Question about Brother DCPJ315W AllInOne Inkjet Printer
Error code unable to print 73 on Brother DCP-J315W
Mix-it-up
  • 832 Answers
SOURCE: Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
Posted on Mar 29, 2008
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
  • 525 Answers
SOURCE: clean unable 46 error on dcp 135c brother printer
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on Jan 23, 2011
SOURCE: brother dcp-165c print unable 50
how ca n i fix my brother dcp 195 c unable 50?
Posted on Jun 07, 2011
kong_chenmin
SOURCE: UNABLE TO INIT 4F BROTHER DCP-J125
my brother printer when on the screen show unable to print 4f
model printer brother dcp-j125 how to solve the problem ?
Posted on Aug 31, 2012
BROTHER DCP J140 W UNABLE TO PRINT ERROR 73
Hello!
Please find attached a manual to this printer.
Hope the "Troubleshooting" part will help you.
https://manualsbrain.com/en/manuals/1228133/?page=42
Nov 04, 2017 | Brother Office Equipment & Supplies
Paper jam unable to print print 73 error how to solve it
I have same problem, the message make me wonder. I am very sure there is no paper tears in the printer. But then i have the answer from internet. I hope this answer can solve your problem too.
First shutdown your printer and open printer cover and find something like ribbon plastic transparant. becareful,clean that gently use wipe tissue or alcohol tissue. dont touch with your finger. hopefully it can solve your problem.
Oct 03, 2016 | Brother DCP-J315W Inkjet Multifunction...
How do I fix the absorber full on brother printer DCP-J315W?
go to service mode by pressing *2864 then appear on screen mentainance press 80.then find purge,then after you find press 2783.then exit by press 99.
Aug 04, 2016 | Brother DCP-J315W Inkjet Multifunction...
Unable init. 50 on my Brother DCP-J315w ...what should i do
Any failure to initialise, print, clean error report usually indicates the waste ink chamber is full and the purge count has maxed out. You can remove the waste ink chamber, clean and replace the pads and refit it but seriously time consuming and messy. You should try the purge count reset first (do google search) eg this one
http://ref.topictimes.com/videos/tech/how-to-reset-purge-counter-on-brother-dcp-j315w-printer-full-1NzJwuCpVOc.html
If that works, you can keep using it but should clean the waste chamber. Or save the hassle and just buy a new machine :-)
Jan 05, 2015 | Brother DCP-J315W Inkjet Multifunction...
I've been trying to use ocr on my Brother DCP-J315W and I get this error message: "Unable to write the file to Destination Folder. Please make sure that you have correct permissions to write to th
Where is the destination folder located is it windows .If Windows
Open file Explore (right click on Start icon select File explorer or explore) Right Click on Folder and check sharing permissions and allowed users.
Jan 03, 2015 | Brother DCP-J315W Inkjet Multifunction...
Brother dcp-j125 shows unable to print 73
'unable to print 73' is a Printhead error..
Usually the printhead is an expensive part around $80 to $110, and you will need a full set of cartridges to prime the new printhead..
Sorry to say that this repair is not normally economical to go ahead with.
Oct 15, 2014 | Brother DCP Office Equipment & Supplies
Brother DCP-9010cn is showing Unable to print code 73
The error code 73 means that you have a paper jam or a paper sensor problem.
here are a list of all the codes for brother printers:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000068/faq000168_005.html?reg=us&c=us&lang=en&prod=mfc5490cn_all
To troubleshoot paper jams go here:
http://www.manualslib.com/manual/355700/Brother-Mfc-9010cn.html?page=78#manual
If its not a paper jam you will need to call brother customer service as it may need a sensor part.
1-877-BROTHER (877-276-8437)
Mar 14, 2014 | Office Equipment & Supplies
Brother DCP-J125 unable print 73
unable to print 73 brother printer dcp-j125
Mar 29, 2013 | Brother DCP-J125
BROTHER DCP-J315W UNABLE TO PRINT.
This error means that the head drive voltage dropped severely. You should try and have it fixed or even consider buying a new printer.
I really recommend you downloading this great manual. If you have any problems with this particular model, this manual will probably help you. Good luck! :)
Dec 19, 2012 | Brother DCPJ315W AllInOne Inkjet Printer
Brother DCPJ315W AllInOne Inkjet Printer Logo
358 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
