps for you: http://www.picturetrail.com/sfx/album/view/22521551 http://www.picturetrail.com/sfx/album/view/17206792
Posted on May 24, 2014
jyackle5
  • 8197 Answers
SOURCE: need manual: Machine instruction-guidebook: Brother LS-2125
Here one is the user manual the other is
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125_EN_272.PDF
setup guide
http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_LS_1217_1520_1717_2125_VX_1435_EN_364.PDF
Good luck please rate
Posted on Dec 17, 2008
Mimito7
  • 128 Answers
SOURCE: bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
Posted on May 29, 2009
  • 7 Answers
SOURCE: bobbin case is disassembled. how do I put it back together?
It should be in your manual.... but if you don't have one, I'm gonna try this out. I don't know the official names, so bear with me.
There should be two plastic arm-lookin things that are turnable. Make sure these are turned outwards.
You should have three silver pieces. The one you need first is a half-moon looking thing with a knob comin out of the middle. (it also has some holes in it)
If you turn the big knob on the right hand side, there should be a moving piece on the inside of the bobbin case.
The half moon needs to fit in with that piece. Don't force anything cause we don't want the machine to break. >< The knob thing needs to be facing the outside, otherwise it's not gonna go in at all.
Once you get the half-moon thing in there, you have two more left. There's a big circle. WOO! CIRCLES! ANYWHO, The big silvery circle.. it has a knotch in it, and a little pokey-outie thing comin' out of it.
It needs to be positioned so that the knotch (on the inside of the circle) is up and the pokey-outie piece (on the outer side of the circle) is on the bottom. On your machine, there should be a place where the pokey-outie piece would fit perfectly into a little hole-type-thing. Put it in. :O
Now it's time to move those little black plastic arms towards the center. On your circle, there should be little grooves that they fit right on top of. ^_^
The only silver piece left should be the actual bobbin case deal. This should be a smaller circle with a movable arm and a silver thing pokin' out of it. (I told you, I'm bad at names!) Before you put this guy in, we need to have your plastic bobbin threaded. (I'm assuming this has already been done, correct me if I'm wrong.... they also have pre-threaded bobbins for sale, but hey, whatever works.)
Your bobbin needs to fit inside this last piece. (my first bobbin didn't, and I freaked out and ran to my dad... LOL) You need to make sure there is a trail of thread coming out of your bobbin that's about two to three inches long. Place your bobbin in the silver guy and there /should/ be a little niche where you can play with the thread and pull it through the silver guy's parts. (Your thread may break, don't worry, just try again)
When you move the thread around, it should come out where the little arm that sticks out is. Keep the 2-3 inch trail goin' on, you'll need it. Remember that first half-moon silver guy? Well, we're gonna stick our little assembly onto his pokey-outie piece.
The silver arm-thing on our assembly needs to go into the knotch that's in our circle, and push in so it clicks. (Sometimes mine clicks twice...) Make sure you have that trail of thread, and go ahead and flip the white plastic up, because you're DONE assembling it.
I'm going to assume you have your top thread in already (again, correct me if I'm wrong..) make sure that your top thread is through the hole in the needle, otherwise we're thoroughly screwed. Pull that thread until you have another 2-3 inch tail, and twist the big white knob on the right side of your machine (same one as before...) TOWARDS you. KEEP HOLDING your top thread, otherwise it'll disappear into the abyss that is your bobbin assembly.
When you turn the knob towards you, your needle should dip down into the abyss and come back up- with your bottom thread! HUZZAH! it SHOULD be a loop around your top thread. (I'd use contrasting colors for practice.. so you know what it'll look like)
The manual says to "grab the bottom thread" but seriously, I can't get me fingers down in there, so I just slide some scissors under the foot and between the two sides of the loop, and just slide 'em left. usually works just fine. Unless my tail for the bottom thread is too short, cause then it'll be hard to grab. You should be good to go!
I know this is pic heavy and kind of long, but I like to provide as much info as possible! Let me know if it helped!!
Posted on Jul 31, 2009
WonderTech
  • 268 Answers
SOURCE: I have a Brother LS-2125 and when I try to sew it
Here are some solutions to try.
* Re-thread your machine
It may be threaded incorrectly.
* Raise your feed dogs If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Posted on Dec 30, 2009
  • 255 Answers
SOURCE: The top stitch on my machine doesn't seem like it
Hi. I think I know what you mean--the top thread looks like it's just laying across the fabric, right? This is because either the top tension is too tight or the bobbin tension is too loose. (Either condition will look the same.) Try it with a different color thread in the bobbin, you can easily see the bobbin thread cross the top thread on top of your fabric. Here's what to do:
  1. since you should hardly ever need to adjust the bobbin thread, we'll start with the top thread.
