Question about Baby Gear
Remove bugaboo buggy board connecters
How do i take the connecters off my cameleon? Do i just prise the plastic apart andhope for the bedt?
  • Baby Gear Master
  • 1,629 Answers
Hi Sarah
We recommend you contact Bugaboo for assistance
Bugaboo Customer Service
Posted on Jun 09, 2014
Whitenoize
  • 11 Answers
SOURCE: lost the bugaboo cameleon manual - need to install seat
You can find the user guides on the Bugaboo website.
https://www.bugaboo.com/US/en_US/support/product-information-strollers
Posted on Mar 23, 2009
  • 12 Answers
SOURCE: changing my bugaboo cameleon from carry cot to buggy
Watch the video, "bugaboo assembly" on youtube. The trick is getting the buckle over the silver pins. You actually have to bend the frame to secure the strap then pull out the frame so it is straight again.
Posted on May 12, 2009
  • 23 Answers
SOURCE: Spare Parts for Bugaboo Wheeled Board
For Bugaboo spare parts, the best way is to contact Bugaboo direct (www.bugaboo.com) or a local Bugaboo stockist who should be able to order in the spare part for you.
Posted on Sep 17, 2009
macnutz
  • 541 Answers
SOURCE: Cameleon Jogger Stroller: The hinge on my bugaboo cameleon is stuck-in and n...
How to fix a Bugaboo Handle
If you are not a handyperson type, take these instructions to you local Bicycle Mechanic or Small engineering shop.
The bugaboo handle fault is caused by two small plastic pins shearing of a plastic disk that actuates two metal locking rods. Why bugaboo uses a plastic disk for this critical component is beyond me!
1/. Remove the domed star lock washer. This is the hardest part of the job. Most people try to leaver this off in the hope of re using. First problem with this is you will mark or damage the surrounding plastic second is star locks are not intended for reuse and will never hold as well as when first used, so best find a new replacement. A hardware store should be able to source some for you. Quickest way to remove a dome washer is to carefully cut a slot in the dome with an angle grinder and then use a large screwdriver to prize off.
Note it is best to open and repair one side at a time, so your moving and flexing one side of the handle does not dislodge parts in the other side.
2/. The lock mechanism is very simple; a wire rod rotates a plastic disk. The disk has two plastic pins that move the locking rods in and out of the inner hub into and out of the outer hub. You need to ether repair the disk by drilling out the pin stumps and finding a replacement metal screw you can fit / glue in. Or (my preferred choice) have a new metal disk fabricated that will last a lifetime.
3/. Reassemble handle locking hub and check operation. (I use a small amount of the grease used for taps to give a smooth action) If all has well fit, the new star dome on the hub shaft and tap home. To protect the dome finish I use a large socket from my socket set and an old rubber washer from a toilet cistern.
4/. Repeat operation on the other side. Note the disks are mirror images of each other and are not interchangeable. Bugaboo calls the side with the brake lever “LEFT” the disk will have a serial number that ends with “L”. I have had metal disks laser cut and stainless steel pins fitted. Cost of a disk with a new star dome washer is $75 New Zealand. If you like one or a set, you can contact me macnutz@xnet.co.nz
Regards
Steve
Posted on Aug 01, 2010
macnutz
  • 541 Answers
SOURCE: I cant fold my bugaboo cameleon chasis. how can i
I answered a similar question only yesterday. The sliver cap is a Capped Starlock do a google to find out more. They are a one use item and trying to remove them for reuse will mark the plastic hubs and make a weak repair. Here's my How to fix a Bugaboo Handle instructions
The bugaboo handle fault is caused either by two small plastic pins shearing of a plastic disk that actuates two metal locking rods or a broken locking rod. Why bugaboo uses plastic for the disk and aluminum for the locking rods is beyond me! They are critical components with a history of failing!
1/. Remove the capped star lock washer. This is the hardest part of the job. Most people try to leaver this off in the hope of re using. First problem with this is you will mark or damage the surrounding plastic second is star locks are not intended for reuse and will never hold as well as when first used, so best find a new replacement. A hardware store should be able to source some for you. Quickest way to remove a capped washer is to carefully cut a slot in the dome with an angle grinder and then use a large screwdriver to carefully prize one side up so you can fit a screwdriver. Note the walls of the aluminum hub axel are thin and easily distorted, make sure you only lever the capped star lock and not hub axel. Use one screwdriver as a support and another to lift off the capped star lock.
