Question about Reliable Irons
NO STEAM THE IRON GETS HOT BUT NO STEAM IS PRODUCED
jaylex
  • 417 Answers
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
SOURCE: Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
Posted on Oct 07, 2008
SOURCE: Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Posted on Mar 24, 2009
  • 244 Answers
SOURCE: I have a Bosch Steam
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
Posted on Jun 02, 2011
  • 244 Answers
SOURCE: The iron heats up, but when the steam generator
Chemicals and minerals in the water have probably clogged the vents. Empty the water. Pour 1/2 cup WHITE vinegar into the reservoir. Turn on your iron and let it heat. Then press the steam generator button several times until the vinegar is gone. Unplug the iron. As it is cooling, take acotton swab and gently wipe the surface of the vents. You can probe GENTLY with the swab, but don't push it into the vent or the cotton head may get stuck.
As you're pressing the steam button, keep the iron in the ironing position, not standing. If the vinegar just will not come out of the vents, use a wooden toothpick to loosen the build up.
This always works well for me and I hope it does for you.
If so, please come back to Fixya and rate my advice!
Posted on Jul 20, 2011
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
What can be done about leaking steam?
ensure your iron steam button is not set into perminent steam function. leaving the iron with the point of the iron pointing upwards should reduce steam to the handle. also the iron may need to be descaled to ensure any steam switch funtion is not stuck in an on position.
May 12, 2014 | Euro-Pro Steam Generator EP8001 Iron
How do I use the self clean button in the DW5080 Focus 1700 Watt Steam Iron
please read carefully the owner manual and get the information about how to use the steam.
download from www. fitness.manualsonline.com
God bless you
Feb 01, 2013 | Rowenta DW5080 Focus 1700 Watt Steam Iron...
Users instructions elitech 2000w steam iron
alas we've had the same problem since day one, just opened it up, must be the boiler unit leaking at the start to emit the steam so the handle gets hot and now the seal is totally gone it will just leak when the water gets too hot
Dec 12, 2011 | Irons
I have so far seen 3 other people with the problem i have with my russell hobbs steam glide iron 13153. I have tried what was suggested to me but nothing has worked. the iron gets hot but no steam coming...
I would write to russell hobbs and complain, my friend bought one of these 18 months ago and hers got hot but no steam through. She sent it back to them and they sent her a new one as a gesture of goodwill.
Aug 04, 2011 | Russell Hobbs 13153 Iron
My iron rowenta leaks when before and after i!m iroeing
my iron is different to yours but i used to have leaks as well.
for me it was because i have a heat setting dial that indicates that the steam function is activated when set to a very high temperature.
i also have a push lever on the top of the iron that controls how much, if any, steam is produced by the iron.
the amount of steam is regulated by letting more or less water through to be vaporised by the heating element.
if the heat setting is low and the steam setting has not been switched off then water is being allowed through but the element is not hot enough to vaporise the water. the result is water pooling and either dribbling through onto the clothing you are ironing or running off when you sit the iron up.
maybe it will help if you turn the steam setting off while the iron is not in use.
Jan 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Thanks J
Feb 10, 2008 | Rowenta Steam 'n Press DA75 Iron
Irons Logo
59 people viewed this question
Top Reliable Irons Experts
Are you a Reliable Iron Expert? Answer questions, earn points and help others
