Question about Konica Minolta MAGICOLOR 2300W LASER Printer
Print quality on Konica Minolta 2300w faded.
I have a Konica Minolta 2300w Printer for the last 3/4 years, the print quality/density has always been very good, until yesterday, after changing a toner cartridge the problem started, the printed text and images are faded, and the density of solids are as if they are washed out. Firstly the printed sheets had a foggy background, a friend told me to empty the toner recycling box and use a vacuum cleaner to take away any remaining toner from the transfer belt that might have built up, I did this and it helped with the foggy background alot, but still printed faded.
I replaced all c/y/m/k toner cartridges but the problem still exists, the OPC Drum reads at 30%, unfortunely I scratched it a little when taking it out, I have ordered another new one, would this help with image density?
I have checked the setting on the computer for the printer and they are all OK.
Please help if you know how I can fix this problem, as I'm totally lost without this printer, I use it every day for work and that work pile is getting bigger and bigger.
SOURCE: PagePro 1350W
Time has nothing to do with how long a toner cartridge will last. What is the page count on the cartridge?
Don't expect too much from it if it is the original cartridge that came with the printer as they have a very short fill.
Posted on Jan 12, 2008
  • 214 Answers
SOURCE: minolta 2300w windows vista
try changing a usb cable vista should find some new hardware
Posted on Jul 02, 2008
namizhka
  • 148 Answers
SOURCE: Konica Minolta magicolor 2300W printer
TRY TO RESET THE UNIT FIRST.
Posted on Sep 29, 2008
chinmay_lp
  • 271 Answers
SOURCE: driver
Here is the link to download your driver.
Konica Minolta Magicolor 2300W
Thanks
Posted on Mar 12, 2009
  • 55 Answers
SOURCE: Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Posted on Apr 25, 2009
Konica Minolta Magicolor 2300W not transferring toner to paper.
Clean the paper feed rollers,the fusing unit rollers and print the blank page(min.10-15) for clean the upper fuser hot roller.Agiting the toner.
Jan 28, 2013 | Minolta magicolor 2300W Laser Printer
2300W print page alignment
try reloading the driver go the web site below get up dated drivers
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 29, 2012 | Minolta magicolor 2300W Laser Printer
I have Minolta 2300W Laser Printer and it folds the first page only about 3 to 4 inches down makes a nice one inch fold but take that out and print again...next page fine.....now printing with two wide...
The is blocked by dust on the side of the paper on the image unit that would have color associated with the print. Remove all the image units and clean all the laser glass. Replace those image units also if streaking as for the paper ensure correct paper side and media type.
Jul 12, 2010 | Minolta magicolor 2300W Laser Printer
Konica Minolta Magicolor 2300W firmware needed
firmware is located on secure web site try having a Konica Minolta tech come out and flash the firmware
Apr 15, 2010 | Minolta magicolor 2300W Laser Printer
WHAT IS DENSITY SENSOR IN LASERJET 8500
The Density Sensor is located inside the right upper door and senses the colour calibration pattern for each colour formed on the transfer drum during a calibration cycle. Press GO. Print a configuration page and then troubleshoot as an Image-quality problem as instructed in the user manual. Check the transfer guide for cracks and replace if necessary. Check the event log for errors numbered 54.00.0<X> the X indicates, 5-sensor abnormality, 4-Cyan, 3-Magenta, 2-Yellow, 1-Black. The last 3 error codes should be seen on the Configuration page.
Dec 29, 2009 | HP LaserJet 8500 Color Printer
Bad photo quality after changing drum
your laser printer
1) print color quality is now distorted that means print skew (technician called)
2) print tint means the print color not enough density,
3) print mottle means print dirty
you may try
1) print distorted--- find out the skew adjustment from your printer manu, it is adjust the image before transfer to the drum.
2) print skew could be happened when the drum replace install not very accurate, so install it more carefully.
3) print tint---you may increase print density from the manu, not fix,
4) print tint---the toner caridge near life cycle or using the less compatible toner. so you have change the quality toner or cartridge (if near life cycle) to improve quality photo print
5)print mottle---toner quality ? or cartridge near life cycle also cause print dirty paper,
Feb 08, 2009 | Konica Minolta magicolor 2300DL Laser...
Poor print quality 2300dl
first did you try to clean laser glass ? and maybe you need a new 2'nd transfer roller.
open front cover and under the pc drum there is a blue knob, pull it out and clean the glass
May 28, 2008 | Konica Minolta magicolor 2300DL Laser...
Light printing
I would suggest using the printer's menu and checking both Direct Print->Print Quality and Direct Print->Brightness as these may be set too low or too high. Change these values, 1 at a time, and do a test print to check the print density
Dec 24, 2007 | Konica Minolta magicolor 2430 DL Laser...
98 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
