Question about Dryers
No power There is no power to my dryer I have changed the fuse and can't see anything wrong with any of the wires inside the dryer.
  • tasha
    tasha May 12, 2014
    at the minute but obviously i plugged it in then realised there was still no power
  • Jerry Mullins May 13, 2014
    Well if you have verified and know you have power going to the dryer it will be your start switch or your main control board, also could be the door switch that lets the dryer know the door is closed and safe to run. you will need a multimeter to check any of them. Good luck
Where is the thermo fuse in a electric whirlpool dryer 70 series
If the thermal fuse was blown the dryer would have no power to anything. it will act as if the wall plug is pulled. The fuse is located inside the dryer cabinet near the motor.
Jan 27, 2012 | Whirlpool Dryers
No heat when drying clothes
Hello there
Please investigate the following
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. you can test them with a meter usulaly tested between 20-40 ohms anything else means replace it Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 26, 2011 | Whirlpool AWZ7303 Electric Dryer
Dryer will not come on or anything.
Hello there:
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with:Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing.
Jul 06, 2010 | Maytag SDE3606A Electric Dryer
I bought a used dryer and went to change the plug in to a 4 prong went to plug it in and saw a spark dryer still not working what did I do wrong?I think I did it right, red wire white,and green and black...
The following link explains how to correctly install a 4 prong power cord (US Standard Electric Code) to your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference between a 3 and 4 prong configuration is the way the Neutral (White) and Ground (Green) wires are installed. In a 4-prong configuration these two wires are independent of each other. If you left the grounding ******** the terminal block (effectively grounding the neutral wire), or wired it incorrectly, you may have damaged the dryer.
Read through the link provided and double check your installation. If you're lucky, you may have just tripped a breaker at the distribution panel, or blown a fuse inside the dryer.
If you need further assistance, please post back with your brand name and model number so I can determine how your dryer is configured.
Jul 16, 2009 | Dryers
Dryer doesnt start, 600 series kenmore
Q - My dryer is dead, what could do that ?
A - Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
* If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first, then it is sometimes a good idea to replace the operating thermostat at the same time. This is a picture of -some- modern thermal fuses.
Door switch
Thermal fuse
Wiring
Apr 01, 2009 | Kenmore 63942 Dryer
LG Front loader Electric Dryer want heat but will run and spin
If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
This link will show teardown illustrations: Parts and more help available on other pages of the website.
http://www.repairclinic.com/0100_16.asp
Hope this helps.
Illeagle
Aug 27, 2008 | LG DLE2532W Electric Dryer
Kenmore Elite dryer
Heating element
Thermal fuse
Wiring
Hope this may help;
Rgards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Kenmore 63942 Dryer
Dryer not working
Assuming the problem is associated with you changing the cord, it sounds like you have a wire crossed on the power cord. Double check how you have the cord installed first. If that is correct check your power to the dryer. Since you changed the type of cord, I assume you have had outlet replaced or have just moved to new house. If you have a fuse box instead of a breaker box, check your fuses. It takes two fuses for the dryer. If one of them blows, the motor will run but you wont get heat. The motor runs on 120 but it needs 240 for the element. I can't count how many people have bought a new dryer just to find out they only had a house fuse blown and nothing was wrong with their old dryer. If you have had wall outlet changed there could be a wire crossed in it.
Oct 05, 2007 | Roper REX3614KW Electric Dryer
Dryers Logo
20 people viewed this question
Top Dryers Experts
