Question about Ovens
Caloric wall oven removal of broiler door - Ovens
ginko
  • 19396 Answers
SOURCE: replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Posted on Apr 08, 2009
  • 93 Answers
SOURCE: I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Posted on Sep 12, 2009
  • 1891 Answers
SOURCE: I have a 31-year old Caloric gas wall oven (Model
first turn the gas off at the meter/ a oven this old may not have a shut off in the back. then you can remove the oven safely/ the line in back will hook to 1/2in or 3/4 pipe stub. . if you have a shut off in the back turn it off and reconnect new range to it . and if not make shure you put one in .. mm
Posted on Nov 22, 2009
SOURCE: I have a caloric heritage series gas stove in
We replaced the igniter which I bought from the appliance repair service. We now have a working oven.
Thankyou for responding to my email.
Cheryli
Posted on Jan 04, 2010
SOURCE: Looking for a Oven knob for the Caloric Presige
http://www.appliancepartspros.com/partsearch/
or
http://www.expertappliance.com/caloric-stove-parts.html
Posted on Aug 22, 2010
Oven element good but does not heat even though broil workes with temp sensor
Hello Billy;
My name is Peter. I am a retired field service appliance technician.
First, your broiler is not connected to your oven thermocouple (Temperature sensor). When you turn on your broiler full load amps go into the broiler element with no adjustment.
There are only three components that control your oven operation:
1.) Heater Element - Inspect your heating element for cracks, sparking or corrosion on the two contacts on the back wall.
2.) Thermocouple - This is a temperature sensor inside your oven. It is about the diameter of a coat hanger wire. Either it comes straight out of the back upper wall or is mounted on the back wall.
It is disconnected and removed from the upper back of the oven.
You should get a meter reading of 1000-1100 Ohms if the component is good.
3.) Oven Control - The control communicates with the thermocouple and increases or decreases the amps to the oven heating element. If the thermocouple is good then the oven control needs to be replaced.
If in unsure, replace them both.
Recently, I replace a digital oven control for a friend. Sears wanted $256.00 for the control. I purchased a remanufactured oven control over the internet for $30.00.
Get the oven model number off your oven. It is on a metal tag on the face of the oven after you open the door.
Go into the following website. Put in your oven model number (on the left). You will get diagrams and parts part numbers. Record these numbers for the above components. Put the part number in your computer search engine and search best price.
CAUTION: If you replace a electrical control board GROUND YOURSELF by touching something that is bare metal. Static electricity will knock out a control board.
Water Filters Lawn Garden Appliance Parts
Jun 06, 2015 | Ovens
Have perfectly working Caloric Electric self-cleaning Wall oven and broiler EXCEPT oven light went out and when we went to replace it fabric around gasket was disintegrated. All we need is the fabric...
while i'm here , give the fabric a flame test with a torch or lighter, just to make sure. some are more flame resistant than others. should be listed on the fabric roll label. good luck again! also, some appliance stores may sell do-it-yourself heat gasket materials.
Nov 04, 2013 | Ovens
Trying to find piece of heat resistant fabric (don't know name - something like old asbestos) to replace degenerating fabric on light fixture gasket on otherwise perfectly working caloric electric wall...
If it would help you to find the model number, I would look for a way to remove the oven door. Usually there will be a release near the hinge bracket that you push in or push to the side to allow the bracket to release and you can remove the door to see the ID plate. Otherwise, I would suggest going to a wood stove dealer and looking at the door gasket material they have in stock. They usually have rolls of heat resistant gaskets for sealing doors and glass panels in wood stoves. Last idea would be exhaust gasket material available at Napa Auto parts. Good luck!!
I have a Caloric Heritage Series gas stove in which the oven will not light but the broiler does work. This stove has a analog clock and we have no idea what the model is. Please help us. Thank you,...
Cheryli
Dec 29, 2009 | Ovens
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
I have a 31-year old Caloric gas wall oven (Model RWD216) that finally died. I am ready to install a new unit, which means taking out the old Caloric. My question is, how do I unhook the gas line from...
Nov 22, 2009 | Ovens
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
or
Oct 18, 2009 | Ovens
Oven won't light.
Localwonder gave a more comprehensive answer, but I wanted to share my recent related experience too:
Same model: MGR5750BDW
Oven was not heating up, or would sometimes and not others. Broiler worked fine. The nice thing is that the broiler igniter and the oven igniter are the same part. So I swapped them until I could get a replacement part.
Before I did anything, I turned off the gas!
To take out the broiler igniter: there's one screw right near the front of the oven that holds the burner assembly in place. Remove that, gently pull the assembly off the gas nozzle off to the left. Then where the wires from the igniter go into the back wall, remove the screw that holds the little door, remove that little door, and then gently pull the wires through until the connector comes through the opening. I also found you can go behind the stove, remove the back panel (which is easy) and see the igniter's connector.
The oven one: remove the floor of the oven by lifting it at the back, and then lift it out towards the back of the oven. Then you can see the igniter at the back of the floor of the oven. remove the two mounting screws, and then gently pull the wires until the connector comes through the insulation.
The bad igniter looked like it had burned down to bare metal in a big patch...not sure if that's the actual problem, but in any event, I installed the good igniter in the bottom (gently pushing the reconnected connector through the insulation, and feeding as much of the wires down in there as well), and the bad igniter in the broiler position (since that was the easiest one to access and replace, it'll be easy enough to replace when I get the parts). Tested, and everything worked great. And I could watch the bad igniter light up, and never light, confirming that it was the igniter itself that was the problem.
The best part, for this stove anyway, -- the ONLY tool needed was a #2 phillips screwdriver. Really. All told, maybe an hour of work, nothing intense. And free -- so if they both worked, it would have spared me ordering a part that didn't need to be replaced!
Jul 22, 2009 | Maytag Amana 30 in. Electric Double Wall...
Ovens Logo
16 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
