Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My Cabrio washer only works in Normal setting. Can you tell whats wrong with it by viewing a couple of videos of its operation?
The model is a Whirlpool Cabrio model # WTW6400SW3 Here is a link to two videos. The first on shows what the problem is and the 2nd one shows the diagnostic. http://1drv.ms/1qqxDKU Any help is greatly appreciated.
  • 1 more comment
  • George Hendrickson
    George Hendrickson May 14, 2014
    I had someone tell me that its probably the control board. I'm not sure if anyone has seen the video yet so I'm attaching a link to it on youtube. Take a look at it. Thanks
    George Hendrickson May 16, 2014
    I replaced the control board. That didn't fix it... on to the next part...
    George Hendrickson May 22, 2014
    I changed the valve assembly in it but before I did, I check the machine one more time. It started working again mysteriously. I changed the valve assembly and it continued working for a while then it came back. I suspect that moisture is getting on something that's causing it to act this way. Is there something down inside the machine that would cause it to act this way? A sensor of some kind?
  • 185 Answers
SOURCE: Whirlpool Cabrio
that is a suds detection error code try not using so much detergent then see what happens
Posted on Mar 26, 2008
  • 1028 Answers
SOURCE: Cabrio f50 Error
if in warranty call a tech...the connection on the motor postion sensor is not making goo contact if you want to try..lean washer back remove large allen screw in bottom of rotor(flywheel looking dohicky) pull rotor of remove the 4 screws in stator (dohicky with all the wires ) carefully pull it doen ..pulling wire retainers down will allow better access..connector with all the brown wires ..release catch and pull the connector off and on 6-8 times this will help clean connector of any excess coating from factory reassemble and ck
Posted on Sep 06, 2008
57 varieties
  • 1653 Answers
SOURCE: washer whirlpool cabrio message code f50,washer
F50 - This is a motor stalled failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Posted on Oct 02, 2009
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
KevinWhite
  • 1902 Answers
SOURCE: F35 ERROR IN DIAGNOSTIC TEST C:00 I have been
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Posted on Oct 15, 2011
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    We are trying to recalibrate the washer using the book and it won't work. Any suggestions as to why?
    Contact Whirlpool Service. Try to unplug washer, wait a couple minutes, then see if that reset it...
    Mar 28, 2015 | Whirlpool WTW5700XW Cabrio HE Washer
    My cabrio washer has change that got under the tub how do i get it out what do i have to remove
    Step by step instructions found HERE starting on page 4-9 on how to remove your basket.
    It will take a minute to load the document.
    Hope you get rich....:)
    Mar 26, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
    I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
    Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    I just got my Cabrio washer and when I use a wash cycle the machine doesn't spin at the end. The machine says the cycle is complete but the close are dripping when I take them out so I have to put them...
    Sorry to have to tell you, this machine is junk. Google search "Whirlpool Cabrio" and see the number of complaints for this model.
    http://www.consumeraffairs.com/homeowners/whirlpool_washing_machine.html Here is one you can see, has 46 pages of complaints.
    If you Just bought it, I would try to return it for refund or exchange for a different model, if you can.
    Soon after washer is on a f1 sign will light up, ans the cycle
    There is a recall for this. Contact whirlpool @ 1-800-253-1301 and have your model/serial number ready. Tell them you have been getting the F1 code error on the Cabrio. Tell them you have been reading on the internet about a recall. They may tell you there is no recall but be persisitent. They will then tell you they will make repairs "as a courtesy". Make sure they are going to cover parts and labor. They will then schedule someone to come out and inspect the washer. When they come out ask them about a updated washer plate. The guy who came out for mine also got me a new wash plate. He said that the new plate helps the clothes from "balling" up.
    Sep 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Push start button on control panel - machine does not start
    only 2 things can cause this.
    1 the control is set to lock out mode. just hold the lock button for 5 seconds and it should go back to normal mode.
    or 2 the controls user interface has an internal failure. its the part that has the switches and tells the computer what to do. either way call whirlpool and see if its still covered by their warranty.
    of yeah and the 3rd thing is you have no power to unit. make sure the outlet is good by trying something else in the same outlet, like a light or hairdryer.
    Jan 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    50 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
