Sony bravia series
What started out as having a flicker on TV & later would stop & now has large black spot, covers one person on right side of screen?
  • Darlene Middleton
    Darlene Middleton May 23, 2014
    I have a Sony Bravia KDL-Z464100. It had started flickering, then it stopped & went to a darker screen w' a large black spot covering 1 person & also has a few vertical lines on right side in pink & lilac.
    Would you please let me know what you think!
    Thank You, Darlene Middleton
    darlenelilac@verizon.net
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
What is the model number to your TV? Is it an LED LCD TV? Anyway, the fault is related to its back light. Contact the authorized service center for Sony. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on May 12, 2014
Testimonial: "I have a Sony Bravia LCD Digital TV/ Model/ KDL40Z4100/"
SOURCE: audio issue with Sony Bravia tv
Each time our TV starts the snapping sound we reboot the cable box. Problem solved.
Posted on Jan 15, 2008
  • 129 Answers
SOURCE: Sony Bravia TV went Blank
COULD BE LVDS CABLE LOSE OR NOT MAKING A GOOD CONTACT , IF IS NOT THAT UNFORTUNATELY IT WILL BE NECESSARILY TO REPLACE T CON BOARD
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
THANKS
Posted on Jun 29, 2008
geemarie
  • 876 Answers
SOURCE: Big grey/black spot
Is it a fuzzy spot or an actual hard edged black spot?LCD televisions can have a loss of pixel display- most very small. Was the TV hit with something or dropped against something (the screen)?
OR Try this first:
Black box appears on the screen
• Closed-captioning might be on. Check the Analog or Digital Caption option in the Setup menu.
Please let me know if your problem is solved. Thank You.
Posted on Aug 15, 2008
  • 68 Answers
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Posted on Nov 28, 2009
SOURCE: my plasma tv has blue or black spots (scattered on
I am facing the same problem with my LG 32 inch plasma TV. There is also a big 2inchX4inch oval black spot at the top centre of the screen. Please suggest any remedy and also the cause. mbkhurshid@gmail.com
Posted on Dec 30, 2010
My tv just shows red light flickering but no picture how can i fix and what may be the problem
Maybe no video input. Check connections! Also maybe INPUT on TV is set to wrong input connector.
Feb 16, 2015 | Sony Bravia Kdl-40ex500 Series 40-inch Lcd...
I have a Sony Bravia LCD Model KDL-Z464100,it started flickering & then went away, now it is a dark screen w' a large black spot covering one person & has a few vertical lines on right side that...
Hi Darlene, unfortunately this sounds like a panel defect. This has happened before with the very same model. To be sure I would try and do a factory reset (search your model, there may be a key sequence reset) on the unit or try leaving it unplugged for a while to see if that helps. But if you are within warranty I would get Sony on the horn immediately!
May 24, 2014 | Televison & Video
Horizontal lines flickering at the bottom of screen...... SONYbrvia KDL-32L 5000
Hi Freddy Pagan
I like your Sony TV is defective that it cannot be fix again, better call the Customer Support to replace your Sony TV.
I hope my solution may help you.
Thanks for using Fixya...;-)
May 06, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Lighting
You have a bad Panel, but here is the good news. Sony will cover this until Oct 31, 2012. What you will need to do is check your TV into service. You might have to pay a deposit, but you will get it back. The servicer will then contact Sony and then Sont will contact you to make arrangements on getting you a new TV, because they are no longer replacing this panel. Congrats, you are getting a new TV.
Jun 20, 2012 | Sony Bravia XBR-Series KDL-46XBR5 46-Inch...
Sony bravia, large black box in center
Go into your menu and look for Closed Caption. Turn it off. That's it!
Mar 02, 2012 | Sony Bravia KDL-42V4100 42 in. LCD TV
I have a black approx 12 inch streak on the left side(facing tv) of my flat screen Bravia Sony TV . It is approximately 3 years old. It started as a brown panel..then became a fine lined multy colored...
sadly you have a bad panel. Sony panels carry a two year warranty.
your best hope is to call Sony and ask for a warranty extension to cover the cost of the part.
Apr 12, 2011 | Sony Bravia KDL-40Z4100 40 in. LCD TV
We have a sony bravia 46" tv. Model number KDL-46W4150. It is 2 years old and has now developed black lines on the right side of the picture.It goes half way across the screen. It is like this when...
That sounds correct, I just have to work on SONY BRAVIA KDL-40BR4 with Horizontal lines problem on ther right side, you you tap around the frame, the lines will come and go, this is only 2 years old TV! Poor quality panel made by SONY/SAMSUNG company jointed venture.
Very sad indeed when you paid for BRAVIA series which are not cheap.
New screen will cost more than new TV.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Feb 15, 2011 | Sony BRAVIA W-Series KDL-46W4150 46 in....
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
