-   I can't scan with my HP Color LaserJet 2840 with Photoshop Elements 6.
Says: Can't find a TWAIN-driver. Where do I find a Twaindriver?-   info762
Apr 25, 2008
-   I am unable to scan a picture -   skinsfan9113
Yes , also check to see how old your printer is first.
If it is new the Vista drivers may work, I say this because there is Vista 32 bit and 64 bit, compatibility issues.
If you are using XP, and the printer is old, you maybe in luck. Your original CD will work just install it and use the menu on your computer to scan the image.
If your printer is old and you have Vista, your software may not work.
You eventually will need to buy a newer fax machine with the latest drivers.
Don't forget, Windows 7 is going to be out soon. Most computers will be sold with Windows 7 loaded in them. Check to see if one of the system requirements on the new fax can use Windows 7 software.
Good luck.
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a...
(More)
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a very old printer ?
Thanks
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not...
(More)
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not necessary)for my home that at least does decent photos for my personal use. Any suggestions?
Ink system failure reported on HP D6160. Previously my yellow ink cartridge was reported as run out....
(More)
Ink system failure reported on HP D6160. Previously my yellow ink cartridge was reported as run out. I replaced with another (not hp due to cost)...probably a refilled one. Now have ink system failure. Could be air in system. How do I flush out?
the printer is connected to a home network that contains four computers. One acts as a server. I...
(More)
the printer is connected to a home network that contains four computers. One acts as a server. I used to be able to print with the printer from any computer. Now I cannot. The printer software is installed and was recently updated. I think something happened to the printer, because the only thing that reacts is the Photosmart express menue on the printer. I tried the color document I was trying to print on a USB key. it would not see it and could not print it.
Hi, my almost new Samsung 315 printer looks broken :( I wanted to print something off on a...
(More)
Hi, my almost new Samsung 315 printer looks broken :( I wanted to print something off on a transparency sheet and it never came out, looks like it melted inside. I wanted to print something on a paper afterwards and it stuck as well. I tried to clean the whole mess on the roll but couldn't get some bits so used tiny pliers to get the plastic and paper out. Unfortunately some scratches are done on the red rubber that covers the roll. I unscrewed the whole machine to get the smallest bits of plastic and asembled it back but it's still not working. I hope I removed all the mess from inside so what could be the problem now? Can't find any help online :(
