Question about Video Game Consoles & Games
Mode Not Supported, IN: 64. 1 KHZ, V: 60. 1HZ
I installed "Midevil Heros" and I get this error. I changed my resolution several times but nothing works. I have a 32 bit system with Name NVIDIA GeForce 9500 GT PNP Device ID PCI\VEN_10DE&DEV_0640&SUBSYS_C9533842&REV_A1\4&2E5EAC9&0&0008 Adapter Type GeForce 9500 GT, NVIDIA compatible Adapter Description NVIDIA GeForce 9500 GT Adapter RAM 512.00 MB (536,870,912 bytes) Installed Drivers nv4_disp.dll Driver Version INF File oem23.inf (Section005 section) Color Planes 1 Color Table Entries 4294967296 Resolution 1280 x 768 x 60 hertz Bits/Pixel 32 Memory Address 0xFD000000-0xFDFFFFFF Memory Address 0xD0000000-0xDFFFFFFF Memory Address 0xFA000000-0xFEAFFFFF I/O Port 0x0000DC00-0x0000DC7F IRQ Channel IRQ 16 I/O Port 0x000003B0-0x000003BB I/O Port 0x000003C0-0x000003DF Memory Address 0xA0000-0xBFFFF Driver c:\windows\system32\drivers\nv4_mini.sys (, 10.51 MB (11,015,392 bytes), 12/27/2013 12:09 PM)
3 Suggested Answers
SOURCE: Would like help with what the optimal gaming settings are
Got free help somewhere else and problem solved
Posted on Nov 12, 2008
  • 26 Answers
SOURCE: Rainbow six vegas 2 running
i had the same problem. First, try downloading any patches that maybe be new, they can help.
then once in the game menu, go to the options and decrease the visual effects and graphics. they made this 2nd game to run in defalt mode with HIGH graphic computers, but if you just lower things to 800x600 and then set things to low, the gaame should run better, wont be perfect, but you will be able to play it with out getting mad at
Posted on Sep 27, 2010
Input not supported acer x193w
Hello Shaul
1) Change to Plug and Play monitor driver
2) try changing the screen resolution on the PC, and driver.
3) try changing to 60Hz the refresh rate of the monitor on driver section or options on the monitor driver.
Apr 05, 2016 | Acer X193W LCD Monitor
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
Out of range 64.0 KHz / 60 HZ
It might be because of wrong screen resolution. This problem can occur because of hardware as well as software change.
To rectify this issue you will have to set your screen resolution to lowest visual settings. For this purpose you can try restarting your PC to safe mode and then modify your screen resolution.
Sometimes setting your monitor to factory defaults can also rectify this issue.
You can view for more information.
I hope this would be of some help.
Feb 05, 2012 | LG Flatron L1515S 15" LCD Monitor
19LVWK (Black) LCD Monitor: input not supported -- I have tried F8,changing th...
No bent pins on the VGA cable? Bootup in safe mode, select VGA support and set the PC video resolution to he native resolution of this monitor, reboot.
May 18, 2010 | AOC 19LVWK LCD Monitor
When booting up my windows is loading and then my screen goes black and come up with an error: recomended resolution is 1280x1024... how do I fix this?
Most probably your computer has a higher resolution or refresh frequencies set in Desktop Settings than supported by the monitor. It might be also, that you have previously installed a monitor driver for a different monitor model, and the computer is using resolutions and frequencies supported by that previous monitor, with which your new one can't cope.
The solution would be to boot the computer in safe mode (hit F8 key when the computer is starting, you can hit it a couple of times, until you see a menu; choose "Safe Mode" and hit Enter).
Go to Desktop Properties, change to Settings tab, and click "Advanced" button. In the new window choose "Monitor" tab and change the monitor to "Plug and Play monitor". Click OK to accept the settings and close both windows.
Now reboot the computer - it should start with a rather low resolution, but the picture should be visible. Now you have to go to your Desktop Settings again, Advanced tab, and move the resolution slider to position 1280x1024. Accept and enjoy.
If the computer still doesn't boot, go to safe mode again, go to Control Panel, System, Hardware, Device Manager, drill down to Monitors, and delete all the monitor devices installed. After a reboot, system should start up and find new hardware, and install Plug and Play monitor. Set the optimum resolution of 1280x1024 as written before.
Nov 18, 2009 | Samsung SyncMaster 710VT TFT LCD Monitor
Monitor went black after changing resolution
Reboot you computer and spam F8 until you get the option to boot in safe mode then choose VGA safe mode or safe mode with network is fine also and change the resolution back
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
Screeen went blank after changing resolution and hz appeared
refresh set to high boot safe mode change settings.
this has worked for me and XP.
TV won't accept monitor input
Try changing your computers resolution to something much lower. Mode Not Supported is usually an error regarding the Display Resolution of the video card being set higher than the monitor is capable of handling.
Aug 14, 2008 | Samsung SlimFit TX-S3082WH 30" TV
Proview PRO576 error message "mode not supported" and will show nothing else
Okay, we got a fix by having another monitor hooked up to our computer and going in to display and changing the display settings to a lower setting. The screen resolution - turn it to lower - I guess somehow - the setting was too high for our monitor. Don't know how it changed itself though. Anyway, change it to a lower resolution then re-hook up your monitor and see if it works. The reslution can be pushed back up until you notice the problem again.
Mar 05, 2008 | Proview PRO576 15 in. Flat Panel LCD...
Video Game Consoles & Games Logo
48 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
