Question about HP LaserJet 5200tn Printer
Printing blank pages 5200
I have an HP LaserJet 5200tn printer that is only about six to eight months old. It just started to print out pages that are warm, but blank. I checked the computer and cartridge and everything else seems to be alright. Research seems to point to the Fuser. Does any think I am on the right track?
jaylex
  • 417 Answers
SOURCE: HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Posted on Jan 28, 2008
SOURCE: printer prints blank pages
Check to make sure the photoconductor grounding spring on the left hand side of printer in the toner slide black plastic has not popped out of it's slot. Just fixed one a couple of days ago doing this.
Posted on Feb 03, 2008
SOURCE: HP Laserjet 1020 - prints blank documents
in my printer the resistor R348 on the motherboard printer was broken. The value that must have is 10 ohms. I have changed and the printer has resumed work.
Posted on Dec 07, 2008
SOURCE: HP LaserJet 1022 Printing Blank Pages
I had this same issue, are you able to print from the printer's internal test feature?  If so try turning the power off for at least 10 seconds.  This is just at temporary fix I am still looking for a permanent fix that does not involve replacing the printer.
Posted on Feb 13, 2009
SOURCE: Error 13.20.00 on HP laserjet 5200 jam inside top
This is a common issue and most times a bear to repair. There is a sensor flag mounted on the paper feed assembly behind tray 1 which has a habit of either coming off or the spring which moves it back a forth comes out of its holder. In any case it is one of the worst repairs you have to do. Many items have to come off to get to it and getting that flag and spring on correctly even with the instructions is difficult. Usually what will happen is you get the 13.20.00 error on power up with no motor movement and when you open and close the top cover, the motor will move but the same error reappears. If you are lucky it is just a case of a shred of paper blocking the sensor flag from moving and worst case of the flag having come off. You will need the service manual and check the removal and replacment section on the paper feed assembly and play close attention to the 3rd page.
sometimes this error also appears if a wrong fuser is installed in ur printer that is not ur model number.... have it checked
thank you have a nice day
Posted on Aug 10, 2009
Testimonial: "Good answers - unfortunately still no closer to solving the problem."
My printer prints blank pages
Delete old driver and then reinstall. Can you do a self test, hold the start button and hold five seconds. Good luck.
Aug 27, 2012 | HP "laserjet p2035 printer"
HP laserjet 5200 printer taking too much time to print a page..
HP 5200 prints 35 pages/minute, however, system configuration and software reduces print speed. So, If there are no changes in those parameters, you're document is too complex to print quickly.
Try to send a test or a text page to calculate the difference.
Also bare in mind that first page takes longer to print due to printer heat-up procedure.
Nov 09, 2010 | HP LaserJet 5200 Printer
While printing there is a noise
Maybe go to a local store and try a display model of the same printer and see if it makes identical sound. If it doesn't make the same, contact whoever you bought from to see about warranty or refund. Can also contact HP customer service for advice.
Sep 16, 2009 | HP LaserJet 5200tn Printer
Hp laserjet 5200tn no display
Is it in sleep mode, or is this some other issue? Scroll down to the resets submenu in this article .
In fact, you might try simply resetting the printer, to try and clear the memory, but if you choose to do so, make sure you have printed a configuration page beforehand so you have all the info needed to set it up again.
Or you could try an online diagnostic session with HP, available here.
Finally, your model home support page with other troubleshooting options here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 04, 2009 | HP LaserJet 5200tn Printer
Dark printout
Have you tried a different toner cart? Common problem with reman carts. If that fails again, check the silver spring loaded contacts inside on the left and right that contacts the toner cart. Make sure they are not stuck inside the frame and that they are springy.
Aug 04, 2009 | HP LaserJet 5200tn Printer
My HP color laserjet 4500 is printing only blank pages
This is usually the Transfer kit, but if the image drum or one of the power supplies goes bad, that can also give blank pages. The Drum problem for no print is usually a grounding/connection problem. Power Supplies are a complicated repair, but these printers aren't too bad to work on. You can buy good used one's fairly cheap on ebay, though. Should consider going to a later model CLJ if you replace with a used, though.
Apr 07, 2009 | HP LaserJet 4500 Printer
Hp 1320 prints blank pages
My HP 1320 printer is printing blank pages and it will not even print test pages etc
Nov 03, 2008 | HP LaserJet 1320 Printer
Aug 08, 2008 | HP LaserJet 1022 Printer
HP LaserJet 5200tn Printer Logo
69 people viewed this question
Seeker5211
Seeker5211
