Question about Pool & Spa
Maxi flow spa booster pump, buzzing...then cuts out
I have just bought a house with a spa in it. its a spa quip spa and when i turn it on the mode light flashes green and red. when i push the button the pump humms for about 15 seconds then stops. WHAT is the problem. a spa shop said it needs to be bleed but i have done that and still not working..????
    Problem Solver:
  • 10 Answers
Hi the capacitor needs replacing in the pump connection box, this needs to be exactly the same uF value as the one you are taking out.
Posted on Jul 08, 2009
  • Kathy Hughes
    Kathy Hughes May 03, 2014
    How do u tell the Uf and where is this located.. Can we do this ourselves or is it best to get someone out? Thanks
  • Kathy Hughes
    Is part of the circuit board as this is what we were told May have to be replaced (the circuit board) .. Was told over the phone we haven't someone out yet to look at it as we are trying to minimise the problem
I have just got a new pumpmaxi flow and the plug is not the same as my old pump(maxi-flow ) what do i do to make it work on a spa/quip spa
there is a wiring diagram on both of the motors, use this to sort out the wiring, very important on two speed motors !!!
Jan 04, 2015 | Pool & Spa
Water Flow to Booster Pump
plastic bag with a few socks in it, can be used to block the skimmer plumbing, if the pump is lower than the pool ! if not it will stop draining after the filter emptys
Apr 25, 2013 | Polaris Pb4 - 60 Booster Pump
Older spa spa quip sq1500 need replacemnet control box model 2095bb5 and heater element
can some one help me i have a spa quip sq1500 and my heater light will stay on for say 5 or 10 min but soon as i put jets on again the heater will go off and stay off untill i turn off jets again ????
thanks
Jan 19, 2013 | Pool & Spa
LocF error on hydroquip 9000 e spa
possible bad pump motor or relay to pump or shorted heater element
Oct 21, 2012 | Hydro Quip Inc Pool & Spa
Hydro-Quip pack in my Hydro-Spa hot tub no heat.
3 Flashing dots (display) - Water flow problem check for closed valves, dirty filters, water level, pump/wet end operation/defective pressure switch.
If your spa has been off for a while its likely something is blocking the lines.
Flashing dots & Lit light on display - Hi-limit trip, reset power to clear.
Nov 16, 2011 | Hydro Quip Inc Pool & Spa
When I turn on the power, my polaris pb4 pol pump buzzes for a few seconds and then stops and doesn't do anything,
Check for a jammed impeller in the pump. Otherwise, sounds like the capacitor is probably bad. Either in a raised housing on the outside of the motor or in the back under the motor cover. The capacitors are rated in uF or micro farads. Be sure to get the right one...
Jun 16, 2010 | Polaris Pb4 - 60 Booster Pump
Had a small leak from pump, now when it comes on loud buzzing noise and it won't do anything. Is it fixable?
sounds like pump is binding or jammed check motor bearings disassemble pump and try turning impeller if stuck try oiling motor if turns free check housing for debris or damage repair or replace any damaged part
Apr 02, 2010 | Polaris Pb4 - 60 Booster Pump
Spa Quip Err8
An error code will come up if the sensors in the unit detect no water flow, or over temperature. Now this might be the actual problem or the sensors or circuit board may be faulty. First check the pump is circulating the water, if it still errors then the fault is in the electronics.
David. Goulburn Pumps
May 09, 2009 | Pool & Spa
We have a spa quip 2.5 maxi flow spa pump,tried to turn the spa on and the pump was hot and just made a buzzing noise.There is power getting to the pump but it just wont filter.The spa controller seems to...
Hopefully you have not fried the motor. To free a stuck motor: try to reach past the strainer to the impeller and turn it. If you can't do that, remove the electric end cover and find a double flat for a wrench where the shaft goes into the motor. Or maybe you can remove the spring thing from the end of the motor and move the shaft with a pair of vise grips or pliers. Don't damage the place where the spring thing mounts. Don't try to move the motor with the plastic fan thing near the pump, you'll just break it, and then you really have problems.
To keep a motor from sticking, thru off season occasionaly spin the pump, just a few seconds will do, don't need water.
Apr 17, 2009 | Jacuzzi Pool & Spa
Pool & Spa Logo
565 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
