Question about Welding Tools
Why my PUK 111 has no welding power?
Hi, My PUK 111 has no welding power when turned on (the operational signal is constantly red). Now I can use it by pressing reset button. But it comes more and more difficult to reset it. Now it resets only after a few attempts. Have any idea what is the problem? Thanks
SOURCE: how do i reset my Panasonic nv-gs70
It is on the Right hand side of the camera, just underneath the finger grip. Next to the Auto|Manual Fucus button... about 2 cm to the right.
Hope that helps
Posted on Jan 20, 2009
Lando93
  • 8 Answers
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
SOURCE: puk 111 welding problem
Mine was doing the same, spoke with the technitions and they told me to undo the connector from the hand piece to the machine at the machine, you then need to disassemble this connector and look to see if one of the white wires is dissconnected, if so you need to carefully push the gold plated pin out the back of the connector towards the cable, solder the wire back on and reassemble and it should work.
If not contact the head office and they were very helpfull.
Cheers Robert
Posted on Aug 18, 2009
  • 17 Answers
SOURCE: iphone wont turn on
hey mate.. what you need is,
Turn on your itunes, and when the iphone is off, press the round button (home button) for 15seconds and without releasing the button, plug it in your computer with itunes running.
Once you see the startup of the iphone, release the home button.
Then after that click shift on the computer to restore to the previous version.
good luck..
Posted on Sep 11, 2009
  • 62 Answers
SOURCE: Hi can you help ? My zebra TLP 2824 printer keeps
If you are using a ribbon remove it and perform a calibration, hold down feed key for 2 seconds as you power on, release key and wait for it to complete its calibration, when it has stopped shifting labels (wait for 10 secs to be sure) HIT THE FEED KEY to exit dump mode. If it has successfully calibrated it will feed a label each time you hit feed key. Re-install ribbon, make sure ribbon is pushed formly onto drive sprockets and then re-run the calibration..
If this does not fix problem. download firmware to latest version. This will automatically reset printer to factory default condition.
Posted on Nov 20, 2009
HOW TO ADJUST CONSTANT CUT-IN THERMOSTAT MODEL WDF 10A-111-122
Part number WDF10A-111-122, 01.D6249A.Z, 5(4) A 250V. Foshan Tongbao Co. is a Temperature (cool) sensor with switch; When it turn CW it drops temperature to cool, while turning CCW it rises water tank temperature.
Apr 17, 2012 | Cars & Trucks
New at welding jewelry. was given a puk 111. have not got the argon as yet. should the unit still produce an arc even without the gas? i have no arc at any of the settings. what am i missing. thanks.
Argon is an inert gas and in welding is used to produce a shield around the weld. It protects the work from impurities. The arch comes directly from amperage shorting to ground through the rod. The heat generated from this short melts the rod into the work. In short, the welder should work without the Argon and needs only Amperage in the rod and a good ground to create an arch. Double check the ground on the work. In this case, your Ring. Please rate this answer for me and feel free to write again. Thank You.
Roger
Apr 03, 2011 | Welding Tools
Universal remote I need the code to a Sharp TV
Hello
Three digit universal remote code for Sharp TV are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four difit universal remote code for Sharp tv are:-
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON your TV with its front panel power ON/OFF switch each time before trying an other code.
Mar 01, 2011 | Televison & Video
My sim pin code is blocked &i want my puk code
hi friend IF your sim pin in blocked you just call up your network provider and ask them to give you your puk number after a short query they will give you your PUK number then you can easily unlock your phone and sim, for airtel dial 198 or 121 for vodafone dial 111 for reliance dial *333 for aircel dial 134 NOTE do not try your puk number more than ten times otherwise your sim will be locked permanently
Nov 08, 2010 | Nokia 1208 Cellular Phone
Aircel puk code
Just dial 111 using other aircel mobile to contact customer support. The PUK code must be given by the network support in able to unblock again the SIM, please do not enter more than trice of the PUK code or do not eventually guess the code it will permanently block the SIM and you will able to use it again.
By the way what exactly the location or country you are located in, so if there no other aircel mobile available to contact directly the Operator, i'll try to look their trunk line number where you can also contact with them.
Let me hear from you again here..
Thanks
Feb 23, 2010 | LG KG800 Cellular Phone
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Puk code of n 72
Hi buddy,
If u need the puk code then u have to take it from ur network customer care center like 121 fro airtel, 111 for vodafone.
Aug 05, 2009 | Nokia N72 Cellular Phone
Puk 111 welding problem
Cheers Robert
May 25, 2009 | Welding Tools
How to damage nokia N72 lock code
you required a PUK (personal unblocking key) becuase you put 3 times wrong pin. call your operator and they will provide you puk after asking your mobile number and sim number (you can find it backside of your sim) they will give you 8 digit puk than you have to put this. after this you can put new pin.
Jan 01, 2009 | Nokia N72 Cellular Phone
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
