Question about Integra Thx Dtr 40.1 Receiver
How do I get into the network and firmware menu?
The manual states that after 30 seconds the firmware menu will allow entry but this never happens. Also I cannot get into the network menu. I know my router is handing it an address but navigating to it fails. I have an issue where it doesn't output sound and I was told it could be a software issue so I wanted to update the firmware.
    Habit-Forming:
  • 48 Answers
Try the following
Via Net
Is it reasonable to assume your router requires password / ssid to secure internet access ?
Due to age of this device,
(1) Lower / disable current router security settings
OR
(2) connect device directly to modem. ( softest, easiest way )
This may require you to disconnect modem from router, reset your modem then connect cable direct between modem and DTR 40.1 device.
When completed, the Modem ( and Router ) may need be reset, prior to re-connecting network
Firmware update information link ( from manual )
http://filedepot.onkyousa.com/Files/own_manuals/Firmware_Update_for_the_DTR50_1_40_1_DHC40_1_100110.pdf
Step 3:
Go to "7-6. Firmware Update" menu.
Note that the Firmware Update option will be grayed out
for 30 seconds after AV receiver/controller is turned on.
Please wait
( system attempts internet link for approximately 30 seconds ? )
Not outputting Sound ( trouble shooting ) link
http://www.integrahometheater.com/faqs_detail.cfm?detail=1&id=347
Hope this was helpful
Posted on May 12, 2014
  • Anthony Powell
    Anthony Powell May 13, 2014
    unfortunately I have all of this information already and have tried it with no luck. Any device connected via Ethernet can get online on my network with no blocks setup so I am positive that is not the issue.
How do i connect and update firmware
Normally on any DVD or Blueray player that has a network (RJ45) connector on it you simply need to plug in a network cable that is attached to your router. Then in the menu's there should be a system menu or update menu that you select and then the option for firmware or system update should be visible. You do not state model so I cannot be more specific.
Jul 05, 2015 | Televison & Video
How do I reset the anti theft system on my Suzuki XL7? A new battery was installed and messed my system up
which one.
radio antitheft
car doors. (alarms) Content Theft Deterrent (CTD)
or immobilizer.
say what messed up means.?
the CDC system must be armed with the fob.
is that failing? I can not arm the system or it will not disarm. on my command?
my guess is arming. fails
  1. Turn OFF the ignition.
  2. Exit the vehicle.
  3. Important: The system is not armed if the doors are locked manually. The keyless entry transmitter or the door lock switch must be used to arm the CTD system.
  4. With a vehicle door open, lock the doors by pressing the LOCK button on the keyless entry transmitter or by pressing the LOCK button on the door lock switch. The system will begin the arm sequence when all doors are closed. The CTD system transition to the arm delay state when the final door is closed. The security indicator will illuminate steady when in the arm delay state.
    If the keyless entry transmitter LOCK button is pressed after the vehicle doors have been closed, the system will transition directly to the arm delay state with the indicator on steady.
  5. The system will arm approximately 30 seconds from the time that the system has entered the arm delay state. When the security indicator transitions to flashing slowly, the system is armed.
    Alternately, if the LOCK button on the keyless entry transmitter is pressed a second time, the system will arm immediately, bypassing the 30 second delay.
if this fails try the Second fob.
if the 2nd fob fails, then pull the battery neg lug, for 5 minutes
and put it back.
the full system rules are in the book called, FSM
seen here, read it for who to diagnosis this problem if it continues
just 4 bucks to read all facts
https://suzukipitstopplus.com/Products/10182-2007-xl7-service-manual.aspx
the book also tells you all things messed up with battery pulls.
good luck.
Oct 24, 2014 | 2007 Suzuki XL7 AWD
On the screen it says The childlock is on. I have the menu on ther tv for 15 seconds and it still says the childlock is on and nothing else happens. What do I do?
The owner manual will tell how to set it but not how to get around it---on many brands in that manual it will tell you for example 9999 when entered will allow entry so you can do things like change the code--if all else fails read that manual or call the customer service number for that brand.
