Question about Craftsman 2500 PSI Briggs & Stratton Powered Pressure Washer
Motor shuts off when wand is pressed - Craftsman 2500 PSI Briggs & Stratton Powered Pressure Washer
Husky 1800 Pressure Washer motor will not turn off when wand trigger is released
I think you have one of two things going on hear, an overpressure problem or a carburetor issue with the engine.
Jul 25, 2017 | Husky Garden
Pressure washer will not shut off when water trigger on wand is released
Sharon, you first should make sure you have no connection/leaks any where. There is a pressure switch inside the pump, which controls when the motor turns on and off. Leaks in pressure causes the pressure switch to activate the motor. Leaks are the biggest contributor to a cycling machine. If no leaks, the pressure switch is defective. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Karcher North America Home Garden Online Help
Frequently Asked Questions about Pressure Washers
Common Pressure Washer Repair Problems Pressure Cleaned
May 18, 2016 | Garden
There seems to be a short between the canister and the extension wand hookup. Right at the plug between located at the front of the canister and where the extension wand plugs in. When you rotate the...
Well, Anthony, considering as how I have no idea of what brand, make, model or color your vac is, I can't make much of a guess as to why it doesn't work. We'd need more info if you want to log back on at a later date, such as brand, model, maybe even a picture of the unit so we could see just where your problem might be.
Oct 22, 2013 | Vacuums
Motor pulsates
Hi there, it's Jack at Dyson.
If your DC44 Animal makes a pulsating noise then shuts off, it's very likely there is a blockage in the floor tool, wand or bin inlet. It's easy to check for this - just follow the steps in our Support guide:
http://www.dyson.co.uk/support/dc44/dc44-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual-dc44/no-resolved-redirect-to-check-the-wand/check-wand
It's also a good idea to wash the filter as shown in the video below - this should be done at least once a month in normal use. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
I'm confident that following these steps shown will resolve the issue, but please get in touch if you'd like further assistance - you can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US)
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 03, 2013 | Dyson Animal Bagless Cordless Hand Vacuum,...
Dirt devil canister power wand wont work
first find and locate belt if in good shape prolly aint bad and may be motor lock up
Nov 11, 2012 | Dirt Devil Vision Cyclonic Canister...
The motorized wand attachment keeps shutting down after 10 to 15 seconds after pushing the red reset button. I've thoroughly cleaned dirt/debris from around motor. Do I need a new reset switch? Thanks,...
either the reset is bad or the motor is drawing too many amps and tripping the reset. Do you have an amp meter? Check the amps being pulled by the wand attatchment against the load recommended by the manufature, this is usually located on a plate somewhere either on the wand or the canister.
Nov 24, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Shuts off when high pressure wand is attached
Hi Brian. Welcome to FixYa I am Kelly. This sounds as if the bypass / unloader valve is stuck in place and the pump id dead heading causing the unit to shut off. (There is most likely some corrosion in the unloader / bypassy valve assy / housing. What you can try is pouring at least 3 oz of oil into the water inlet assy and briefly.... like VERY briefly switch the unit on then back off. Then let it sit over night. The next day connect everything for normal use then turn the unit on again briefly. Use a bucket to PURGE the oil that you put through the system by squeezing the wand Power SW Off until the oil purges. Then switch the unit on and rapidly trip the trigger at 0.5 sec intervals or less. If it trips off wait 5 mins and try it again. Do the rapidly tripping the trigger on the wand routine for about 20 seconds. Your forcing the bypass unloader valve to cycle trying to clear out any debris / corrosion.
This works often and well. There are exceptions. Hopefully it will work for you.
Thanks for using FixYa.
Kelly
May 07, 2010 | McCulloch FHH18A Electric Pressure Washer
Windsor Sensor Vacuum
Sounds like you have a clog, either in the hose, or the inlet down at the bottom. When there is a clog, the red light will come on and may also shut down to protect the motor.
Nov 19, 2007 | Vacuums
Craftsman 2500 PSI Briggs & Stratton Powered Pressure Washer Logo
29 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
