Question about Xerox DocuColor 12 Printer
Error code 8-139
No paper inside and same error on the TV
  • 3 Answers
The sensor detects the paper tray 5 has an actuator which must be broken, this is on the top of that lift the tray when paper is jammed.
Posted on May 28, 2014
Canon Pixma MG 3200 is showing error code 02. I have reloaded the paper 20 times - no joy - stilll error code 02 - Any ideas?
remove jammed paper stuck inside the printer slowly, and u should be up to go
N.B do not pull the paper out forcibly from the front tray as this may cause serious damage
if u dont find any paper inside try to clean what ever it stuck inside the printer and be careful
Mar 22, 2017 | Canon Office Equipment & Supplies
Had paper jam which have cleared. Getting support code 6001 saying turn off and restart which we have done but still keeps coming up with same error
The 6001 error is a generic internal error code. Unfortunately, it could mean one of many things. To resolve the 6001 error, please follow the following steps:
1. Turn off the printer and disconnect the power cord and USB cable.
2. Remove paper from the automatic sheet feeder (in the back).
3. Gently pull jammed paper out, if any.
3-1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
3-2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
4. If the paper tears and a piece of that remains inside the printer, open the printer cover and remove the paper from inside the printer.
5. Check ASF with a bright light to check for obstructions. Remove any if found.
6. Open the rear cover to check if the paper is jammed.
7. Pull out the cassette and check if the paper is jammed inside the cassette area.
8. Load paper back into the ASF or cassette.
9. Reconnect the power cord, turn on the printer and confirm that the Alarm light is off. (If there was any jammed paper remaining in the printer, the paper may be automatically ejected.)
Aug 24, 2016 | Office Equipment & Supplies
How to fix code 6000 mx922
The 6000 error is a generic internal error code. Unfortunately, it could mean one of many things. To resolve the 6001 error, please follow the following steps:
If the above procedure does not resolve the error, the unit would require service:http://www.usa.canon.com/cusa/page.action
May 03, 2014 | Canon Pixma MX922
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Says paper jam, worked fine yesterday but there is no paper even in the machine...
Those errors that deal with paper jams. An error code "6A80" can either represent a sheet feeder error or a debugging unit. This means that there may be scattered bits of paper or other debris trapped inside the unit itself. The potential for this error is high; when the paper is removed from a jammed feeder, bits are prone to fall off and cause this error code. The user must inspect the inside of the printer thoroughly. This error can result from problems with the unit serving or the electronic card; however, the most likely cause is debris caught inside the printer interfering with the printer's operation.
Nov 09, 2010 | Canon PIXMA MX340 Wireless Office...
047-320 error
When we had this error code, we tried all the doors. No luck. I checked the fuser and there was a piece of paper jammed inside. We now know that we need a new fuser before the error message will go away, but it was the paper jam inside the fuser that caused the fault code. The fuser simply got too hot with the paper in there and burned up, apparently.
Dec 30, 2009 | Xerox Office Equipment & Supplies
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Need trouble code for selphy ds810 trouble code is 6000 or where can i get all of them
Error 6000 is a paper feed error, something may be inside stopping the feed rollers from turning, otherwise it could be ink on the paper feed sensors. If you can't see something inside like a paper clip or something else that doesn't belong, I would reccomend shop repair.
Jun 22, 2009 | Canon SELPHY DS810 InkJet Photo Printer
Error 1300 keeps coming up on myh Canon Pixma IP4000 although there's no paper?
Dear pants53,
Code 1300 indicates that paper jam error occurs. First, check whether any broken paper inside the paper path, remove it then press Resume/Cancel button. If problem still persist, means paper sensor error or paper sensor cam is broken. If it so, then I suggest you bring your printer to nearest service center.
Regards,
Nov 08, 2008 | Office Equipment & Supplies
Xerox DocuColor 12 Printer Logo
73 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
