Question about Motorola AP 7161 Access Point
How do I fully reset my AP7161 - Motorola AP 7161 Access Point
  • Motorola Master
  • 3,320 Answers
LOST ROUTER LOGIN PASSWORD
If you have forgotten your personal router login password there is no way to recover it. You will have to reset the router. This means all the settings on the router will be reset to factory defaults. It also means that all your connected devices will need to be connected again with the new security information (WEP, WAP, etc,) . You will need the default admin login name and the default admin password. This can be found in the user guide that came with the router. This can usual be found online at the router manufacturers site.
There is usually a button or a switch hidden in a pinhole opening on the back of the router. Pressing and holding the switch for 10 seconds or so will cause the reset and usually the LEDs will flash and blink for several seconds as the router firmware sestets and clears out the old information.
If you are trying to get into someone else's router illegally there is no way to find out their login password.
For future reference, write the password down, or a hint at what the password is, on a piece of tape and secure it on the bottom of the router. I use my cell phone memo function to store all my passwords.
Posted on May 12, 2014
Testimonial: "Thing is pressing the Reset button doesn't do anything. I was trying that for about two hours withouth success."
  •  Mike M
    Mike M May 13, 2014
    The router has to be on. Press and hold the reset button. The LEDs should start to blink. Keep the button pressed until they stop.
How to reset windows on is 350 lexus 2007
(a) Turn the engine switch on (IG).
(b) Halfway open the power window by pressing the power window switch.
(c) Fully pull up the switch until the power window is fully closed and continue to hold the switch for approx. 1 second after the power window is fully closed.
(d) Check that the AUTO UP/DOWN function operates normally.
If the AUTO UP/DOWN function operates normally, reset operations have been completed at this time. If not normal, follow the steps below.
(1) Disconnect the negative battery terminal for 10 seconds.
(2) Connect the battery terminal.
(3) Turn the engine switch on (IG).
(4) Halfway open the power window by pressing the power window switch.
(5) If the AUTO UP/DOWN function operates normally, reset operations have been completed at this time.
(6) Turn the engine switch on (IG).
(7) Halfway open the power window by pressing the power window switch.
(8) Fully pull up the switch until the power window is fully closed and continue to hold the switch for approx. 12 seconds after the power window is fully closed.
(9) Check that the AUTO UP/DOWN function operates normally.
Feb 05, 2017 | 2007 Lexus IS 350
How do i reset my braun 5790 shaver.
Fully charge the unit then turn it on and let it run until the batteries are fully discharged....do this cycle a couple of times and it should reset the display to be accurate with the charge on the battery.
Dec 28, 2014 | Braun Health & Beauty
Fully reset samsung cdma mobile samsung sch-m369
i need to reset my samsung 8ph-m910
Oct 08, 2012 | Cell Phones
My Sony PRS600 does not fully charge. I had it
First, confirm whether you're using the AC-S5220EAC Adaptor to charge the Reader, as it's always recommended to use that one with the Sony Reader. However, you may also keep connected the Reader to the Computer for at least 4 hours to get it fully charged. If the issue still persist, perform a soft reset. To soft reset, please press the RESET button using a sharp-pointed object. Then, try charging it. That should resolve the issue.
Jan 26, 2010 | Sony Reader Touch PRS-600
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
How do I reset the "change oil soon" light on a 2005 Grand Prix?
Turn ignition fully on, without the engine running, press the acelerator fully down three times within five seconds.
anaanymous
Oct 11, 2008 | 1998 Pontiac Grand Prix
Reset check engine light
First of all, you should'nt do this unless you know what the problem is.. or what tripped it. I had this problem when my husband and I were replacing a head unit and disconnected the old head unit, a/c and other stuff then turn the car on. This made the light flash. The first time we took it in and got charged $50 to reset it. The second time we did this procedure and it worked.
ECU Resetting Procedures
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON.
A stop watch or an analog clock with a second’s needle will be useful.
Reset Check Engine Light Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 seconds.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
-Christine
May 15, 2008 | 2007 Nissan Murano SE
Motorola AP 7161 Access Point Logo
394 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
