Question about storz SMR Apex 2000 Exam Chair
How do you correct or replace the Apex 2000 Storz exam chair that will not hold in position when tilted back?
Chair operates with controls but will not hold when placed in upright position when someone sits on it
    Master:
  • 373 Answers
This should be visually diagnosed to get an accurate identification of the issue. That said, I would look to the tilt motor having broken teeth on the sprocket or a broken drive gear. Also the drive chain may be loose enough to allow it to slip on the sprocket. In most cases, the issue is with the tilt motor mechanism. Removing it will determine if an adjustment is all that you need or if it needs replacement.
Posted on May 29, 2014
How to get to bulb to replace on solarlite
SMR Solarlite Chair Mounted Procedure Light Apex Maxi Exam on eBay : http://www.ebay.com/itm/SMR-Solarlite-Chair-Mounted-Procedure-Light-Apex-Maxi-Exam-/172507202330?hash=item282a3b031a:g:7FsAAOSwa~BYPjpF
May 25, 2016 | storz SMR Apex 2000 Exam Chair
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya
www.fixya.com > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600%20Owner's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600E%20Owner's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
Dec 30, 2015 | Quantum 600 E Electric Wheelchair - Used...
My wheelchair's green light doesn't come on after I return from my reclining position
Contact Pride for a manual, you'll need one. Or a Wheelchair/ medical equipment outfit.
Aug 02, 2014 | Pride Health & Beauty
I have a Quickie S646SE wheelchair with a Qtronics Pilot+ romote controller. I charged the chair last night. When I turned it on today the profile lights scroll left to right and the chair does not move. I...
Press and hold power button til beep then push joystick forward and hold joystick til beep then pull the joystick back and hold joystick til beeps. turn power off then on. should be unlocked now
Mar 17, 2014 | Quickie Wheelchairs Quickie S-646 Power...
Tilt
The repairman for our vendor figured out, as he was about to replace some mechanisms so our Boss B9431 chairs would tilt, that they were not broken! While flipping down the paddle on the left can lock the chair in a particular angle, once you've tilted it, it will not tilt IF the height adjustment lever on the right is PUSHED IN towards the chair, locking out the capability of tilting. You have to gently pull the height lever away from the chair, sliding 0.5 or 0.7 inches, to activate the tilt ability. This may be the case with other models, or may not.
Jan 15, 2013 | OfficeMax Zeal II Leather Task Chair...
Today I turned my wheel chair on and it would not go forward or back. The indicator on the control panel shows I have a full charge. This has never happened before. I did some checking, when I put the...
I am making some assumptions based on your description of the problem:
1: You have a Jazzy 1113 with tilt.
2. You have batteries that are fully charged as indicated by the battery display
3. Your chair is not in freewheel, that is the brakes are engaged with the levers in the correct position.
4. The motors are not turning.
5.You do not state the type of tilt system but I am assuming it is either true balance tilt by Pride or Motion Concepts tilt.
6.You have no flash error code on the battery display.
7. You do have a flash error on the joystick.
My initial response based on these assumptions is that your chair is in drive lock out and the electronics are inhibited because of the following reasons:
You have a bad switch that indicates to the electronics that the chair is in tilt or more than 20 degrees of tilt. You have a bad inhibit harness. You have a bad end of travel switch on the actuator. The list is long depending on the system.
Check all the wiring and switches associated with the tilt system for broken/disconnected wiring.
Get back to me with exact specs of the system including type of tilt system and the serial number of the chair so I can research the configuration and give you exact and not general answers. I hope we are off to a good start.
Dec 10, 2010 | Pride Jazzy 1113 Power Chair
My speed indicator lights are constintly flashing- the chair works fine though
You don't say what sort of chair you have, but if it has tilt or power seating system, the speed lights flashing could be a power-limiting warning, which means you have the seat tilted or raised too high for full power so it is limited to going slow. Lower seat and then try to drive it an normal speed. If the seat isn't tilted or raised and lights are flashing, then the switch on the chair that senses the height or the tile is probably faulty and would require replacement. Do NOT disable or bypass the switch as it is a safety device to prevent unsafe operation.
May 23, 2010 | Jet 3 Ultra Power Chair
storz SMR Apex 2000 Exam Chair Logo
603 people viewed this question
Top storz Medical Experts
Rhonda Webster
Rhonda Webster
masud
masud
Ron Jones
Ron Jones
Level 1 Expert
Are you a storz Medical Expert? Answer questions, earn points and help others
