Polaroid 2001G DVD player and recorder won't eject or go past the HELLO. POWER ON
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
If the set switches ON, and the display says 'eject' when you press the eject button, and the disc tray do not eject, the fault should be with its mechanical side. Check and replace the disc loading mechanism. Prior to that, check whether the loading belt is broken or not. If broken, replace it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on May 12, 2014
4 Suggested Answers
  • 226 Answers
SOURCE: DRM-2001G weak remote
The range problem with the remote can be fixed by replacing the LED in the remote with a Radio Shack 276-143. The LED is a lot stronger and now the remote works a lot better.
You may also find that the 'receiver' inside the cabinet is pointed at an angle instead of directly towards the 'window'. You can trim the rubber(?) to allow it to point correctly.
Posted on Apr 29, 2009
  • 226 Answers
SOURCE: DVR making bad DVDs
Three suggestions:
1) take it apart and clean the laser and the spindle 'hub' that the DVD rests on
OR
2) get a 'cleaner' disk that will 'whisk' any dust from the laser diode.
OR as a final suggestion
3) replace the DVD recorder with another. Plain old EIDE parallel interface units fit fine.
This is a very friendly machine in that it will accept PC compatible hard disks and DVDR drives.
tom
Posted on May 11, 2009
SOURCE: default password to unlock hard drive video on
Default password for DRM-2001g is: 3308
Posted on Feb 07, 2010
Need polaroid customer service number
Start at http://polaroid.com/support. Pick a product category and then your country to get the contact information.
Aug 06, 2013 | Polaroid DRM-2001G DVD Recorder/HDD...
I have the polaroid dra-01601a dvd/hdd audio
First of all with all do respect I do not have the polaroid drm 2001G. I have as I exprest in my letter to you the polaroid dra 01601A. The problem i had was an audio problem and i simply rechecked all my connections and found that I needed and extra set for HDMI plugs on my TV.
Jan 03, 2010 | Polaroid DRM-2001G DVD Recorder/HDD...
No audio on polaroid DRM-2001G
just unplug the power cable for few seconds
Oct 21, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Drm-2001g turn on says hello that all
If you are comfortable with electronics and using a DMM, you could remove the cover and check the voltage on the power supply. Likely you will find that a few capacitors on the power supply have leaked onto the board, or are bulging on the top. If you can replace them with equivalents, it may bring your machine back to life.
This unit runs extremely hot, and capacitors, electrolytic anyway, will dry out and fail. There is a 'gel' inside that just dries out. That is why the fan blows on the power supply in later models.
You might also have a failed hard drive. You can substitute a known good disk. Make sure the jumper settings are the same. If that is the problem, it will take a few minutes after you power on for the machine to finish setting up the disk.
tom
Apr 16, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Apr 06, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
DVR making bad DVDs
Three suggestions:
OR
tom
Feb 04, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Polaroid Will NOT edit out Commercials!
You need to post edit the recording;
First unprotect then do a split before the commercial
than split after, then recombine the parts without the ad.
Cumbersome, but it works
Feb 12, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
