Question about Xerox WorkCentre 3045ni Multifunction Printer
How do i clear an error code 077-900 on a xerox 3045 printer?
My printer reads paper jam but there is no paper inside the machine
mstr2kx
  • 102 Answers
SOURCE: Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Posted on Mar 20, 2007
SOURCE: paper jam
I had the same problem kept getting an error something like Jam at Exit Door Open Door A. When I looked at the top of the where paper normally comes from and flipped it open I found a super crinkled piece of paper, which once removed cleared the jam.
Posted on Oct 23, 2008
SOURCE: Xerox 6250 - Jam at Registration Roller
Ik heb een deregelijk probleem gehad, ook bij merdere printers tegelijk. De oorzaak was achteraf logisch. We hadden een nieuwe zending briefpapier waar een bepaalde film op zat waar de printer niet tegen kan. Logisch, want het kan niet zijn dat alle 3 printeres tegelijk hetzelfde mankeren.
Ander papier erin. De eerste hoeveelheid zal nog problemen geveb tot der olletjes vrij zijn van de vettigheid.
groeten,
G.Eijken te Hoorn
Posted on Nov 15, 2008
yooperbud
  • 8637 Answers
SOURCE: Xerox WorkCentre PE120i - Paper Jam 1
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 28, 2009
  • 526 Answers
SOURCE: Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Posted on Apr 15, 2009
Error code: 05,004.44:159443
Hi Lee,
You might have this problem sorted by now, however if not read on.
Your problem could be a multitude of things, perhaps you still had a small piece of paper stuck inside. Perhaps you caught one of the paper sensors and it won't operate any more.
Difficult to say you just have to look very carefully.
Good Luck.
Jun 16, 2015 | Xerox 8860dn Phaser All-In-One Thermal...
08,045.43:5458 power outage happened, when power
This error indicates that the paper path motor stalled. Clear the paper jam, power off the printer for 30 seconds and then turn it back on.
Here's how to clear a paper jam from Xerox website, depending on the location of the paper jam: http://www.support.xerox.com/support/phaser-8560mfp/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 19, 2011 | Xerox Phaser 8560MFP Laser Printer
Xerox 7300 paper jam A 10 error code jam telling me to open top tray and I've looked at the machine inside out and cannot find any scraps of paper or any location where there is any traces of paper being...
There is most likely a small piece of paper in the rollers take out Tonor and any parts that will come out with out having to use any tools. then spray with a can of air in all the rollers.
Chris Thrash
B52Computers
Jan 10, 2011 | Xerox Phaser 7300DN Laser Printer
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
Aficio 3045 suddenly indicate jamming.
format the hard disk if available check wheather there is not any paper in duplex or in the machine if not then check paper settings if not then execute memory clear if not then replace the registration sensor and exit sensor if not then replace thermistors if not then replace nvram
Sep 10, 2009 | Ricoh Office Equipment & Supplies
Xerox Phaser 8400 Error code 07,010.43:99907
You manually rotated the aluminum drum? Since you did that, I would suspect you have the print head wiper blade stuck between the drum and print head. The code you are getting it caused by the print head not being able to move freely.
The jamming is probably due to a bad registration clutch. Common failure on that machine.
You can go to Xerox.com, there is under documentation and drivers a parts list for that machine. You can reference the wiper blade and get the clutch part number there.
Let me know what other information you may need. I will be glad to help you get it running again.
Jun 17, 2009 | Xerox Phaser 8400 Laser Printer
Xerox WorkCentre Pro 215 E2 Error Code
Nov 19, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Constantly jams
Xerox has some good information on their web site regarding troubleshooting problems with their printers. I'd first suggest you visit there for help. As for general jam problems, try to determine where the paper is jamming. If it is a feed problem, for example, you can clean the feed rollers with Isopropyl Alcohol or run them over the sticky side of clear packing tape to clean them. If the paper is folding or getting stuck somewhere, look for what might be blocking it. I've seen this happen when one page jams and the page is torn and part is left in the printer. I've also seen situations where labels were put through the printer and some got free and stuck to the inside of the printer causing jams. If you can provide a bit more detail on where the jam is located, we can help you find the cause.
Aug 22, 2007 | Xerox Phaser 5500N Laser Printer
Xerox WorkCentre 3045ni Multifunction Printer Logo
336 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
