Question about Toshiba 27A44 27" TV
Can the input method be changed on toshiba 27a44 without the remote?
  • 8457 Answers
SOURCE: How can I use the input on my toshiba TV without a remote?
Press the UP/DOWN channels buttons u well get a couples channels,than u will get the input, to use for input divices.If ur tv don't have the menu button on the front pannel of the tv.
Posted on Aug 28, 2009
  • 8457 Answers
SOURCE: I have a Toshiba 24af42 with no remote.
Try this website 1-800-remotes Factory original u can buy an original remote,tries Channels up or down couple times u should get in the input 1 or 2.
Posted on Oct 22, 2009
  • 5341 Answers
SOURCE: Can't change input source without
Unfortunately, this is a limitation of the TV and its programming. (There is no TV/Video button on the TV itself and no route to change the source in the menu.) You can get an exact replacement remote for the 30HF84 from remotes.com: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=30HF84&uuid=13052406603210 .
You can probably find a universal remote that can match the feature. The lowest end remotes don't have an Input or Source button. The higher end ones frequently do. You may need to try multiple codes for Toshiba TVs to get one that lets this button work. The remotes that can be programmed via a USB connection to a computer will be the fastest to set up for your TV. (Based on the age of the TV, I don't think you will have problems with the code not being in a remote unless it has been sitting on a shelf for a long time.)
I hope this helps.
Posted on May 12, 2011
  • 520 Answers
SOURCE: HOW DO I CHANGE THE
Here's the link to the manual for the Toshiba 27DF46 tv.
http://www.tacp.toshiba.com/tacpassets-images/models/27df46/docs/27df46_om_e.pdf
I hope this is helpful to you.
Bobya.
Posted on Jun 09, 2011
AJIN G
  • 6694 Answers
SOURCE: how do i change my
hi,
You should need the remote to access the AV mode. Try to purchse any universal remote, which you can configure for your TV if the Orginal remote is not avilable.
ok
Posted on Jul 07, 2011
How to put my toshiba 27A44 model into video without remote
Without a remote control, you can't select its inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Nov 03, 2016 | Toshiba 27A44 27" TV
Remote
Is this the original tv remote? What exactly do you need to reprogram?
Thanks,
Lee
Sep 01, 2008 | Toshiba 27A44 27" TV
I have a toshiba model 27a44 and have lost the factory remote.is there any way to change from cable to antenna.
If there is a 'menu' button on its front panel, you can enter its menu option, and surf through to select the input window and can change the input you want to. If there is no Menu button, there is no other way. You must have the remote control to select the inputs.
Jul 13, 2012 | Televison & Video
Toshiba 27A41 27" TV Remote is lost. Need to change the input. Can I do this using the buttons on the TV? Can I program my DirectTV remote to change the input?
You can't chage it with your Direct TV remote control. If there is menu button in front of the tv, just go through the menu, and see the vedio options. From there you can change the input selection. If there is no menu button, you can't do anything without the help of remote control handset.
Oct 15, 2010 | Toshiba 27A41 27" TV
I have been struggling to get the tv to move to the correct input when I switch from watching TV with Tivo to watching a DVD. I thought I'd made the correct selections, but end up either having to use the...
There are 5 types of input switching methods that you can come accross for each device. In the Software is says there is certain input switching methods that go with certain manufacturers - This is NOT the case. The following is the list of all the inputs:
1) Toggle (Method 1): You only use one button on your original remote to cycle through a set of inputs.
2) Discrete (Method 2): You have multiple buttons on your original remote where each button goes to a particular input and stays there, no matter how many times you press this button.
3) Menu Toggle (Method 3): A menu pulls up where you can scroll through the set of inputs and select which input you would like.
4) Menu Discrete (Method 4): A menu is pulled up where you use another set of numbers to select which input you would like. (you do not cycle through each input)
5) Multi Method (Method 5): A combination of any of the above. This can also mean that you have multiples of one of the above input switching methods.
Make sure you follow through the prompts for them but the Method 5 - you would have to contact Logitech Directly to get it added!
Jan 18, 2010 | Logitech Harmony 890 Universal Remote
I have a Toshiba 24af42 with no remote. I am trying to change the input, but without a remote I cannot figure out how to change it. I have tried a universal remote which works for other functions, but not...
Oct 22, 2009 | Toshiba 24AF42 24" TV
You can change your inputs by pressing the menu button on the panel of your television.
Aug 07, 2009 | Toshiba 14AF44 14" TV
Dont have a remote
Get a universal remote control. I have used several "One For All" brand remotes and they are very dependable. (Note: Big Lots usually carries some remotes at much better prices.)
Sep 30, 2008 | Toshiba 27A44 27" TV
I have a 27 toshiba and a rca universal remote but no code
Select code search instructions and you will be right!!
Dec 11, 2007 | Toshiba 27A44 27" TV
Toshiba 27A44 27" TV Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
