Question about Refrigerators
Do you think it could be my thermo stat making it trip on and off I want to rule out the relay plug and thermostat before I call a tech out and have to pay more money or compressor thx
  • 2,509 Answers
The thermostat is a simple switch, it unlikely to be the stat but it,a not impossible, if it were arcing it could cause a trip. My guess is it's more likely to be the starter on the compressor or the compressor itself. If you know what you are doing and are qualified you could check the stat for leakage. (You could also eliminate it by bridging it out but I don't like the idea if it's tripping). Have you tried disconnecting the compressor to see if it still trips? HIGH VOLTAGES BEWARE
Posted on May 12, 2014
  • ramirezff May 12, 2014
    I changed the start realy that's on the commpressor but I can hear it click every 5 mins and I seen it on the compressor but my freezer is cold and fresh food cold I have ice it's working just keeps clicking
3 Suggested Answers
SOURCE: beverage air dd78 comp.wont start..tripping GFI
The "compressor side" probably consists of the compressor and condenser fan. One, or both of those could be grounded out. Try testing continuity to ground with an electric meter on both parts, if your handy with a meter. Remove relay and overload from compressor and check all three compressor pins to ground on unit. Check from each pin to the copper tubing. You should not read any continuity. If you do the compressor is grounded. :(
Posted on Sep 23, 2009
pappapumpdaf
  • 635 Answers
SOURCE: My Kitchenaid Fridge completely stopped working.
It's the defrost timer. Nothing else can shut off the cooling fan in the rear, the circulating fan in the freezer and the compressor at the same time. Try looking near your temperature control for a small hole that you can fit your small finger into. Grab a screwdriver and try turning the 2 tooth bezel located there. It won't look like a knob or adjuster, but that IS your defrost timer. Rotating it will restart your fridge, but the timer motor is bad so it will have to be replaced.This is just a quick way to confirm the diagnosis.
Posted on Mar 13, 2010
We have Turbochef NGC N6. The units high limit thermostat had tripped. Re-set thermostat and found cooling fan not working. also found thermal cut out ( top left rear looking from above ) had also tri
ur high limit trip because ur heater overshoots the program setting for the temp replace ur k4/k5 solid state relay for it controls ur temp for the heater.
Sep 21, 2014 | TurboChef TORNADO Electric Oven
Yes I turned all switches off but the motor is still running, what should i do i cant afford a technician today
the thermostat operates a relay (usually in the outside unit) .. sounds like your relay has stuck contacts. you can trip the air conditioning circuit breakers to shut it down for now .. you can try tapping the relay with a screwdriver handle to see if you can break loose the contacts .. or better, you can replace the relay .. its also possible that the thermostat has a shorted contact .. disconnect (or unplug) the thermostat and see if the motor stops .. if it doesn't then suspect the outside relay .. if it does then replace the thermostat .. make sure the wiring to the stat is ok ..
Sep 26, 2010 | Heating & Cooling
Ruud uhqa sill runs when i turn off t stat contactor test good and is not stuckhit breaker and back on and fan stops running goes on when t stat is turned on stays on till i trip breaker again i think it...
Your sentence is hard to understand because there is no punctuation. But, I think you are saying that the Outside unit is still running when the inside unit is off and the Thermostat indicates it should be off. If so, you have a stuck relay outside in the compressor/condenser unit. This is common. The contacts get hot and fuse themselves together. You will have to remove the cover on the unit outside to expose the relay. MAKE SURE THE BREAKER IS OFF. If you house is to code there will be a disconnect box on the wall just above the AC unit outside. PULL THE DISCONNECT> then use a flat head screw driver and slight pry the contacts apart. If they are fused very tight you may need to replace the relay. If they break free put every thing back together and you're done. If you this happens again soon you will need to replace relay.
Jun 15, 2010 | Ruud UAKA037 Air Conditioner
Which way is the thermostat in a 94 t bidr v6
Usually the t/stat has one end with a point on it. This goes up. If that doesn't work, try no t/stat. That's one way to rule out the t/stat
May 10, 2010 | 1994 Ford Thunderbird
I want to wire digital wall mount thermostat to my window AC unit
I think you are wright and also may lead to short cycle and burn the start relay on compressor(it may be too hot to be without air just now)try bigger relay when it is a bit cooler and 24,000btu must220-240 volts be very careful
Aug 20, 2009 | Heating & Cooling
Cooling fans on radiator will not run. Voltage in plug at block thermostat is 5.4.this therm provides an earth switch. Bypassed the thermo to earth and fan relay engages momentarily only. Relay is ok....
The fan control thermo switch should be either "off" or "on".
Voltage should measure either +12 or 0V, depending on coolant temperature.
Replacing it should fix your problem.
Jun 20, 2009 | 2000 Daewoo Nubira
Rheem 92 gal. no hot water. breaker not tripping. lower thormostat reading no ohms. the upper thermostat is reading about 6 ohms. however when i turn power on the upper thermostat reads no voltage? Do i...
Have you checked to make sure that the elements are good by checking the ohms. Be sure that the power is off and the wires are disconnected from elements and then also be sure to check the ohms across the tank to make sure there is not a dead short in the element reading through the tank. If both elements are good then I suggest replacing both thermos then they will both be new and should work for you . Thermos can be problematic when trying to test them sometimes they won't always give you correct readings. Make sure you have the breaker off whenever you mess with a waterheater, and make sure you install the thermos correctly with the right wires going where they should.
Apr 19, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Radiators cold when thermo says otherwise !
First, check to see if the battery in the stat is good. If you can move the manual temp up and down...causing the relay to click on and off, the unit ought to work. If not the battery is bad or the stat is. IF THE UNIT IS ON 110V, you can't do the following:
If this is a two wire connection, simply short them out. If the heat comes on, the stat is bad. If not, the relay package is likely defective. You may want to get help from someone who knows electrical items.
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Thermostat
your thermo stat is on your intake you will have to remove the radiator hose to get to it
Sep 10, 2008 | 2001 Ford Focus
Analog thermo.stat control kit
Have you tried removing the RH wire connected to the thermostat and try it ? This might rule out furnace as short in system. If it does the same, put RH- (heat) back on and try removing RC-(cool) , if it doesn't pop the fuse, you may have isolated the problem.?
Jul 30, 2008 | Dometic Rooftop RV Air Conditioner
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
