Question about Franke Saphira Espresso & Coffee Maker
Drawer missing ive changed the board the switch but still get the same message so im not sure what else to suggest
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
Check that the pin on the drawer cover is not broken.This pin will activate the micro switch that tells drawer is in place.
Posted on Jul 09, 2014
Drawer missing message showing, ive cleaned both sets of contacts, what is the location of the drawer micro switch. Many thanks
If ther is two pens that's men's it's wired not a microswich
So look where the pens attached to the machine then Mack sure the wires are attached bouth from inside the machine
Apr 17, 2015 | Coffee Makers & Espresso Machines
E14 message on whirlpool washing machine/dryer
To prevent the washer from operating while the detergent drawer is open your machine has what is called a "reed switch". The reed switch is controlled by this magnet, so that when the drawer is closed the magnet causes the reed switch to close and this tells the control board to go ahead and run the machine.
Your error message is telling you the reed switch it not working, so they want you to check the magnet to make sure it is still in place and is working.
Dec 05, 2012 | Whirlpool Washing Machines
E14 problem message
The dregs drawer missing indicator on, unit won't work.
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
There is a micro switch whit an arm the hangs down in the slot on the side of the machine. Make sure that you have the arm for the micro switch.
Jan 11, 2010 | Saeco Magic De Luxe Espresso Machine
Error message: Dregdraw miss
which machine do you have. The drawer is not hitting the micro-switch try puttin a piece or 2 of tape on the tab on the side of the dredge drawer
Nov 20, 2009 | Saeco Coffee Makers & Espresso Machines
FI error message from both drawers. We had a
F1 indicates flood fault. There is no reset, machine thinks it has flooded. If machine was running OK until electrical storm, then it could have shorted the mains filter control board (DD603 models-this mains filter board also acts as flood switch), although this is unlikely to have shorted. More common is dishwasher has had a leak causing F1 fault, or corrosion on mains filter board . Open bottom drawer and shine torch underneath to see if there is any water in the base of the cabinet- if yes, machine has leaked and activated flood switch. If not, flood switch board may be faulty.
Unfortunately, access to this flood switch control is permitted only by removal of the bottom drawer- recommend calling technician unless very keen!! If keen, read on!!
-To remove drawer- there is a tag at the bottom front on each side of drawer when you open it -just below the round plastic plug. You need to push this tag in and slide backwards on each side, then drawer will lift out-Careful as hoses and wiring still attached, but long enough to allow access. Mains filter control board is located under plastic cover at left rear- press tag on plastic cover and slide to the right- you will now see small electronic board. This is the mains filter board that doubles as the flood switch. It is held in place by 1 screw- you need to remove wires from board before removing it). Check circuit board for corrosion or evidence of short circuit- if so, replace circuit board.
Good luck, but advise seeking professional help unless you very confident!!
Aug 10, 2009 | Fisher and Paykel Dishwashers
Doulbe Draw model receiving an F1 error message.
F1 indicates flood switch has been activated. I wouldn't advise you attempt repair on these drawers- they really require an expert to disassemble (I worked for F+P for 10 years!!). Depending on which model you have (DD603 or DD601v2), repair varies. 603 has a small circuit board that acts as flood switch- located in base beneath drawer- requires drawer to be removed for access. 601v2 model has polystyrene float that acts as flood switch-leaks usually caused by split lid seal(tricky to access- drawer has to be removed) In either case, a leak has occurred and activated flood switch. These drawers are very sensitive to detergents (don't use tablets!!), and the way they are loaded.
Would suggest you get service technician to remedy F1 fault
Aug 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dregdrawer Full
There is no 'sensor' for this, an internal counter resets when you remove the drawer with the machine switched on and the "Dreg drawer Full" message displayed.
Make sure the machine displays this message "DREG DRAWER FULL" Do NOT turn off the machine, Pull out the drawer that the used grinds are dumped in(you have to remove the drip tray 1st) Check display - it should read "DREG DRAWER MISSING" If the display message is correct, wait 10 seconds then replace the drewer.
Message should be cleared.
If the "dreg drawer missing" does not display, you do have a bad sensor and machine needs to be serviced.
Nov 19, 2008 | Saeco Royal Digital Plus Coffee...
"ink cannot be correctly detected" error U130
Hold down the "Stop/Reset" button for 5 seconds and it dismissed the first message, but then there was another for a different cartridge, etc. Eventually I got it to work.
Jul 26, 2007 | Canon Pixma MP800 All-In-One InkJet...
Franke Saphira Espresso & Coffee Maker Logo
50 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
frankecoffee
Level 1 Expert
Jay Finke
Jay Finke
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
