Question about Saeco VIA Venezia
Venezia vae know boil water for coffee coming out the head
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
It sounds like you need the tune up kit. I got mine at Seattle Coffee Gear. http://www.seattlecoffeegear.com/seattle-coffee-gear-tune-up-kit-for-saeco-via-venezia. It was really easy to unscrew and replace the parts. Good luck
Posted on May 17, 2014
    Habit-Forming:
  • 111 Answers
Sounds to me, that the Pump is not working!
Also have you checked if the temp of the water changes, as in have you seen the water prepare to boil, in the Water Unit that hold the water ?
It also sounds like it could be the thermostat. and it may needs changing?
So what you best doing is look for those signs like I just said.
And if non of it works then you have problem with Pump/ thermostat .
Nige
Posted on May 12, 2014
  • Ted Robey May 17, 2014
    If I understood right, he has boiling water, it is leaking out of the head. When this happens, it means the retaining. Spring for the white busing has worn and the spring and bushing need replacing.
2 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Water won't come through
If the pump vibrates when trying to draw water then that is a good sign. Remo;ve the hose on the output side of the pump and turn it on to see if it draws water(BE Careful water and electricity love each other too much), it water flows out the output side, reconnect to boiler and test. If that did not solve the no draw problem then the machine is blocked either at the boiler.
Posted on May 24, 2009
The ready button does not come on. No water comes
Check the thermostats on top of the boiler for the ready light, or the light itself.
For the coffee, check the screen under the head, remove it and make sure it is clean, if yes then remove the 2 allen wrench screws and check the valve and spring make sure it is not blocked.
Feb 20, 2010 | Saeco VIA Venezia
My machine seems to heat up, it runs like it is drawing water into the boiler and it will froth but it does not brew espresso now. What could be the problem?
Hi
If water comes out the head with out the portifilter in then its you portafilter or your grinds are too fine. If its not coming out the head then your pipe in the brew head are plugged with scale.
Nov 25, 2009 | Saeco VIA Venezia
Doesn't pressurize in order to steam
Can you get hot water and hot coffee from the machine? If yes, then check the thermostats on the boiler, it is possible that the one for the steam could be damaged. Check the schematic below I know its a gaggia model but its close.ac19505.jpg
Aug 12, 2009 | Saeco VIA Venezia
Saeco espresso machine Isn't pulling water at all
Can you brew a coffee? If not then the problem is the pump might be blocked.
Jun 22, 2009 | Saeco VIA Venezia
Water won't come out like its blocked
Water won't come out when you brew coffee or use the steam wand?
If its when you are using the steam/hot water valve the parnello might be clogged.
If it is when you are using the brew head, then try backwashing the machine with espresso machine cleaner(Purocaff or Cleancaff).
The pump could also be blocked, or the spring in the pump might be damaged, open machine and check pump.
May 15, 2009 | Saeco VIA Venezia
Water won't come through my Saeco via venezia coffee machine. It was working fine until I cleaned it so I don't think the pump has gone.
May 11, 2009 | Saeco VIA Venezia
The steam coming out of my espresso smells burned
Try descaling amchine to clean boiler.
Mar 12, 2009 | Saeco VIA Venezia
Steam works, coffee doesn´t
Try to prime the machine.
Open the steam knob and press the buttom for coffee, when the water comes, close the steam knob.
Aug 24, 2008 | Saeco VIA Venezia
Saeco VIA Venezia Logo
170 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
