Question about Canon Pixma MP480 All-In-One InkJet Printer
Are there any updates for this computer? - Canon Pixma MP480 All-In-One InkJet Printer
Tip
Some important tips to update your computer drivers
<p><span>Computer drivers</span><span> are useful for your <span>computer</span> run smoothly with some hardware such as hard drive, CD/DVD drive, Graphics Card, USB and other components of your <span>computer<b>.</b></span></span><br /> <p><span>So it is important to update your drivers when you have a <span>computer.</span> These are tips that how to update your drivers, it will help you to find the problems in your <span>computer</span> when you run some applications. It is important to ensure that they work perfectly with your computer.</span><br /> <p><span>If you facing some problems with a device, it may cause of need a driver update. If you have other software on your computer, you may need to update drivers, for it's running smoothly. </span><br /> <p><span>Here are some tips<b> </b><span>that will help</span> you to update these drivers. </span><br /> <p><span>The first thing is to know about your driver, there are different drivers on your computer. If we have knowledge of what we need and which hardware required drivers to update, it helps you to find what is to be updated. </span><br /> <p><span>The driver for your <span>computer,</span> such as scanner, DVD, printers, video, audio, USB, webcam, digital camera, and others can also your Windows drivers, if you run on the operating system. </span><br /> <p><span>You should make your equipment familiar. And do not take too much to go into the depth details of them, but having working knowledge can make your easy. Here are some product online and find it that will takes to be a smooth process. </span><br /> <p><span>Everything you need to do is available in start menu click on window update button.</span><br /> <p><span>The manufacturer's site will help you to get the drivers for your PC update. You must ensure that you at the exact same model of the device that you looking for update. </span><br /> <p><span>If you do not want to search driver updates online and during the test, then you can go to software that automatically update all the drivers on <span>your computer</span> and keep its equipment running smoothly. This process may be the easy and simplest way to update your drivers quickly.</span><br /> <p><span>By using these operations your Computer will give you best performance.</span><br />
on Dec 24, 2010 | Computers & Internet
Tip
Disable Automatic Reboot after Windows Update
Have you seen the message
"Automatic Updates
Updating your computer is almost complete. You must restart your computer for the updates to take effect.
Do you want to restart your computer now?"
Automatic Windows updates are very good for computer security. However, when these Windows updates are downloaded and installed on your computer, if the updates require a reboot of your computer, Windows keeps prompting you to reboot your computer.
Now, Windows XP Pro users can disable automatic reboot of the computer after a Windows Update. In order to do that, follow these steps
Disable Automatic Reboot after Windows Update for Windows XP Pro usersWith this setting you will be able to specify that after a scheduled Windows update, Automatic updates will wait for the computer to be restarted by any user who is logged on, instead of causing the computer to restart automatically. If this setting is not enabled or not configured, your computer will prompt you every 5 minutes to restart the computer to complete the installation.
1. Press <Windows Key> + R which will launch the Run command. Type gpedit.msc and press Enter
2. Group Policy Editor will now be launched
3. On the left hand pane, under Local Computer Policy, click on the (+) sign next to Computer Configuration
4. Click on the (+) sign next to Administrative Templates. Then click on (+) next to Windows Components and then click on Windows Update
5. Double click on No auto-restart for scheduled Automatic Updates installations. A settings window will now open. In there, select Enabled and then press OK
6. Close the Group Policy Editor
Disable Automatic Reboot after Windows Update for Windows XP Home usersThe settings are a bit different for Windows XP Home users because there is no group policy configuration for Windows XP Home.
1. Press <Windows Key> + R and type in regedit. Press Enter
2. Navigate to
HKEY_LOCAL_MACHINE SoftwarePolicies MicrosoftWindows WindowsUpdateAU
3. Change the "NoAutoRebootWithLoggedOnUsers" DWord value to 1 to Disallow auto reboot.
4. Press OK
if this tip really help u pls vote ,...........shailendra
on Oct 03, 2010 | Computers & Internet
How to desible Dell optiplex 755 Frimware updates
There is no need to "disable" firmware updates.
The computer will only accept "valid" updates.
So, how would somebody be able to access your computer, in order to try to update the firmware. Prevent access to your computer, and you will have prevented the firmware from being updated.
Oct 19, 2014 | Dell Optiplex 755 Desktop Desktop Computer...
Download ios 6
Install the latest iTunes.
Then
Update your device using iTunes
If you can't update wirelessly, or if you want to update with iTunes, follow these steps:
If you use your device's Personal Hotspot for your computer's Internet connection, update your device wirelessly or connect your computer to another network.
Install the latest version of iTunes on your computer.
Plug in your device to your computer.
In iTunes, select your device.
In the Summary pane, click Check for Update. 975b3562-83bf-4984-a552-164adcbaa5b2.jpg
Feb 18, 2014 | Apple iPad Tablets & eReaders
Error 1439 cant restore ipod keeps on popping. my ipod is a classic black.
  1. Disconnect and reconnect your iPod to iTunes, and then attempt to restore or update the iPod again.
  2. Restart your computer and then attempt to restore or update the iPod again.
  3. Try connecting your iPod to a different USB port, and then attempt to restore or update the iPod again. Connecting to a USB 2.0 port is recommended. For Windows computers, refer to Identifying USB 2.0 ports on your computer for instructions.
