Question about Stihl Garden
Looking fo a new Carburetor fo my Stihl FL72
I cant find a replacement Carburetor for my Stihl FL 72
  • 140 Answers
There are a number of companies that supply replacement carburetors that I have used on the internet.
Posted on May 31, 2014
STIHL BLOWERS BG 56/C and BG 86/C
I don't have much experience with Stihl products but I do have a couple of disc cutters, both of which had a short life and suffered piston damage.
I suspect the air cleaner isn't as efficient as it should be.
Apr 26, 2017 | Stihl Garden
Stihl FC 72 Edger. The little plastic switch is preventing the pull cord from spinning. How do I fix it?
BUT THE PLASTIC part is looking good ? also " If you can turn it easily ofcourse " its looking 100% the spring looks good but how are the cams on the choirturd ? or the movement of start spring? there is i think the problem
Aug 09, 2015 | Stihl Garden
Stihl ts400 starting problem
sounds like your getting air leak around a gasket
Jan 30, 2018 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Parts for a stihl bg 72 carburetor
Make your own.
Pull carb,use thin paperboard,punch 2 holes for carb mount and place on carb,lightly tap on carb throat to make an outline of where you need to make big hole.
I use steel tubing and punch small holes over a block off wood.
The big hole a a bit tougher to make perfect.
Nov 16, 2012 | Stihl Bg72 Leaf Blower Intake
Need parts diagram fo bg85 stihl blower
You can't have one, but what are you looking for, I can get you the part number because I am a STIHL tech and have all the breakdowns. I also have two of these blowers.
Jul 26, 2011 | Stihl Garden
Need to know belt size fo the stihl ts400 concrete cutoff saw
You should go to a Stihl dealer and ask for the belt for a TS 400 Cut Off Saw. The belt is ribbed, you should only put on a Stihl part to replace the belt and make sure the belt is under the correct tension. When you go to the Stihl dealer you can ask them to show you how to make sure the belt is under the correct amount of tension.
Aug 31, 2010 | Stihl Ts400 Cut Off Saw Carb Carburetor...
I need to rebuild the carburetor on a Stihl Model 025 chainsaw. An exploded view diagram would help.
I don't have a diagram or the part numbers to the minor and major repair kits, but a Stihl dealer should be able to help. Tell him you need a kit for a ZAMA C1Q type carb. The exploded view should be with the kit.
May 19, 2010 | Garden
Stihl st410 , after first pull it fires then turn...
Remove the carburetor and open the lower chamber--check the condition of the diaphragm and fuel metering valve--either of which can cause flooding. The diaphragm should be flexible and not cracked or have holes in it. The metering valve point should be in good condition. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. This information applies to nearly all saws even with other brands of carburetor. When you have the carburetor installed, remove the spark plug, open the throttle fully, choke and ignition switch off, then pull the engine through to expel the excess fuel from the engine. Reinstall the plug and attempt to start normally. Hope this helps!
May 17, 2010 | Garden
Will run at rough at idle but won't take any fuel
This isn't a 100% solution, but a saw only runs as clean as the air filter, and they get dirty quick. I give my air filters a quick wash about 5-7 times with just soap / water.
If that doesn't do the trick, your probably looking at some kind of carburetor issue.
May 24, 2009 | Oregon Scientific Oregon Chainsaw chain...
Garden Logo
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
