Here is so difference case of corruption of MDF files and I can't my MDF files so please any body know about that type of errors please share with me....!
This site can help you:
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/569-i-have-a-problem-how-do-i-fix-a-corrupted-database-file
or try thes steps
-Determine which program is associated with the corrupted data by the error messages you are receiving. For example, if you consistently receive a "File Not Found" error when starting Microsoft Word, it is likely that the corrupted data is a Word file.
-Reinstall a fresh version of the program which currently contains corrupted data. Insert the installation CD for the program into your computer's CD drive.
-Double click on the "My Computer" link.
-Double click on your CD drive letter (typically the "D" drive).
-Click on the "Setup.exe" file contained there to begin the reinstallation process.
-Select the option "Install/Reinstall" to reinstall the program. All of the files associated with the program will be patched over, fixing the corrupted data.
To choose a reliable and 100% safe and secure, a Microsoft SQL server database recovery program guarantee the zero loss of quality. You can see this page: http://www.en.repairsqlserver.net
See demo: http://www.youtube.com/watch?v=Q0aW1vT5nxA
Hi, if you want to recover your SQL database then I suggest this SQL database recovery software. By using this software the user can easily recover MDF file data. By using this utility the user can recover database objects such as tables, stored procedure, functions etc. This software provides two scan options quick scan and advanced scan to recover the SQL server database. For detailed info, the user can try the demo version of this software.
https://www.sqlrecoverytool.com/
Stellar Phoenix SQL Server Recovery is an advanced solution to fix extremely corrupted MDF files of MS SQL Server. It effectively recovers maximum possible data from corrupted MDF files.
Specially designed for such purposes like to fix severely corrupted database files (MDF) of SQL Server. It thoroughly scans damaged MDF file within a click and displays all the recovered tables including objects such as views, triggers, etc. Download now: SQL Database Repair
