Question about Tablets & eReaders
UVM302 keeps saying no /weak signal
  •  Mike M
    Mike M May 12, 2014
    Hi audrey may nidd, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    No idea what product you have.
Why does my tablet keep powering off when the battery says 82%
Battery is weak and not calibrating properly. Replace the battery and re calibrate unit as per the instructions that came with your unit.
Sep 15, 2017 | Tablets & eReaders
My tv is saying it's connected to my wifi but when I try to pull up the apps it's saying disconnected to wifi
The signal is weak, when you try to pass data over the network it drops out due that fact
May 03, 2017 | Tablets & eReaders
7 inch irulu tablet keeps kicking me out of my internet wifi, i have to reboot all the time... i have my screen set to stay on always to avoid this, i like the tablet but this is ridicules..HELP
I have to tell you they are cheap Chinese entry level tablets and are grossly unreliable. We had a guy here who went through three in 18 months.
You shouldn't have to reboot to get wifi back. If is it a public wifi spot, getting booted out is intentionally unless you are using it constantly.
If it is home wifi, it may be that your signal strength is weak. Irrespective, buy yourself an Acer, Samsung or iPad.
Nov 01, 2016 | Tablets & eReaders
Keep getting error message. Unfortunately google play services has stopped
Hi, First I would check your pad for adware. Then you can get in to the settings and see where things are going wrong. Services etc...
Another thing the wifi signal maybe weak check and adjust for best signal. Please don't let you 2 or 4 year old play with it... Good luck.
Apr 18, 2015 | Tablets & eReaders
My Tablet keeps shutting down, uses Battery quickly, won;t even find wireless, when it stays on long enough.
You neglected to provide the age of the tablet. If it's a couple years or older your battery might be on the way out. They don't last forever and some of them aren't of the best quality to begin with. Charge it all night long. In the morning when you turn it on if it still doesn't work right be sure to check the battery level with the A/C adapter unplugged. The level indicators are based on the voltage. If the voltage doesn't come up to spec, it might show less than 100% charge even when charged overnight.
The wi-fi problem could be battery related, too, as wi-fi is a radio transceiver that sends as well as receives signals. Wi-fi doesn't work so well if the transmitter produces a weak or intermittent signal.
Mar 08, 2015 | Ematic 7" Touch Screen Tablet
Ok I asked the question three days ago why can I get on a free wifi connection with my phone but not my tablet
The free Wi Fi router may have run out of IP leases on its DHCP server just when you were trying to connect the tablet. If the leases are as an example say one week long then if lots of people connect to the free wi fi they get a lease for one week. So if the device comes back within the week it already has an IP address assigned to it and works. If a new device comes along it has to ask the DHCP server via the WI FI to assign it an IP address. If all available IP addresses are leased from the WI FI router the device will not get assigned an ip address. Would suggest trying to connect the Tablet on another Wi FI system to test it works.
I had this happen on my mobile phone when I was in Surfers Paradise in a Coffee shop and suspected the lease time on the WI FI router was too long for the amount of short term customers using the coffee shop. (the staff had no idea on why the Wi FI was not working so it would have been pointless to try and explain this concept to them and how to change the lease time on the dhcp server) Also there is a limit to the simultaneous number of users on a Wi Fi frequency on one access point . Unless the WI FI uses multiple WI FI access points.
Jan 27, 2015 | Mach Speed Trio Stealth G2 Tablet -...
How can I get my proscan tablet to connect to networks it keeps saying failure to connect
Firstly try to use one network at a time.Utilize required software APP and proceure to recognise signal. please check if you have available DATA
Dec 07, 2014 | Tablets & eReaders
Weak wifi reception on my coby 4331 tablet
The solution for this problem depends on how you are using the device. It depends mainly on how thick your walls are and where you placed your wi-fi router. If you can't change the location of your router, I suggest you to get a new, more powerful one. A cheaper solution would be to move, if possible, the router. The thickness and number of walls between the device and the router decrease the signal's strength considerably. You could also install a repeater, though you'll need to place it where the signal is at medium strength, in order to boost it. The repeater should be of the same manufacturer of your router, as it will have 100% compatibility.
Mar 26, 2014 | Android Tablets & eReaders
Weak wfi signal
Did you check in wifi settings and make sure they are both picking up your wifi and not a neighbors?
Nov 30, 2013 | RCA 7 DUAL TABLET DVD SYSTEM
Why does my tablet keep saying authentication problem when trying to connect to wifi
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Dec 30, 2012 | Archos Arnova 10 4GB 4)
Tablets & eReaders Logo
24 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
