Question about Panasonic NN-S963BF Microwave Oven
Turntable doesn't turn
I replaced the motor and the turntable still doesn't turn. When I opened the bottom of the microwave a very small plastic piece smaller than a dime fell out. It's round with a flat piece that extends out.
  • Catherine OConnor
    Catherine OConnor May 12, 2014
    This is not a Panasonic Microware - I try change the name - it's a Kenmore Model 401.85043010
My turntable doesn't turn
Sounds like the turntable drive coupling is broken. In the bottom of the microwave where your turntable is, underneath that is a small drive coupling that the motor shaft pushes into. if the motor doesn't turn or the coupling, which commonly has a D shape shaft to keep it from slipping, is broken, the tray will not turn. One quick test it to remove your tray and see if you can turn the coupling easily by hand, if you can you probably have a broken drive coupling. The turntable motor is very difficult to turn by its shaft. so if it turns easily it is probably a broke coupling. NEVER force your turntable around by hand or you can break that coupling.
May 12, 2014 | Panasonic NN-S963BF Microwave Oven
Tip
Replacing a Turntable Motor on a Microwave
The following advice is for MOST microwave ovens (including over-the-range models). This is a fairly simple repair that can be accomplished without uninstalling the microwave oven.
If the turntable motor has failed, it can be replaced by following these steps:
1. Unplug the microwave.
2. Open oven door and remove glass tray and carousel ring.
3. Locate and remove the screws holding the bottom panel (under the microwave) in place. With the screws removed, the bottom panel should open from the front with the hinges in the back.
4. Disconnect the connector plug from the turntable motor.
5. Reach inside the oven and remove the coupler. This is the small plastic piece that the center of the glass tray sits on. You may have to gently pry up with a flat screwdriver to get it to come loose, then pull straight up.
6. With the coupler removed, loosen the mounting screw(s) to the motor and it should easily come out from under the oven.
7. Install new motor in the reverse order of the steps I just provided.
There are many appliance parts websites that carry replacement parts cheaper than retail. The average cost for most of these motors is about $30. Prices do vary depending on model number. I hope you find this information helpful.
on Dec 01, 2009 | Microwave Ovens
Magic chef microwave
Take the tray and the plastic piece the tray sits on out of the microwave. There is a small motor that turns the turntable. It is probably bad. You should be able to replace the motor from the bottom of the microwave. Part number is 3966820200.
Jan 18, 2014 | Microwave Ovens
Phillips microwave oven vt255/bl tuntable does not rotate
HELLO.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to one of these problems explain below
(1)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properl on the turning mechanism.
(2)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(3)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
FOLLOW THESE STEPS TO REPLACE THE FAULTY MOTOR.
THINGS NEEDED.
* screwdrivers
* replacement motor
* specific microwave information and part number
1 Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3 Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4 Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5 Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6 Reinsthall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Whirlpool Microwave Ovens
Phillips whirlpool microwave turntable not turning
HELLO.
Your microwave turntable may not turn due to any of these problems explained below.
(a)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properly on the turning mechanism.
(b)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
(c)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
follow these steps below to replace the faulty motor.
1. Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 .Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3. Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4. Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5. Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6. Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Microwave Ovens
The turntable on my GE Spacemaker Microwave JVM1640BB does not turn.... I can turn it by hand, but does not turn during cooking.
HELLO.
THINGS NEEDED.
* screwdrivers
* replacement motor
6 Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Hoping to help on more problems.
THANKS.
Sep 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable not turning
This is commonly caused by a turntable motor that has worn out and needs replaced.
The motor can be replaced by following these steps:
1. Unplug microwave.
3. Locate and remove the screws holding the bottom panel (under the microwave) in place. With the screws removed, the bottom panel should open.
5. Reach inside the oven and remove the coupler. This is the small plastic piece that the center of the glass tray sits on. You may have to gently pry up with a flat screwdriver to get it to come loose.
This is a very simple repair. A replacement can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Prices vary so shop around for the best price. If the model number you listed this question under is correct, the part number is DE31-10172A. Most of these sites also have helpful exploded view diagrams you can use for reference.
If you have any questions, or require additional assistance, please let me know. I hope this help you.
Sep 23, 2009 | Samsung SMH7178STD Microwave Oven
Flashing is occurring around the plastic turntable piece which is causing it to melt. Took off and saw that the enamel was pitted around the turntable opening. When I remove the plastic turntable piece, no...
It sounds like you are talking about the turntable tray adapter in the bottom.
What usually causes arcing is the reaction of the RF (microwave) energy acting on carbon. It's great that the motor and orifice are OK. Sounds like you just need to replace the T/T adapter. If the paint is pitted or altered, you need to use a special catalytic paint for microwave cavities to touch it up. The paint's main purpose is to protect the metal from rust but it is a high temperature paint to stand up to the higher temperature of that environment.
Sep 12, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
The turntable does not turn. How do I change the
The turntable motor can be replaced by following these steps:
This is a very simple repair. Ironically, I just replaced mine today. If you have any questions, or require additional assistance, please let me know. I hope this help you.
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar 1310W built in
The following parts are in the turntable system: The turntable motor, underneath the floor of the microwave; the turntable coupler, which is like a small plastic piece; the turntable support, either a three-legged or circular piece with wheels; and the glass turntable tray.
It sounds like maybe your turntable support is missing?
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. Goldstar owner manuals can be downloaded here.
Aug 11, 2008 | Goldstar Microwave Ovens
Panasonic NN-S963BF Microwave Oven Logo
47 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
