Question about Garden
Blades keep going out of time
Just replaced the timing belt. Everytime I set the blades to the respective 12/6 & 3/9 o'clock positions for timing, the blades will start to hit after about 8-10 seconds after turning them on. When you look at the blades, they are not longer in their set positions. The tensioner is set pretty tight, so I do not see how the belt could be slipping, plus it is a cogged belt. the blades are seated correctly on the keyways, so I know they are not slipping. I'm at a loss how the blades can just move like that magically.
  • Garden Master
  • 2,478 Answers
What model?
Posted on May 12, 2014
Testimonial: "LX 255, 42" deck"
  • 3 more comments
  • carolina_sun May 12, 2014
    John Deere
    Freedom Deck\
  • Dennis Key
    Dennis Key May 13, 2014
    Check for sheaved key on left pulley. It takes a key, the other 2 don't.
  • carolina_sun May 13, 2014
    I'll do that. I'll bet it fell out.
    Can you describe a bit where the sehaved key is located? I'm an Engineer, so I'll be pretty savvy with this. I assume you are talking about the timing pulley opposite the pulleys with the tensioner?
  • 86 Answers
SOURCE: blades stop working
Does your mower have an electric clutch ? If so your problem is most likely a connection
Posted on May 12, 2009
SOURCE: We have a brand new Craftsman 26 HP, 54
adjust the tension on the idler pully or refer to your manual
Posted on May 14, 2009
  • 10865 Answers
SOURCE: I have a craftsman riding lawn mover 42" model #917270812
Hi Paul It sounds like the belt is worn, stretched, or possibly just two long for your machine. Save yourself a lot of aggrivation by checking your operator manual and getting exactly the right belt for your mower.
You don't say how old your machine is but if it has been mowing for many, many hours, the tensioning spring may need to be replaced. If that is the case you can order a new one at Sears.com
Posted on May 20, 2009
  • 95 Answers
SOURCE: blades became disengaged -- won't engage
Sometimes the belt can jump off one pulley and cause the problem,follow the belt around all the pulleys and see if it came off one.there may be a belt loosening lever on the lh side of the mower deck, if so unlock it and reroute the belt around the pulley. If you need to replace the belt the manual has a good description on how to do it and should take 30 min with only a couple of tools.
Posted on Jul 30, 2009
  • 138 Answers
SOURCE: My Swisher Rough Cut 12.5 HP 44 Inch mower - The
I dont believe there is a shear pin on your blade spindles, what I have found on these machines is the the spindle nuts on the balde spindles sometimes loosen or wear and no longer squeeze the pulley on the blade spindle. To make this process easy on your self you need to tighten these with a impact wrench. However if you dont have access to a impact wrench you can use hand tools and block the blades you are trying to tighten with a wooden block. Just make sure you block the blade you are trying to tighten
Posted on Aug 30, 2009
What will cause blades on J.Deere G100 mower to Freely turn by hand without causing Spindles or belt to turn even though Bolts are still tight and when installed Blade turned only if spindle turned
Do Ray:
If the blade engagement lever is in the disengaged position, the belt will be loose, allowing you to turn the blades by hand. If you place the blade engagement lever in the engaged position (with the motor off) it will be hard to turn the blades because of the tension on the belt. If the blades are still easy to turn with the blade engagement lever in the engaged position, you need to replace the blade drive belt!
Jun 15, 2015 | Garden
The blades on my cub cadet 1042lt are hitting each other. This is causing knotches in the blades. I was told to have blades at 12&6 and 3&9? Would I need to change one of the belts, if so which one?
who ever told youy 12 and 6 and 3 and 9,is crazy in the head,the first time you hit heavy grass on one side,that will change,the problem is your blades,your blades are probably 22 inch,they need to be 21.2 inches,and if they are,then your spindles have moved and you need to fix thathere is your parts list,and pics of the blades you need, Cub Cadet LT1042 13AX11CG010 Cub Cadet Lawn Tractor 2008 after Mower Deck...
May 11, 2015 | Cub Cadet Garden
I have a poulan pro PR1842STC; the blades won't stop turning after I disengage the mower belt
On the top of the mower deck, there is a spring that will pull to disengage the blade idler pulley. At the same time, it will release two springloaded arms with brakes that press on the pulleys at the top of the blade spindles. On top of the mower deck at the back, the two spring loaded arms may be held out of the braking position by a cam. Make sure the cam is free to allow the blade brakes to activate when you disengage the blades. If arms are out of alignment, or the parts are too worn, the blade brakes won't move and the blades keep spinning, even after you have disengaged and the safety switch is deactivated. This is a dangerous situation and should be fixed soon. Good luck.
May 09, 2013 | Poulan Garden
Sears Craftsman rider mower bought in 2001. Still runs really great. However, lately it will not cut the grass when I lower the deck to positions 1-3; the blades seem to stop; no cutting action at all. As...
Do the blades need sharpening? Check the belts for tightness and the spring that holds the tension. what stops? The blades stop, but the belt is still turning? Check to also make sure the blades turn freely with the belt disengaged. you may have a spindle problem too.
Jul 23, 2017 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Zero turn cub cadet mower, deck keeps clogging with grass
do you have the right blades for bagging ?is the deck belt slipping?
Apr 22, 2012 | Briggs & Stratton Garden
John Deere L110 blade brakes wont stop blades from spinning
Are the brake pads on brake levers good? May need replace levers.
Apr 01, 2012 | Garden
We are replacing the wiper blade motor on a 2003 Hyundai Elantra and it's not clear how to set the wiper blades to be properly timed. There is nothing in the manual and currently it's falling about...
what i do is mark the old motors position and fit new one but you havent done this mmmm? where its stops mark and if it was a clock ie 3oclock move connecting arm back to 12 or forward to 6 this always works for me keep going ontil its set ... be carefull with the paint work lol ......
Sep 07, 2011 | Hyundai Elantra Cars & Trucks
My LT 1000 was working fine, and then the blades stopped going. When I backed up and waited a minute - the blades began turning again. Everytime that I hit some higher grass, the blades stopped again. ...
Hi. It sounds to me like the belt that drives the blades are worn. Take note of the routing of the belt, or take a snapshot with a camera, and remove the belt for a sample at your spares shop. Hope this helps
Jul 09, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Replacing dual blades When they are put back on, do they need to be positioned to counter-rotate???
Im not sure if counter rotate is the term. Both blades will turn in a clock wise rotation and do not have to be timed. There is adequate clearance between the blades to prevent them from contacting one another.
Good luck.
Regards,
Aug 28, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Replacement blade position.
The blades have such a close tolerance tip to tip on a V belt deck that it makes no difference where they are positioned, On a 3 blade deck the center spindle is forward of the two outer spindles. So for that reason you still get a quality cut. Most all commercial units use a V belt and have a good quality cut.
Some john deere mowers have a timing belt with cogs like a car and their blades have to be in time
90 degrees perpindicular to each other and locked down and if you strike something then the timing will be off and your back working on your mower instead of cutting grass,and the belts are twice as expensive than a v belt.
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
