Question about Intel Core 2 Duo E6700, 2.66 GHz E6700 Boxed Processor
I want driver e6700 - Intel Core 2 Duo E6700, 2.66 GHz E6700 Boxed Processor
  • Intel Master
  • 3,320 Answers
The operating system is the "driver" for a CPU
Posted on May 12, 2014
Pentium dualcore e6700 graphices driver
there is no such thing as a graphics driver for this cpu....you will need a graphics driver for the graphics on the motherboard or the discrete video card being used in the computer it is in
add details of the graphics card or the motherboard and resubmit the query please
Dec 11, 2013 | Intel Pentium DualCore E6700 32 GHz 2 MB...
Speakers not detected on Dell XPS 210 with windows 7
hmmmmmmmmmmm sounds like dell has an o/s discrepancy(no duoooooooooooeiiiiiiiillllllll)
it's the sound card drivers at fault
look at your device manager
start
control panel
system icon
and see who makes that sound card/driver
go to that website and see if they have the w7 version
don't get your hopes up
May 28, 2012 | Dell My XPS 210 (dxcwpf1_7) Intel Core2...
Pentium dualcore e6700 audio driver
The best place to find a possible driver would be the Microsoft update page, assuming you are using windows. If you are just point your computer's internet browser to www.update.microsoft.com and select check for updates. It should be able to find any missing drivers specifically or if they are not stored by Microsoft it will find you the generic drivers for your motherboard/processor combination.
Mar 23, 2012 | Intel Pentium DualCore E6700 32 GHz 2 MB...
I installed a new cpu and now computer will not boot. I thought the processor might be bad so I returned and got a new one. This was not the problem since the new one does nto work and original processor...
Are you sure the main board is capable of taking the new processor speed. There might be a jumper on the board to switch processor speed or could be a Bios setting. What exactly happens with the new processor installed do you get any post beeps at all if so how many. Double check to make sure there are not bent pins on the processor if it has any pins. What kind of Pc is it you can usually go to the manufacture web site to the drivers section and see if there are any Bios updates if there are you can save the bios to some type of disk then boot from the disk and the Bios flash is automated and run by itself.
Hope this helps some
Robert
Jan 06, 2011 | Intel Core 2 Duo E6700, 2.66 GHz E6700...
I'm planning to upgrade my desktop and i want to start upgrading from cpu. My current motherboard is Asus P5S-MX SE and cpu is Intel Pentium Dual Core Processor E2160, 1.8Ghz. Can you give me a list of...
Oh boy, you're in the same boat i'm in with my dad's HP asus based OEM board. You're max choice in a regular core 2 duo is the E6700 @ 2.66ghz with a 1066 FSB (Front side bus). Reason being is likely identical to my situation. The board likely only supports a "conroe" core. It can't handle the "WOLFDALE", otherwise they would list higher ghz for an E6700. The E6700 is also available as a 3.2ghz with 1066mhz FSB, but its based on 45nm process, which requires different power regulation from the board. if you were to put in the wrong chip, you get nada. Not even POST errors from what i've read where others have tried and failed.
Unfortunately, E6700 @ 2.66ghz are a little rare, but they are on ebay for about 80-100 bucks, and various other places. Search for "E6700", but be careful to avoid the 3.2ghz's.
The only other choice for max is the Core 2 Extreme X6800 @ 2.93 ghz. This processor looks like its about double the cost to the E6700 though. That's a lot of extra money to get only .27 gain in ghz though, IMO, though there could be other reasons to go extreme, like availability. There might be more of them! The same logic applies here. Stay with the 65nm process, and 1066 FSB.
Here is the tech spec page for your board. Its shows all the supported processors: http://usa.asus.com/product.aspx?P_ID=fLSzpcTDJYT0rgS6&content=specifications
You might want to choose carefully on whether to upgrade this board's CPU. Might be time to scrap the whole board and get something with more FSB capabilities.
Dec 29, 2010 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Cpu upgrade
does it fit?
put it in.
Jun 04, 2009 | Intel DG965RY Motherboard
1333 FSB processor ( E6850 ) on a 1066 FSB motherboard, DDR2 667 memory
Hi proenza. you're making good sence! You're D945GCL MB should be able to run 1066 FSB. Not 100% sure you're memory will keep FSB up to 1066.
Here's the trouble though. The Intel Core 2 Duo E6850 will not run on the Intel D945GCL motherboard because it is not supported. Look here at Intel's web site. Supported CPU's.
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=d945gcl
Intel E6850 specs sheet. http://www.dealtime.com/xPF-Intel-Intel-Core-2-Duo-E6850-Processor-3-0GHz-4MB-Cache-1333MHz-FSB-Conroe-Dual-Core-OEM-Socket-77
Intel E6700 spec sheet. http://www.dealtime.com/xPF-Intel-Core-2-Duo-E6700-2-67Ghz
This CPU is supported by the D945GCL MB.
Intel Core 2 Duo E4700 Processor BX80557E4700 - 2.60GHz.
$149.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3826343&CatId=2396
In order to get 1066MHz (CPU can run at), you'll also need the memory support at 800MHz. The D945GCL MB can only run DDR2-667MHz.
Many people buy a CPU to run MB's specs (1333MHz) just to find the same MB does not support DDR2-1066MHz or DDR2-800MHz. Motherboard Mfg's are lagging. DDR3-1333MHz is out there now to support the 1333 MHz CPU FSB.
http://www.lagoom.com/KINGSTON_1G_DDR3_1333MHZ_PC3-10667/KVR1333D3N9_1G/partinfo-id-580235.html
I hope this has helped you make a decision proenza.
Good Luck!
Mike
Jul 17, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Intel Core  2 Duo E6700, 2.66 GHz E6700 Boxed Processor Logo
69 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
