Question about Vivitek D508 Projector
Power supply CIRCUIT OF POWER SUPPLY
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: circuit manual of power supply of vivitek d832mx
These are not available except for payment but you can get technical help for your fault from the link below; http://www.vivitek.in/For fault on SMPS get some tips from the link below:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Nov 30, 2011
Crt standard hisense 54cm colour tv model tc2198L no powering fuse ok HOT ok.
Check the power supply.If you have no output from the power supply try to disconnect the power supply from the other circuits ( such as the IF,audio,video,horizontal,vertical,etc.If the voltage at the power supply comes up when you disconnect a particular circuit then that circuit is loading down the power supply and you would troubleshoot that circuit.If after disconnecting the other circuits and the power supply still shows zero,then you would troubleshoot the power supply.
Sep 14, 2013 | Televison & Video
Tip
Ducati Fault Codes
Engine Fault Codes - Ducati 749/999
To see the fault codes, with the ignition off hold both dash buttons down and turn ignition on.
1.1 TPS Disconnected
1.2 TPS short circuit to earth
2.1 Pressure Sensor short circuit to power supply
2.2 Pressure Sensor shorted to earth
3.1 Water Temp Sensor shorted to power supply
3.2 Water Temp Sensor shorted to earth
4.1 Air Temp Sensor shorted to power supply
4.2 Air Temp Sensor Shorted to earth
5.1 Battery Hi
5.2 Battery Low
10.1 Hor. Coil shorted to power supply
10.2 Hor. Coil shorted to earth
11.1 Ver. Coil shorted to power supply
11.2 Ver. Coil shorted to earth
12.1 Inj1 shorted to power supply
12.2 Inj1 shorted to earth
13.1 Inj2 shorted to power supply
13.2 Inj2 shorted to earth
14.1 Inj3 shorted to power supply
14.2 Inj3 shorted to earth
15.1 Inj4 shorted to power supply
15.2 Inj4 shorted to earth
16.0 Pump Relay
17.1 LH Fan shorted to power supply
17.2 LH Fan shorted to earth
18.1 RH Fan shorted to power supply
18.2 RH Fan shorted to earth
19.1 Starter Solenoid shorted to power supply
19.2 Starter Solenoid shorted to earth
30.0 ROM/Eprom error
34.0 Signal Panel Sensor
36.0 Speed sensor
37.0 Immobiliser (transponder)
37.1 Immobiliser (antenna)
37.2 Immobiliser (instrument panel serial driver)
37.3 Immobiliser (serial cable disconnected)
37.4 Immobiliser (ccm serial drive)
37.5 Immobiliser (key not recognised)
37.6 Immobiliser (ccm program)
38.0 Can Line error
Source http://moto-files.weebly.com/ducati-fault-codes.html
on Dec 20, 2016 | Motorcycles
Power comes on for two seconds then goes off. Trouble code is 21. Is this worth fixing?
The X-Ray Protect circuit monitors:
* Excessive High Voltage
* Excess CRT Beam Current
* Excess HV Circuit Current
The X-Ray line is normally High. If any of the monitored sources exceeds its' specific reference, the X-Ray line is pulled Low, shutting Off the TV. If X-Ray protect shuts the TV Off, pressing the Power button will turn the TV back On ( it will shut Off again if the problem still exist).
Possible Problems: Power Supply Fault, Sweep Circuit Problem, Doubler Board Fault or a leaking CRT. You may have bad capacitors in the power supply or the sweep power supply.
Check for CRT leaking, few drops of clear light oil. If this is leaking the fix is costly and not worth fixing.
Inspect for puffy capacitors on the power supply and sweep circuit boards, if you can solder replacing capacitors is cheap, middle pricing for replacing power supply or circuit boards.
Feb 28, 2011 | Mitsubishi Televison & Video
Power light flashes red 6 times. No picture.
The common fault often points the problem being to the power supply or the main printed circuit board.
If you are tech-savvy, you can open the back of the unit and measure, using a multimeter, the voltages from the power supply printed circuit board as well as the main printed circuit board, if the power supply is sending insufficient voltages, its common that you will get the flashing red lights.
Also check for any blown capacitors on the power supply as well as any shorted resistors. I hope this helps.
Aug 07, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Fuse for gx150 power supply
The fuse is located inside the ATX switch mode power supply and it is solder onto the circuit. There are dangerous voltages inside this power supply. I suggest you get a new switch mode power supply because failure of a component inside the power supply has caused the fuse to blow and replacing the fuse would most likely not fix the power supply.
Apr 03, 2010 | Dell Computers & Internet
No power
Was check 12-5v power supply?
Use other power supply for check it.
The power circuit in mother board is microswitching with integrated circuit, it is off commercial supply, no body sale it.
Mar 10, 2010 | ASUS P5V800-MX Motherboard
My power supply had ashort circuit smell burnd,
This power supply is a standard power supply that will handle 200 plus watts.
It can be replaced with just about any ATX supply and really would be a waist of time trying to trouble shoot it.
Any 24 Pin ATX supply will work just fine in its place.
Nov 29, 2009 | AOpen (FSP200-60SAV) 200-Watt Power Supply
Circuit diagram
I'm afraid I cannot comply with your wishes, as there are copyright laws governing this, for one. (For existing circuitry)
Two, there is the liability issue. Take for example that I design the requested circuit, give it to you freely, and you or someone in your group is injured using my circuit.
Will state that this is a basic circuit design. I believe that if you 5 put your minds together, you can build this circuit.
Sep 14, 2009 | Powerline 200Watt DC to AC inverter...
2000 Ram 1500 4x4 "no bus"
All the modules are connected together to communicate with each other via the PCI bus. It is possible that one of the modules is pulling the bus down. If the vehicle won't start it could be any one of the modules. It will be a process of elimination to find the faulty one by disconnecting them one at a time.
Apr 22, 2009 | 1998 Dodge Ram 1500 4WD
Vivitek D508 Projector Logo
26 people viewed this question
Top Vivitek Office Equipment & Supplies Experts
Electro Med Services...
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
