Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
I have a Bosch Nexxt 500 front load washer that will not drain when it gets to the spin cycle. The drain pump is clear and free from obstructions as well as the lines are clear and manually filling up
I am very handy at working on anything but I don't have any direction to go. Thank You.
  • 682 Answers
Sounds as if the rinse hold button has been set by accident.check the switches top left.if they are correct, then next query would be logic board has a problem, sometimes fixed by hair drying the board in cases of damp lack of use washer.if machine completes most cycle then I suspect rinse hold button is on or open circuit.
Posted on May 12, 2014
textonor
  • 130 Answers
SOURCE: bosch frontload washer will not drain
Hello Mamma5, It sounds like the drain pump is either seized or jammed. The drain pump has an anti jam device in it. Since you have figured out how to get into the drain pump, try turning the inpeller in the back. It will be a little hard to turn as the magnets in the motor will fight you on this. Look close in case there is anykind of thread wrapped around the inpeller. If so, then you can free the pump. If you cannot free it to run, advise the repairman what you found so he can bring a drain pump with him.
Hope this helps.
Posted on Jan 23, 2008
  • 1462 Answers
SOURCE: my bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Posted on Oct 18, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch Classixx WFL 2462 Front Load Washer
Remove plastic panel at front bottom of washer, there you will see the filter, unscrew it anti clockwise to remove and clean, replace and tighten up clockwise.
Plz rate my solution.
Thanks.
Posted on Jan 17, 2009
barkencoa
  • 3463 Answers
SOURCE: washer drum doesn't spin, no draining of liquid
If you have got rid of all the water, and it still will not spin, then the odds are it is the brushes in the motor that need replacing.
Quite a common problem
Posted on Jan 19, 2010
Testimonial: "I will tell repairman from Sears ( coming Friday ). i'll ask him to check brushes before he pulls motor. "
Macmarkus
  • 2605 Answers
SOURCE: washer fills and drains, but the drum does not run
Joe, Thanks for the prompt reply. OK, it sounds like one of two possible culprits, 1) the belt has broke or spun off. 2) the brushes in the motor are worn...although the initial symptom of this is typically manifest in "no spin" so I'd lean towards a broken or spun off belt. You'll need to remove the rear panel for a visual inspection to confirm or dismiss either possibilities. Let me know what you find out. If the belt is off check for possible reasons "why" ? It can be a loose drive pulley, ( the large one, not the motor pulley ) or simply an unbalanced load on the previous wash, just a heads up since you're looking around in there anyway. Of course the belt itself may be worn ( stretched ) or broke and thus at fault as well. Good luck, I'll watch your post. macmarkus :)
Posted on May 04, 2010
Code d:08 bosch nexxt series 500
It is bound to be a blockage or the impeller is stalling due to foriegn objects like coins.
Mar 06, 2014 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I have a Bosch WFMC330SUC that does not end the cycle, it just keeps starting over. I assume it is a bad control board, but they are $300+ and I'd probably replace the machine instead. Any suggestions?
Hi wwwylie,
First check the Drain Pump filter, as the last 2 cycles of a machine is Drain & Spin, and if the Drain pump cannot drain the water, the filter may be clogged and the cycle won't progress to spin.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 16, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Jul 12, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Why no spin?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 21, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Nexxt Washer Problem
timer not sending signal, or bad transmission
May 08, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
The water won't drain from my Bosch Nexxt 500 Series Washer machine
I solved the problem by using a sump pump to drain most of the water, then I removed the cover plate on the lower front right of the machine to get access to the drain plug. Upon removing that, some water flowed out but not too much, I found a sock jammed in there which wasn't allowing the drain or spin cycle to work properly.
Interestingly, the machine's manual says that the cover plate is only to be removed by a Bosch authorized service repair representative. Saved about $150 by simply doing this myself.
Sep 16, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch front loading washer nexxt 500 won't pump out water on the spin cycle
could be drain hose is not high enough. I had the same problem and when I raised the hose it worked fine.
Dec 04, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch frontload washer will not drain
Hope this helps.
Jan 22, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Clothes too wet upon cycle completion...
Try reducing the amount of low sudsing detergent you are using. This can make the load too heavy and won't spin out. Remember suds have 3 parts, air, detergent, and water. The drain pump is designed for water, so if you see suds during the wash, it will be worst on warm and hot, then there is too much detergent, or is not low sudsing. I know Bosch reccommends HE, however HE liquids normally are not low sudsing, just High Engery. Also the Permanent Press cycles are always a lower spin speed. Hope this helps
Jan 20, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
93 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
