Question about Coverking CSC1P1VW7031 Seat Covers Volkswagen Golf / Golf GTI 2002-200
My car starts and immediately switch off
When I start my car it starts but immediately switches off and the light with the car and key flickers
    Problem Solver:
  • 14 Answers
It may be a wire disconnection problem.
Posted on May 12, 2014
Turns over, but why doesn't it start with key?
Last month, my car wouldn't start when I turned the key and it was because the engine was busted. I would hear a bit of a rumble and then I would hear nothing. However, if you can't hear anything, then it is probably an issue with your battery. Did you leave your lights on in your car the night before? When you leave your lights on, it drains the battery and makes it so your car doesn't start. Auto Repairs
Jan 31, 2016 | Cars & Trucks
Possible ignition switch problem?
Ignition switch is likely worn out making intermittent contact.
Jan 28, 2016 | 2003 Buick Rendezvous
2000 Rodeo: No Crank, No Start issue. I have bumped the gear shift and bumped the steering wheel to get car to immediately start. I even switched keys one time and Rodeo started immediately. Repair sh
Many keys today have a microchip in the key itself, and if the chip has malfunctioned the car won't respond normally. Your second key working is proof the trouble is in the key not the car. I think they can be checked in some Autoparts stores.
Dec 04, 2014 | 2000 Isuzu Rodeo
My 2000 bravada oldsmobile wont start is it the sartaer
It depends upon what actually happens when you turn the key. If the engine turns over, but doesn't start, it is NOT the starter. If all you hear is a clicking sound, or the starter motor engages but doesn't have the power to turn it over, then it could be wither the starter or the battery. A quick and easy check when this happens is to turn on the interior light. If, when you turn the key and get the click or no activity, the interior light dims way down or goes completely out, it is probably the battery. If you turn the key and get nothing at all, things are more difficult. The interior lamp test should be performed. If the light goes out immediately, try the battery. If the light doesn't flicker or dim at all, then the problem could be the starter, the starter relay, the Park/Neutral Position (PNO) switch, the ignition switch, or the IGN E (Fuse 22) or IGN A (Fuse 34) fuse in the fuse block under the hood.
Nov 10, 2013 | 2000 Oldsmobile Bravada
Ceiling fan lights flicker in bedroom with 23watt cfl bulbs
Sounds like an older unit that has either a dimmer or electronic switch. You need to use dimmable CFL lamps.
Nov 07, 2013 | Hunter Dryers
Car not starting, battery charged by son's car, still wont' start.
More than likely its your ignition switch going or gone bad. Ok, here's what you do, turn the key to the on position but DO NOT CRANK, let the key stay in this position until the security light stops flashing (takes 5 to 10 minutes) then turn the key off and crank it immediately after. If your car cranks then you will need to replace your ignition switch ($120 to $160). Hope this information helps someone. .
Jan 22, 2013 | 2001 Chevrolet Impala
Hello, just recently started having a problem with my 98 grand prix gt headlights... while im driving at night my headlights will shut off and start to flicker after about 10 minutes of driving... if i...
COULD BE FAULTY DRL HEAD LIGHT RELAYS OR FAULTY DIMMER SWITCH.SINCE HEADLIGHTS TURN ON AUTOMATIC.TRY USING MANUAL HEAD LIGHT SWITCH ON TURN SIGNAL SWITCH LEVER SEE IF HEADLIGHTS STAY ON IF LIGHTS STAYS ON YOU HAVE FAULTY DRL HEADLIGHT RELAY.IF LIGHTS STILL FLICKER OFF.YOU HAVE BAD DIMMER SWITCH.
Jun 09, 2011 | 2006 Pontiac Grand Prix
My headlights and dash lights are starting to flicker on my 2002 Buick Century. Once in a great while the headlights go completely off for just a split second and then immediately come back on.
It probably has a bad headlight switch or the connector that plugs into the back of the switch is burned. The burned connector will cause a bad connection.
Dec 17, 2010 | 2002 Buick Century
My instrument panel, parking lights, and taillights flicker simultaneously. they are all ran off the 'park lamp relay' on my 2002 dodge dakota. my headlights are fine. the conflict is intermittent and...
relay coil may be a bit weak and is sharing power with the headlight relay. Try swapping the relay with the horn relay or another similar one that is non-essential to operation of the car. If that doesn't work, you may have a loose wire on the headlight switch or at the relay socket.
Dec 05, 2010 | 1997 Dodge Dakota
Flickering lights
The e-brake light problem is causing your headlight issue.
The e-brake switch is supposed to turn the lights off for you if you are parked and don't want them on.
Make sure your e-brake is released all the way, if OK, check the switch at the E-brake, it will have a single tan wire connecting to it. If you disconnect the wire the headlight issue should go away and you will know it is the switch. Make sure you have the key in the off position so the module resets.
Good luck, let me know.
Regards,
Mar 08, 2009 | 2001 Chevrolet Cavalier
Coverking CSC1P1VW7031 Seat Covers Volkswagen Golf / Golf GTI 2002-200 Logo
77 people viewed this question
Top Coverking Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Coverking Golf Expert? Answer questions, earn points and help others