Apr 28, 2012 | Televison & Video
How to activate GPRS of motorola v3
Hi gonzaga,
try this: Motorola V3 GPRS Settings 1) Main Menu > Web Access > Select Web Sessions > Go to [New Entry] & press select> Name: EWZ > Homepage: http://econet.mobi > GPRS APN: econet.net > Select OK > Press Done > Go to EWZ > Press Menu > Select set default 2) Main Menu > Web Access > Select Browser > Enter URL: http://econet.mobi
Apr 17, 2011 | Motorola Mobility RAZR V3
My 180SL 4GB Eclipse is frozen on the opening screen. How do I reset?
Same happened to me. I called the support number in the manual 580-272-0035, and they gave me the reason and the fix. The reason is improperly disconnecting the device from a USB port. This can cause the firmware to be corrupted. The solution is to allow the battery to completely drain, then before connecting to any power source, press the play button for 30 seconds. This resets the firmware. How to properly disconnect from a USB port is on page 17 of the manual and applies to any device.
Nov 07, 2010 | Mach Speed Eclipse 180SL 4GB MP4 ...
Car won't start.Theft light blinks,clicking sound under hood and thumping like horn wants to go off.Seems like it's stuck in anti theft mode
anti theft light should blink every few seconds.
try disconnecting the battery for 15 minutes.
Anti-Theft-Perimeter The perimeter anti-theft system consists of the following components:
  • anti-theft indicator (THEFT)
  • remote anti-theft personality (RAP) module
  • hood switch
  • keyless entry remote transmitter
  • deck lid ajar switch
NOTE: The remote entry features will not function when the ignition switch is in the RUN or ACC position.
Up to four keyless entry remote transmitters (15K601) can be programmed at one time.
The keyless entry remote transmitters :
  • Are programmable.
  • Must be set at the same time.
  • House four buttons.
  • House three buttons (Mexico Anti-Theft System only).
Programming
Refer to Section 501-14B.
Inputs and Outputs
The remote anti-theft personality (RAP) module receives input from the following components for anti-theft operation:
  • Hood switch.
  • Deck lid ajar switch.
  • Keyless entry remote transmitter.
  • Power door lock switches (LH and RH).
  • Door courtesy input.
The RAP module distributes output to the following for the anti-theft system:
  • Power door unlock relay.
  • Power door lock relay.
  • Liftgate unlock relay (Wagon)
  • Park lamps relay.
  • HORN relay.
  • Dome lamp.
  • THEFT indicator.
  • Deck lid release.
Arming
The anti-theft system can be armed if:
  • The ignition switch is in the OFF position.
  • The panic alarm is off.
  • All doors are closed.
NOTE: If a door is open, the anti-theft system is prearmed and waiting for all the doors to be closed. The THEFT indicator will remain illuminated for up to 30 minutes waiting for all the doors to be closed. If a door remains open after 30 minutes, the THEFT indicator will turn off and the system will return to a disarmed state. After all doors are closed and the 30 second prearm (continuous THEFT indicator illumination) is complete, the system is armed.
NOTE: If the theft LED does not flash after 30 seconds, check the LED FLASH PID to see if the feature is enabled.
The anti-theft system will be armed when the lock button on the keyless entry remote transmitter is pressed, all doors are closed and 30 seconds have elapsed.
When the system is armed, the THEFT indicator will flash quickly until the system is triggered or disarmed.
Disarming
NOTE: Using a key in a door lock cylinder to unlock is not a valid method of disarming the anti-theft system.
Untriggered System
NOTE: If the driver arms the system and remains in the vehicle, an untriggered system can be disarmed by turning the ignition switch to the ON position.
An untriggered alarm system can be disarmed by pressing the unlock button on the keyless entry remote transmitter.
Triggered System
NOTE: If the hood or trunk are open when the system is armed, it must be closed and opened again before it can trigger an alarm.
An armed anti-theft system can be triggered by the following conditions:
The deck lid door, liftgate, hood or any door is opened using a key, inside door handle, hood release, etc.
  • The keyless entry remote transmitter can activate a panic alarm which is similar to the anti-theft alarm, but does not cause the THEFT indicator to flash.
