Question about Honda 98 99 Accord Alternator Cpe 2 Dr 3.0l 6 Cyl
My car will crank and it runs great but it cuts off going down the road. the only way to crank it back is by taking the out and putting it back in a few times. does this have anything to do with the s
I am afraid it is going to get me killed! i can be running 65 miles an hour and it just shuts off. help me
    Habit-Forming:
  • 72 Answers
The ignition switch is a known problem on this car. Honda recalled them, get your VIN handy and call the local Dealership to see if your car is eligible for the recall. Even if the recall has been done, the upgraded switches may eventually go bad also. It's not really a hard job
The other common problem is the PGMFI relay, it is an electronic relay under the dash that powers the fuel pump. If you have a way to test fuel pressure when the problem happens, you could verify if it is the problem
Posted on May 12, 2014
I have a 1986 for ranger this happens very regular now need help asap I can crank it up and it will crank fine most time till this happens going down road the truck will start to bog down you can let off...
If you have any rubber fuel lines in the fuel system, I would replace them. Over a period of time the insides of the hoses swell up and stop the fuel flow to the engine.
Jul 15, 2017 | Cars & Trucks
92 4Runner automatic, runs great, put in drive, start down the road and at about 1850rpms cuts off.
Things to check first are fuel pressure and spark. Rig up something you can watch during a driveability (road) test. if neither of the two quits working when the engine dies, check for correct ignition timing (and advance) and injector pulses at the injectors.since the engine idles, the problem is probably not a tired engine, but possibly a sketchy sensor (crankshaft or camshaft position), engine computer, or spark controller. Not so expensive to replace, but no fun to troubleshoot.
Jul 29, 2016 | 1992 Toyota 4Runner
Why does it shut off while underway?
1988. Start with the electrical plugs(corrosion). Ignition module, distributor, stuff like that.
Oct 31, 2015 | 1988 Ford F 150
Engine sputters when taking off and cuts off
Check the fuel pump , filter, throttle position sensor.
Mar 12, 2014 | Toyota Camry Cars & Trucks
1994 ford ranger runs fine until i go to town then just shuts down but will crank over and fuel is getting to it
check ignition pick up its in the distributor. its responsible for spark in the plugs
Dec 04, 2012 | 1988 Ford Ranger
My 1999 jeep will stop running while driving it
Hi, i have a 1999 jeep grand cherokee, 4.0 litre, had the same problem, quits running out of the blue, driving down the road, or sitting idling. starts right back up or takes some cranking to get it running. found out that the crankshaft position sensor was going bad, cost 40$ for the part, but had to have mechinac replace it due to it's location, hard to get at. jeep runs great now.
Jun 17, 2011 | 1999 Jeep Grand Cherokee
1997 Neon if the crank sensor was bad would the car just stop running when going down the street? Car run great when just sitting in yard but while going down road will cut off.replaced the following...
change the crankshaft sensor. it's located in the cylinder block, where the alternator is, above the oil filter. make sure the car is cool & raise the car on jackstands. go under the car & find the oil filter & right above it is the crankshaft sensor. take it out from the cylinder block & pull out the red stop clip. after that, pull out the sensor from the wire clip & install the new sensor. installation is reverse of removal. now your car shouldn't stop.
Feb 27, 2010 | 1997 Plymouth Neon
After I drive my jeep some, if it is somewhat warm or not cold weather, my jeep has a hard time starting. It may crank but run a little ways and cut off going down the road.I have had the coil, plugs, plug...
if it shuts off after running for a while and will not restart for about 10 min,a bad crank sensor will cause this. abad crank sensor will make car shut off and not restart for about 10 min. put a scanner on to make sure. a check engine light does not allways come on. if you do not have a scanner, any auto parts store will scan it for free.
Feb 27, 2010 | 1997 Jeep Grand Cherokee
Car cuts off going down the road, won't stay cranked
crank sensor or fuel pump call A MOBILE MECHANIC as its not the sort of thing thats easly diagnosed from a description sorry
Nov 03, 2008 | 1995 Mitsubishi Galant
Honda 98 99 Accord Alternator Cpe 2 Dr 3.0l 6 Cyl Logo
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
