Question about HP LaserJet M1120 MFP All-In-One Printer
What is scanner error 22? - HP LaserJet M1120 MFP All-In-One Printer
Resolve by turning off by power switch, wait at least 30 seconds, then turn back on and wait for it to initialize. perform a hard reset on it. turn it off. press and hold down cancel and start copy buttons at the same time while powering on printer. continue to hold down until the control panel display reads PERMANENT STORAGE UNIT. RELEASE BUTTONS. printer should return to ready automatically
Posted on May 12, 2014
Scanner Error 22 Hp Laserjet M1213nf MFP printer
it is a physical broken piece that supports scanner mechanism. from what i can find. dont no if this has helped.
Jun 16, 2016 | HP Office Equipment & Supplies
Error 22
Go to hp website and look for firmware update. The model M1217 had the same issue which was fix in a firmware update.
Jun 07, 2012 | HP LaserJet Pro M1212nf MFP -...
TMA doesn't work ;code 22
If 22 is blinking in the Scanner LCDThe Transparent Materials Adapter (TMA) may be attached incorrectly or is broken.
  1. Disconnect the scanner power cord.
  2. Disconnect the TMA cord from the scanner.
  3. Verify there are no bent or broken pins in the cord plug of the TMA. If the cord has bent or broken pins, it will be necessary to contact HP .
  4. Reconnect the TMA cord to the scanner.
  5. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  6. Check that the TMA is properly positioned on the scanner glass; either reposition the TMA in the positioning plate or reposition the positioning plate on the scanner glass.
  7. Reconnect the power cord to the scanner.
  8. Attempt to scan.
If 22 "The scanner could not scan" displays on the screen and the Transparent Materials Adapter (TMA) is being used
  5. Reconnect the power cord to the scanner.
  6. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  7. Attempt to scan.
  8. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
If 22 "The Scanner could not scan" displays on the screen and the TMA is not being used
  1. Disconnect both the scanner power cord and the USB cable.
  2. Perform a self-test on the scanner if it has a built in self-test. Click here for instructions on performing a scanner self-test (c00030441) .
  3. If the scanner passes the self-test, reconnect the USB cable and attempt to scan. If the scanner fails the self-test, it will be necessary to contact HP.
  4. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
May 05, 2012 | HP 4570C Flatbed Scanner
Scanner error 22 M1213nf mfp
why it is showing scanner error 22 message
Feb 23, 2012 | HP LaserJet M1120 MFP All-In-One Printer
Error e42 22
Apr 24, 2011 ... E40 20 = Other hardware error. E42 22 = Scanner error. How to reset CANON WASTE INK COUNTER MP160/MP145 Before you reset the ... canonprintersink.com/error-code-printers-reset-canon-mp145-mp160.html canonprintersink.com/error-code-printers-reset-canon-mp145-mp160.html
have just checked this site and I am sure it will help you
Feb 20, 2012 | Canon Office Equipment & Supplies
The error message on the printer screen says: scanner error 22
The error is scanner error check the scanner in moving or not if not then check the scanner cable is broken or dust on scanner rod clean oil it properly
Dec 28, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Error code E-22 in RICOH FT3713
· Scanner home position sensor failure
· Defective scanner motor
· Defective main motor
· Defective dc power supply board
· Incorrect scanner drive wire position
· Defective dc harness
· CN103 or CN105 on the main board is not correctly connected.
· FU202 on the dc power supply board open (blown fuse).
Jan 08, 2010 | Ricoh FT3713 Copier
HP LaserJet M1120 MFP All-In-One Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
