Question about Canon imageRUNNER 1023iF Black and White Copier
How to reset a canon ir 1022i copier to the default settings
SOURCE: Canon ScanGear Ir - how to set defaults?
ScanGear won't run under Vista. The scanner works with other programs. (Twain works) ScanGear fails and Vista closes it.
Don
quantm@localnet.com
Posted on Jan 26, 2008
fer_nan_14
  • 76 Answers
SOURCE: copier model canon ir 2016 (down load stand by )
hi if yo have knowledge on electronics try to remove the boot rom and memory and let the machine for 10 minutes,then put it back the memory and boot rom,and turn on the machine.if the same thing try to update the firmware using sst
Posted on Mar 06, 2009
  • 118 Answers
SOURCE: canon imagerunner Ir c3200 total reset
On the Control panel press asterisk (with the head) next to ? mark the press the ID SYSTEM SETTING>NETWORK SETTING>TCP IP .you can reset or erase the IP Addres or if you know to go to service program :COPIER>FUNCTION>CLEAR> MN-CON then switch OFF and ON the machine it will restart and then the machine will asked to switch ON/OFF theunit then all are reset
Posted on Jun 22, 2009
  • 4090 Answers
SOURCE: Canon Pixma MP500 Reset PAGE SIZE to A4
Set up the parameters you want A4 Paper orientation etc then go to profiles in printing prefences and ADD to profile.. delete any others that preced this set of parameters
Please tae my help++++Thanks for using FIXYA
Posted on May 09, 2010
spinal
  • 287 Answers
SOURCE: I need to set a Canon IR 3025 so that the Scan
Hi fiona,
I am glad to help you.Press the "ADDITIONAL FUNCTIONS" button located to the right of the display. Select "communication settings". Now press "TX SETTINGS".Now press "common settings".Now press "Edit standard send settings". You will now see a screen that allows you to set the DPI value and file format.You will have drop down menus for each that allow you to change these settings. Once you have selected your preferred settings press the "OK" button located at the lower right. I have "FIXEDYA". :-) Rememeber, you can change these settings of a case per case basis on the main send srceen. Be well and smile when you get a chance.Please let "fixya" know I have helped. Thanx
Posted on Jan 24, 2011
How do i get the factory default setting for canon ir 6800?
Go to service and and clear the error
Asterisk * press
then press 2 & 8(Two buttons single time)
Again press Asterisk *
COPIER>FUNCTION>CLEAR>ERR
Then press ok an off the machine wait 1 minute and on the machine..
Jun 23, 2016 | Canon Office Equipment & Supplies
Canon ir c6800
not surprising..sounds like either your copier is needing some internal diagnostics service(read that digital control panel board) or it's just skipping, and needs to be reset to defaults..suggest you use a qualified Canon person locally on both of these items.
Apr 26, 2008 | Canon imageRUNNER C6800 Copier
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
Today I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution...
oday I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution for disable or reset the same.
Oct 23, 2010 | Canon iR 2022 Printer
RESET IR 2018 AS FACTORY DEFAULT
Additional Functions button>ID System Settings>Initilize All Data Setting tab. This may take a while to process do not power down during this time.
Sep 02, 2010 | Canon iR 2016i Black and White Copier
Canon IR3570 Factory reset
how to reset cannon ir 3570 photo copier
Apr 07, 2010 | Canon Office Equipment & Supplies
Tried the solution to set black as the default color on the Canon ir c3200 that was on your site, it says to set as B/W on screen, only gives Auto Color Select, Full Color and Black as choices. Says to go...
might be able to do this through your remote user interface {the copier ip address} go to internet expolrer and type the ip into the address bar and look around for settings under additional funtions
Mar 26, 2010 | Canon imageRUNNER C3200 Copier
I have proplem in canon ir 2020
Under service mode *28* find the clear all and OK, after that you shouldnt have any pass required, but you need to set the IPadress, and your preferd sets.
Apr 05, 2009 | Canon iR 2020i Laser Printer
Don
quantm@localnet.com
Sep 21, 2007 | Canon imageRUNNER 1023N Black and White...
Canon imageRUNNER 1023iF Black and White Copier Logo
76 people viewed this question
old marine
old marine
