Question about Fisher and Paykel Fisher & Paykel Washer
I have a Fisher & Paykel Smart Drive 9 - 6.5kg top load washing machine...model# GW609AU. Will not fill at startup, only short bursts, then shuts down. Can this model be reset?
  • Nick Stewart-Reid May 11, 2010
    hi there it sounds like your machine is faulting out, when it stops does it start beeping and a series of lights come up?
  • 86 Answers
The problem will be one of two switches the magnetic lid switch under the right side of the hob or the out of balance switch located under the main motor conctroller board in the head ,Check this one first.Hope this helps Cheers.
Posted on Jul 30, 2009
  • 205 Answers
Can only be reset by unplugging... Sounds like a bad controller or poor connection. Try different water temps, it same problem will need to call a Technician. F/P can tell you who is authorized to fix it. 888.936.7872
Posted on Jul 21, 2009
Fisher paykel washing machine fuse smartdrive
All Fisher & Paykel top load washers have 4Amp fuse for 240vac.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
Smart drive 051 error code 32
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Fisher and Paykel Washing Machines
I have a Fisher & Paykel GW609AU washing machine
keep it simple, make sure water is on to both hot and cold hoses. Trip switches for door (and sometimes soap draws) can prevent machine working. Try asking a few logical questions. Has the machine been moved recently? If its out of level this could be a problem. Check solenoids are working (these are electrical taps at the back of machine which hoses hock up to), to do this try both hot and cold settings. Even try changing water level settings to further attempt to deduct were problem might lie. hope this helps and let us know how u go
Aug 08, 2011 | Fisher and Paykel Washing Machines
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
Our F & P GW508 Smart Drive starts to fill at
Sounds like your out of balance switch is corroded. It is located underneath your gold motor controller board.
May 27, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
F & P Smart Drive Model MW0I5K - BEEPING
If the washer is also filling slowly it's likely to be the hot or cold water solenoid (either one or both - not that an expensive a repair)
Jun 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Mar 12, 2008 | Washing Machines
Washing Machines Logo
874 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