  2. Make sure you thread the machine with the pressure foot UP (opens the tension disks) but adjust the tension with the pressure foot DOWN (closes them so they will adjust). Use a size 12 or 14 needle and good-quality thread (it does make a huge difference!)
  3. With different color thread on top and in the bobbin, stitch an inch or so and check the stitch.
  4. Slightly loosen the top tension (move the dial so the numbers go lower). Don't move it a lot, just a little bit.
  5. Stitch again and check. Repeat this process, stitching, checking, and gradually adjusting the tension dial until you don't see any of the bobbin thread on the top (or very, very little) and don't see any of the top thread on the underside (or very, very little).
  6. IF this doesn't get the balance adjusted, then you'll have to play with the bobbin tension. (But generally, once this is set, you shouldn't have to mess with it again.)
  7. There is a tiny screw on the bobbin carrier that tightens or loosens a very small metal strip (where the thread exits the carrier). To tighten the bobbin tension, screw this just a tiny bit to the right. (Turn it to the right to loosen the screw, to the left to tighten it.) Again, just make a small adjustment each time and recheck your stitches.
Few things about sewing are more frustrating than stitches that aren't balanced!
Sure hope this helps!
Robbie
Posted on Apr 22, 2010
Pattern selection dial
take the machine back & get another one
Aug 30, 2012 | Brother LS-2125 Mechanical Sewing Machine
My Brother LS-2125 does not stitch forward - only in reverse.
What stitch selection have you made, anything to do with the buttonhole? If, so make sure that you let it go through the cycle then, pick a straight stitch pattern with a longer stitch length. You can also go online to brother-usa.com and see if there are any other suggestions
Sep 16, 2010 | Brother LS-2125 Mechanical Sewing Machine
Top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
Jun 07, 2010 | Brother LS-2125 Mechanical Sewing Machine
How do I adjust the bobbin settings on my Brother XL-3022
Well is your machine skipping stitches? "Not looping" does that mean not creating a stitch? To adjust your bottom stitch you usually adjust the top tension regulator. I can try to help you more in detail check out my forums http://www.sewingmachineryrepair.com/forums/index.php
Feb 28, 2010 | Brother LS-2125 Mechanical Sewing Machine
I have a Brother LS-2125 and when I try to sew it works for a minute then the bottom thread bunches up and goes no wear, i thought it was my bobbin but im not sure, im not real familiar with sewing...
I hope this helps.
Dec 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
How to adjust tension on bottom stitch?
There are tow places where the thread tension is adjusted.
One is bobbin. This is not routinely adjusted. Just once and it is good for long time. This is done by turning the only screw on bobbin by about 1/4 turn or so at a time. Try several settings until you find he best.
the other place is the conventionally on body of the machine.
Tension of bottom stitch or top stitch are very confusing words. meaning difft things to difft pple.
All i can say is this. If u see bottom stitch run straight through loops of top thread. then either top tension is too loose or bottom too tight. and vise versa.
With top tension set to middle position adjust the bobbin to get correct stitch. Then later on all u need is to adjust only the top setting according to stitch and cloth
Oct 16, 2009 | Brother LS-2125 Mechanical Sewing Machine
The top stiches are overlaying and the bottom stitch is loose
Remove the thread from the machine.
Raise the presser foot.
Turn the handwheel until the take-up lever is at it's highest position.
Set the upper tension to 5.
Re-thread the machine.
Oct 01, 2009 | Brother LS-2125 Mechanical Sewing Machine
Loose stitch with loops on top of material i got the right needle and bobbins what do i need to do i have ls 2125 brother
General rule of thumb is this.. If it loops on the bottom the problem is on the top..
If it loops on the top, the problem is on the bottom.
Sounds like #1 your bobbin is wound very loosely , #2 your bobbin thread has to go thru its tensioner.
Apr 19, 2009 | Brother LS-2125 Mechanical Sewing Machine
I'm having troubles with my brother sewing machine
Your tension is loose on top. Adjust your tension dial up a little at a time until you have a desirable stitch. Before adjusting the tension, you may want to look into the tension and see if there are any threads caught between the disc. If so remove them. Another common problem is that your machine is not threaded properly, make sure the pressure foot is in the up position when threading and if needed consult your manual for the proper threading diagram.
Jan 16, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
50 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