A triggered alarm system can be disarmed by:
  • Pressing the unlock or panic button on the keyless entry remote transmitter.
  • Turning the ignition switch to the ON position.
Alarm State When Battery Power Is Cycled
When the RAP module is supplied power the first time at the vehicle assembly plant, the system will be in the disarmed state. The RAP module will remember whether it is armed, disarmed or triggered in its non-volatile memory. When the battery positive cable is removed and then reconnected, the system will return to the state it was in just before the battery was disconnected. If the system is in any prearm state, then the system will return to a disarmed state when the battery is disconnected and then reconnected.
Nov 06, 2010 | 1999 Mercury Tracer
Getting error code 8001000a
__you can try this:______
I struggled setting up the wireless internet connection on my PS3. It seemed that no matter what I did, I kept getting the error message 8001000B. After reading some help materials on this website, I determined that I needed to add to my router list of allowable MAC addresses the PS3 MAC address. Once I did this, the setup was as easy as shown on the manual.
Steps:
1. Locate the PS3 MAC address number: Settings - System Settings - System Information
2. Open the software controlling the rounter. This is usually done my typing the router's IP address on your browser. ie http://192.168.0.1
3. Locate a tab for FILTERS
4. Slelect MAC filters.
5. Enter the PS3 MAC address from previous step as an allowable MAC address.
6. Save entry. At this point rounter will reset itself.
7. Go back and set up the wireless connection on PS3. Select all settings automatic or EASY as the case maybe.
__or this:___
After looking over the internet for answers I found a fix for the 8001000A and when the Playstation 3 (with firmware version 2.76) is hooked to a wireless router (in my case a Netgear WNR834B v2). Below are the steps I took.
  1. Reset your router to factory defaults.
  2. Go to Select Network Settings under Settings in the home menu.
  3. Select Easy then Wireless.
  4. Then select Enter Manually. Then enter in your SSID of your router. Then rest of the setting should be set to Automatic.
  5. However DO NOT TEST CONNECTION. Just save and turn off the playstation3.
  6. Then turn off Playstation 3 from the back of the drive.
  7. Unplug the power cord and wait 30 seconds.
  8. Plug the power cord in and turn on the Playstation 3 switch.
  9. Wait 5 seconds and turn on the Playstation 3 and it will work. You can even test your connection and it will work.
However if you want your security settings on the router then once the router settings are back then repeat steps 2 through 9. Hope this works for all. I do not think replacing the unit is the answer. Any question just let me know.
Apr 10, 2010 | Sony Playstation 3 (PS3) Console
How do i enter gps coordinates?
First I suggest that you download the latest manual for your unit. Magellan has the manuals
Now if you have the latest firmware loaded then one way is to press MENU .. go to create and pick Waypoint or Geocache and the new menu will allow you to pick coordinates as the method of entry.
JG
Dec 21, 2009 | Magellan Triton 400 Handheld GPS Receiver
Cannot connect to wifi from bt home hub any suggestions. laptop higrade 8615gtx
Could be a variety of reasons.
Assuming you have not had it working before
Assuming the wifi is broadcasting it SSID
Assuming you have laptop connected by ethernet cable to hub:
Assuming you have XP:
Go to start/control panel/network connections/right click the wireless lan icon and select properties/select wireless connections and delete ALL previous entries.
With Vista go:start globe then
Control Panel\Network and Sharing\Manage Wireless Networks and delete all entries
Now:
press windows key and R
type cmd and enter
type ipconfig and enter
note lower set of figures ie 192.168.0.1
open browser and type in those figures and enter
should now open router firmware
When asked for log in use defaults of admin - admin or admin - password
navigate to wireless security and set encryption to WEP 64bit and create a simple encryption code - save settings
Change broadcast channel to 8
make sure wifi is set to open and not shared
Save all settings, allow hub to reboot and now see what happens
Dec 10, 2008 | Computers & Internet
Integra Thx Dtr 40.1 Receiver Logo
263 people viewed this question
Top Integra Audio Players & Recorders Experts
Larry Stiles
Larry Stiles
Michael Galve
Michael Galve
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
