Question about Samsung SF555P All-In-One Laser Printer
How I can makeprint through sidetray ?
How i can take print through side wise
  • Samsung Master
  • 1,087 Answers
Depends what software you are using. But if you use MS Office you go to the menu top of page left, and File, Page Setup, Paper Size, then click the button Landscape. That means the printer prints it 'sideways', long edge across the top. Most word processors use a similar system.
Posted on May 12, 2014
Change print size
just scale to a4 from print dialog box appear on right bottom side
other wise delete all prints and restart printer and computer then try again it comes to actual sizze
Jan 15, 2014 | Epson WorkForce WF-2530 All-in-One...
How to stop Lexmark C540dw printing instructions for two-sided printing
I had same issue. I checked two sided printing, but wanted it to take the paper back in to the printer automatically. I did not have the duplex option selected in properties and it was showing how to do it by feeding the pages manually. Go to printer properties and printer preferences and I think the tab labeled page layout, you may have to select the advanced button to find the 2-sided options for flipping short end or long end. (you want flip on long end if you want the top of page 2 to be on the opposite side of page one. Other wise, flip on short end will put the top of page 2 opposite from the bottom of page 1). however, AUTOMATIC 2-sided printing will not work unless your model has the duplex printing feature. In that case you just need to go to properties and un-check two sided printing and check one sided printing. That way it will not keep wasting paper and showing you how to do it manually. So you don't have to do it for each print job make sure you change it in printer preferences so it does not keep trying to do 2 sided printing. If there is a job you want to print 2 sided then just select it in properties for that particular print job.
Apr 29, 2012 | Lexmark C540DW Color Laser Printer
50.4 fuser error 4015 laserjet
Faulty fuser..Remove back tray, take out & resit fuser assembly properly, observe that fuser lock are clicked or not,if you feel seated properly, switch on and shoot print command.. If its printing well then you are in in safe side, other wise replace fuser assembly just little bit expensive...
Feb 02, 2012 | HP Office Equipment & Supplies
Hi. I have a Canon IR2018 printer in my office. Because I am eco-wise I would like to set it from single to double sided printing (I think that's the term for printing on both sides of the paper) but...
you can do so if your machine has a duplex unit attached.if it has a duplex unit then for printing you have to select 2 sided profile as default or for prints when u want double sided from you pc print software(canon) or the server if you have one .that way u will get all the prints in 2 sided. for copying u have to select 2 -2 sided by pressing the 2sided key on the console of the copier.then place the originals in the ADF and thats all
Jul 15, 2011 | Canon imageRUNNER 210S Copier
Error code 9-342 at start up of Dc 12 xerox printer/copier
change the IOT back side clutch that appear behind the back side of machine which rotates the ITO (black roller in main path of paper) just try with cleaing clutch other wise change it
and remove that IOT back side gear which rotate IOT black roller without that gear u can print
i solve my problem with this methods
Mar 28, 2010 | Xerox DocuColor 12 Printer
I need to print mailing labels imported from excel to word in columnar order instead of in order by rows across the page.
hi Samajane,
I understand the you excel file has data that is stored column wise. Well you can first convert the column wise data to row wise data and then import it to you word.
To convert the column wise data to row wise data.
1.Select the data in your worksheet.
2.Right Click -> Copy
3.Create a blank worksheet.
4.Goto Edit - > Paste Special
5.Check the Transponse Option
6.Press OK.
Now you have converted your column wise data to row wise data and now u can import it to your word and print mailing labels
Dec 14, 2009 | Microsoft Windows XP Professional
HP C4480 Won't Print Borderless
Most pix you shoot are not exactly 4x6 which will leave white edges top and bottom- Sides Try using the HP software- see if any difference Inkypete
Apr 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Color Printing Problem
Remove all ink cartridges and replace them securely in position.That may be the problem always.
Print nozzle check pattern.See for any missing patterns
Give a head cleaning
Again print nozzle check pattern.If it is ok leave it, other wise give a deep cleaning
  1. If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
  2. Atleast a multi colour( like your visiting card) page should be printed in a week time. other wise the ink may clog in the head.
Mar 29, 2008 | Canon Pixma MP500 All-In-One InkJet...
Samsung SF555P All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
