Question about Xerox WorkCentre 3045ni Multifunction Printer
How to clear error code 077-900 on xerox workcentre 3045 printer?
My printer has an error saying paper jam remain on exit
mstr2kx
  • 96 Answers
SOURCE: Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Posted on Mar 20, 2007
  • 208 Answers
SOURCE: Xerox WorkCentre Pro 785
My best guess with the A4 is that the tray guide is not set correctly. Or the machine has been told that your tray has A4 in the tray.
If you resolve the A4 issue, you will most likely resolve the jamming problem since it is looking for a longer piece of paper.
Additionally, take a cloth with a soapy cleaner. Fantastic, some cleaner like that, take out the drum, and toner cartridges and clean all the rollers you can see throughly.
If that doesnt resolve the issue then you may also have some very worn out rollers. See if they feel slick .
Posted on Dec 05, 2007
  • 3 Answers
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Posted on Oct 07, 2008
  • 3 Answers
SOURCE: error message on Xerox workcentre
Fuser jam, maybe the exit switch ?
If you turn the unit off and back on does it come up ready to copy or ready to scan you job
Posted on Mar 09, 2009
  • 2072 Answers
SOURCE: Xerox workcentre c2424 error code
One of two things most likely.
1. The wiper blade is stuck to the print head,or 2, The print head blosk has a lot of spill over ink built up in it.
That code is caused by the inability of the print head to move properly. Either left to right or pivot front to back to get into the print position.
You have to remove the covers to access the stainless steel print block. It is located about 2/3 of the way back on the lower left side of the frame. It is a one inch by one inch square block that may have a lot of buildup of spill over ink in it. If the wiper is stuck you have to remove the ink loader , where you add the ink sticks , to access the area between the print head and drum, It is a pink blade the is between the drum and print head, it wold be stuck to the print head not allowing it to move. Just carefully unstick it from the print head
Posted on Mar 28, 2009
Fault code 008-164 for xerox workcentre 7328
Xerox 7346
What is the problem of error code 008-164
Nov 07, 2012 | Xerox WorkCentre 7328 Multifunction laser...
Xerox Workcentre 4150. Paper keeps jamming in print engine area. We clear the jam and it jams again.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. ItemInc.com has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Jun 23, 2011 | Xerox WorkCentre 4150 Black and White...
We had a paper jam in the print engine area. Once the paper path has been cleared we are still receiving clear misfed paper in print engine. I have fed paper through the path and cannot find any paper jam.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Area" you should check and possibly replace the fuser exit actuator (part# 120N00534). Iteminc.com has this part in stock and ships same day. Here is a video the shows you how to check and replace the fuser exit actuator. Good luck, and thanks for using FixYa!
Jun 17, 2011 | Xerox WorkCentre 4150 Black and White...
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
Error message shows e2 but there isn't a paper jam anymore
Hello sir; try to turn off the power and turn on, if still don't work, you have to check the sensor it located where the paper got jam,
Jan 10, 2009 | Xerox WorkCentre XD120f Copier
Xerox WorkCentre Pro 215 E2 Error Code
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Nov 19, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
E2 Paper Jam code flashing .... but no paper jam!
There is a small sensor on the fuser that most likely has become disloged. It requires a lot of disassembly to get to.
But an E2 code is that sensor not being cleared off. It pops out of the frame sometimes during paper removal.
Apr 14, 2008 | Xerox WorkCentre XE80 Laser Printer
Troubleshoot xerox workcentre xl2140df we have an error code E5?
An E-5 Normally comes from the paper path actuator that detcts the second side of a copy is hanging up.
In the fuser area there are some corrigated looking parts of the fuser exit guide that the actuator is most likely hitting or hanging up on.
You may have to take a pair of diagional cutters and snip a small section of that out.E-5 is a jam on duplex copies on that machine.
Jan 12, 2008 | Xerox WorkCentre XL2140df Laser Printer
Xerox WorkCentre 3045ni Multifunction Printer Logo
1,153 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
