Turn compatibility mode off - Audio Players & Recorders
How Do I TURN-OFF "COMPATIBILITY-MODE" in Windows 8.1
Right click the setup.exe go to properties and you wil be able to turn off compatibility mode off there
Nov 24, 2014 | Computers & Internet
Which compatibility mode are you wanting to disable? For a web browser or a program?
Jul 16, 2014 | Dell Computers & Internet
Error 50 appears when trying to open itunes after update install
Uninstall it, then Unblock the setup before you run it,(right click on the setup, Unblock/Apply. Temporarily turn off any Antivirus program when you re install it. And you can run it in Vista compatibility mode, see if you still get any errors then. (right click on the programs icon, properties, compatibility tab, Run this program in compatibility mode for: Vista SP1/Apply).
Feb 26, 2011 | Computers & Internet
Have easy share program easy share appears to be running in a compatibility mode for and older version of windows. how do you turn off compatibility mode
If you right hand mouse click n the programme on your desktop, if it will run in normal mode, there will be an invitation to change to normal mode.
If you are running Vista or Win7 that'll probably be why.
Jan 12, 2011 | HP Pavilion dv6000z Notebook
Unable to install 3.1 in windows7
install the app as admin. then go to the installed apps propereties and tell it to run as a xp app in compatibility mode
How to Use Windows Application Compatibility Mode Published: October 25, 2001
This article describes how to use Windows Application Compatibility mode. This mode provides an environment for running programs that closely reflects the behavior of earlier Windows operating systems.
Using The Windows Application Compatibility Mode
When you use Windows Application Compatibility mode, many of the most common issues that prohibit earlier versions of programs from working correctly are resolved. If you run a program and it does not function as expected, it is recommended that you run the program in one of the compatibility environments.
To run programs in Windows Application Compatibility mode in Windows XP
  1. Right-click the icon of the program that you want to fix.
  2. Click Properties.
  3. Click Compatibility tab.
  4. Click Run this program in compatibility mode and select one of the following options:
    • Windows 95
    • Windows 98 / Windows Me
    • Windows NT 4
  5. Under Display settings, check the mode that you think is necessary for the program to work correctly:
    • Run in 256 colors.
    • Run in 640 X 480 screen resolution.
    • Disable visual themes.
  6. Click Apply.
  7. Click Ok.
  8. Double-click the program icon.
    Note The Compatibility tab is only available for programs installed on your hard drive. Although you can run the Program Compatibility Wizard on programs or setup files on a CD-ROM or floppy disk, your changes will not remain in effect after you close the program. For more information about an option on the Compatibility tab, right-click the option and then click What's This.
Oct 30, 2010 | Primavera Project Planner P3 (PRIMAVERAP3)...
Itunes .exe has been set to run in compatibility mode for an older version of windows. i already tried to change version but cant find windows 7 version also turned off compatibility still no luck
Unfortunately, even though I'd turned off compatibility mode for iTunes (by right-clicking the iTunes icon, choosing Properties, clicking the Compatibility tab, and clearing the Compatibility mode checkbox), the program generated this irksome message every time I ran it:
iTunes.exe has been set to run in compatibility mode for an older version of Windows. For best result, turn off compatibility mode of iTunes before you open it.
Sigh. Stupid Windows. Or maybe stupid iTunes. Either way, compatibility mode was "off," but iTunes didn't think so.
Fortunately, I finally found a solution:
1. Make sure iTunes isn't running.
2. Click Start, type regedit, then press Enter.
3. Navigate to this Registry location: HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry.
5. Start iTunes. The offending message should be gone!
Dec 16, 2009 | Apple iPod MA446LL/A MP3 Player
Can't get on Easyshare
Try the steps below.
1. Right-click the EASYSHARE icon on your desktop
2. select Properties.
3. Select the Compatibility tab.
4. Clear the Run this program in compatibility mode check box.
5. Click Apply, then OK.
Thanks.
Regards,
Neerak21
Sep 24, 2009 | Kodak EasyShare One Digital Camera
CivilizationII test of time
If it doesn't work the regular way, try installing and playing in compatibility mode. To install in compatibility mode right click on setup -> properties -> compatibility tab -> check: run this program in compatibility mode; to play the game in compatibility mode do the exect same thing ond the game executable file
Mar 17, 2009 | MicroProse Civilization 2: Test of Time...
20 people viewed this question
 Grubhead
Grubhead