Note it is best to open and repair one side at a time, so your moving and flexing one side of the handle does not dislodge parts in the other side. The hub and disks are mirrors of each other and not interchangeable. The side with the brake lever is left The Bugaboo parts will have an "L" after their serial numbers.
2/. The lock mechanism is very simple; a wire rod rotates a plastic disk. Check the hubs for ware. If too badly worn or damaged you will have too much movement in the locked position. The Frog and Chameleon use the same plastic hub find another frame to salvage hubs from. They are held in by a single aluminum rivet.
The disk has two plastic pins that move the locking rods in and out of the inner hub into and out of the outer hub. You need to either repair the disk by drilling out the pin stumps and finding a replacement metal screw you can fit / glue in. Or (my preferred choice) have a new metal disk fabricated that will last a lifetime.
3/. Reassemble handle locking hub and check operation. If wire rods seem to be in the incorrect position, loosen the top plastic fittings where the handle extends from by removing the small self-tapping screws and wiggle things into alignment. (I use a small amount of the grease used for taps to give a smooth action) If all is working well fit the new capped star lock on the hub shaft and tap home. To protect the dome finish I use a large socket from my socket set and an old rubber washer from a toilet cistern. Repeat operation on the other side
I have parts available laser cut metal disks with stainless steel pins, replacement locking rods in stainless steel and capped star lock washers you can contact me at macnutz@xnet.co.nz
Regards
Steve
Posted on Nov 23, 2010
I would like 2 know where i can get a reolacement harness for bugaboo cameleon
There's a shop in Holland that has a lot of Bugaboo parts ask them. www.babycare.nl/spare-parts-bugaboo-cameleon-c-34_124_153.html. If it's just a broken clip Mountain Buggy clips fit and they sell them as a part unlike Bugaboo but that will involve a bit of needle and thread work.
Dec 08, 2010 | Bugaboo Cameleon - Tailored Fabric...
The white push buttons on either side of my bugaboo cameleon buggie are getting stuck in not allowing the seat to lock into any of the three positions.
You need to replace them, you can get them easily enough I bought a pair on e bay last week for 5 euro. Very easy to change just one screw.
Jun 22, 2010 | Bugaboo Cameleon Jogger
How can the Bugaboo Cameleon seat be cleaned? I
There is a company that does buggy valeting they are called buggy pitstop I think they steam clean them.
May 14, 2010 | Bugaboo Cameleon - Tailored Fabric...
How do i fix the squeaking on my bugaboo cameleon wheels?
try wd40 oil or ask fred at www.buggypitstop.co.uk they have answers to all buggy question they are great and very helpful.
Apr 26, 2010 | Bugaboo Cameleon - Tailored Fabric...
How to wash Bugaboo Cameleon seat fabric? As the manual told that all the parts are able to taken apart but I still confused. Especially the seat fabric. there are the back support saw inside. I have no...
If you are talking about the base seat fabric, before you put the seat fabric in the washing machine remove the wooden and foam piece from inside the seat and then throw it in on cold with a gentle cycle. DO NOT put it in the dryer. Hang it to dry. Mine came out great like this. If you are talking about the tailed fabric that goes over the base seat fabric, then just remove the cover and put it in the washer - again NO dryer.
Mar 17, 2010 | Bugaboo Cameleon - Tailored Fabric...
Problem re-attaching bugaboo stroller seat cover
contact www.buggypitstop.co.uk they are the only buggy valeting company and are the specailists they will be able to help you.
Feb 28, 2010 | Bugaboo Cameleon Jogger
Bugaboo cameleon snapped break cable
try buggypitstop they sell new and second hand parts for bugaboo. They have a website
Oct 23, 2009 | Bugaboo Cameleon Jogger
Changing my bugaboo cameleon from carry cot to buggy
Apr 14, 2009 | Bugaboo Cameleon Stroller
Bugaboo cameleon stroller
hi
no expert here on buggys lol.
but i did find this link it may or may not be off any guide but you can try Cameleon FAQ althought i would suggest try contacting bugaloo see if they will email you a manual for free.
hope the above link was some help.
riz.
Apr 08, 2008 | Bugaboo Cameleon Jogger
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
