Question about Sony STR-DE485 Receiver
Code for remote control for sony STR DE 485 E
petraman7
  • 1175 Answers
SOURCE: Remote Doesn't control stero
Blinking doesnt always mean that the IR transmitter is working in the remote.
Check a couple-few of the online remote dealers you may be able to get one cheap.
Posted on Feb 24, 2008
  • 336 Answers
SOURCE: Remote control won't work
Could need a new ir sensor or repair solder connections on the display (ir) board. You can check that the remote is putting out a signal by viewing it with a camcorder, turn the camera on look through the viewfinder and point the remote at it push a button. If it is working you will see a flashing light on the remote.
Posted on Feb 09, 2009
  • 652 Answers
SOURCE: Sony STR DE-445 unit powers up but no sound
Check the fuse, Sony is known for its random problems with sound. The one I have you must tap it on the side. Its a flicker switch inside.
Posted on Feb 14, 2010
Handyman Joe
  • 16 Answers
SOURCE: Programming my DishNet remote for my Sony AV System
OK...Press and hold the clear tv button on the upper left hand portion of your dish remote until all of the mode lights illuminate. When illuminated, release and clear tv button would flash. Press 500 followed by the pound key and the clear tv button would flash 3 times. Try to press now the red tv button to power off the tv, and try the volume and mute buttons to. Before changing the channels, press the SAT button to set it on satellite mode. Now try all of the functions....
Posted on Mar 26, 2010
SOURCE: Sony STR DE 485 is locked on Protect mode
hi i have a protect error problem and the power is only pluged in
Posted on Jul 30, 2010
Need remote control programming codes
I assume you have purchase a universal remote control...if the programming codes for your Sony STR-DE675 receiver is not listed in the remotes code guide, then you purchased the wrong type universal remote. Make sure you get a universal that does stereo equipment or check eBay for a reasonable price on the original.
Jan 07, 2014 | Sony STR-DE675 Receiver
The 1/4" headphone jack broke on my Sony STR-DE 485 receiver. How do I replace it and what it the part number?
1-683-763-11 is the p/n for the headphone board. Should be easy to replace. Just unplug the old one, take take the screws out, and put the new one in.
Mar 30, 2013 | Sony STR-DE485 Receiver
The digital sound is off after 1 houre str de sony str de 485
It sounds like the receiver is either failing or going into a thermal protection mode.
There should be NO reason why the input source (digital versus analog) should make a difference unless you play the digital sources obscenely louder than the analog ones.
If you suspect heat, you should be able to feel it.
Can you verify that the digital sources ONLY do this?
Mar 01, 2010 | Sony STR-DE485 Receiver
Remote Control Programming
it is so good to hear from you friend. the replacement remote that you need is on newremotecontrol.com. the number that you are looking for is 148058621. this remote cost 24.95. thank you for writing and please rate my solution.
Nov 18, 2009 | Sony Televison & Video
Remote's will not work with my Sony STR DE-485
the ir feed receiver amplifier has failed a common sony fault on older units a fix is about $100.00 or use a repeater ir blaster from circuit city for $40 and try that you can return if no success the repeater eye covers the receivers originaland pumps up the out put into the unit
Sep 09, 2009 | Sony STR-DE485 Receiver
I have a STR DE 485 reciever. When I try and turn
unplug,leet capacitors discharge, check back of unit where speaker wire clips are to make sure there are no wire strands touching each other,check same thing @ speakers, try turning unit back on.
Aug 13, 2009 | Audio Players & Recorders
My reciever does not work
Power Amp IC gone in your set, replace it.
Jul 30, 2008 | Sony STR-DE575 Receiver
Feb 24, 2008 | Sony STR-DE875 Receiver
Sony STR-DE485 Receiver Logo
62 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