  4. Remove any USB devices not manufactured by Apple that you have connected to your computer (it is not necessary to remove your keyboard or mouse). Then, attempt to restore or update the iPod again.
  5. Update to the latest version of iTunes, and then attempt to restore or update the iPod again.
  6. Try to restore or update the iPod again using a different user account for your computer. For example, create a new test user account on the computer with admin rights, and with iTunes installed, try to restore/update the iPod.
  7. Try disabling Disk Use on your iPod and attempt to restore or update the iPod again. If that doesn't work, try enabling Disk Use on your iPod and attempt to restore/update. Refer to Putting iPod into Disk Mode below for instructions.*
  8. If using a Windows PC to restore or update your iPod, try to reregister ".dll" files as described below this list.**
  9. If using a Windows PC, try to update or reinstall your Windows USB drivers, referring to the section titled "iPod only: Updating, or in some cases reinstalling, the drivers for your computer's USB interface may resolve this issue."
Apr 23, 2011 | Apple iPod classic MP3 Player
Vertical lines and discoloration on my sony vaio vgn a140
It is required to get the BIOS and the Video Driver Updated in the Computer to resolve the issue.
The BIOS Update and Video Driver Update are available at Sony Support Site for download.
You can view and download the BIOS Update from this link
Before installing the BIOS update, be sure the computer is running from AC power. If the installation of the BIOS is interrupted by power loss, the computer may not operate correctly or at all.
During the installation of this update:
  • Do not turn the computer off.
  • Do not allow the computer to enter Standby or Hibernation states.
  • Do not start other programs.
  • Do not connect any peripherals.
Download the AIBSYS-00772903-US.EXE file to a temporary or download directory.
Go to the directory where the file was downloaded and double-click the "AIBSYS-00772903-US.EXE" file to begin the installation.
At the "BIOS Update Utility for Microsoft® Windows® XP" box, click "Next".
At the "License Agreement" dialog, read the agreement, then, if you agree, click "I Agree" to continue with the installation.
NOTE:
Please wait while the utility extracts the necessary files for the update.
At the "VAIO BIOS Update Tool 1.0.01.10181" box, click "Update".
At the "WBFLASH" box, click "OK".
NOTE:
Please wait while the utility updates the BIOS.
At the "WBFLASH" BIOS Update successfully completed box , click "OK" to shutdown the computer.
After the computer shuts down, wait for a few seconds, and then power on the computer.
After the computer restarts, the installation of the BIOS Update is complete.
After installing the BIOS Update, it is required to Update the Video Driver to resolve the issue.
You can view and download the Video Driver Update from this link
Download the ATDVID-00610812-US.EXE file to a temporary or download directory (please note this directory for reference).
Go to the directory where the file was downloaded and double-click the ATDVID-00610812-US.EXE file to begin the installation.
Then, please follow the onscreen instructions to complete the installation.
After installing the Video Driver Update, please restart the Computer for the settings to take the effect.
Performing the above steps should fix the issue.
If the issue is not resolved, please check if the Vertical lines and discoloration are visible while accessing the BIOS Setup Utility.
To access the BIOS Window, please restart the Computer, press and hold the F2 Key to access the BIOS Setup Utility.
If the lines and discoloration are available on the BIOS Setup Utility window, the issue may be related to the LCD Screen of the Computer and you will need to get the Computer serviced to fix it.
In that case, you can contact Sony Service Center get the Computer serviced and resolve the issue.
Apr 14, 2010 | Sony VAIO VGN-A140 PC Notebook
Downloaded windows automatic update stuck on 3 of 3 for last few days. tried last known good config does nothing, i always return to updating 3 of 3 cannot get my comp to do anything else. help desperately...
An issue has been identified by Microsoft that, after installing Windows Updates, a Computer displays a Configuring updates: stage 3 of 3. 0% complete message, reboots, comes back to that message again, and repeats the cycle. This problem occurs when Windows Update is attempting to install update 937287.
Follow this procedure to resolve the error:
1. Remove all connected peripheral Devices from the Computer.
2. Press and hold the power button until the Computer completely shuts down.
3. Unplug the power cord from the wall outlet.
4. Leave the Computer without any power for at least 30 seconds.
5. Reconnect the Computer to the power supply and then turn it back on.
6. Allow the Computer to start normally.
NOTE 1: Once the Computer has completely started into the Operating System, Windows Updates should automatically finish installing the update. If the update again fails to install completely, restart the Computer in Safe Mode (by tapping the F8 Kay at Start-up) and use the System Restore feature to return the Computer to a time before the issue started.
Click the Start -> All Programs -> Accessories -> System Tools -> System Restore.
NOTE 2: To avoid this issue, obtain and install update 937287 from the Microsoft Download Center separately from all other updates on the Windows Update site. Install the update that applies to your version of Windows Vista so that you can successfully install future updates.
For more information about this error, refer to the Microsoft KB Article ID 949358.
Good Luck!!!!!!!!!!!!!!
Dec 01, 2009 | Dell Computers & Internet
Windows Update
What Windows update type/number is this?
Jul 09, 2009 | Microsoft Windows XP Professional SP3 Full...
JAVA multiple programs on disk
no you don't. Just keep the most recent version.
May 04, 2008 | Sun -115H Computer Speakers
Canon Pixma MP480 All-In-One InkJet Printer Logo
16 people viewed this question
old marine
old marine
