Question about Canon Office Equipment & Supplies
Canon ir2880 error code e808 - Canon Office Equipment & Supplies
  • NickCWA
    NickCWA May 12, 2014
    Hi Alfred mensah, I want to help you with your problem, but I need more information from you. For example, what does the computer do to make this error? What do you see when the error occurs? any text in the error? where is the error displayed (desktop?) what Operating System are you using? Also why not contact Canon Support?
  • 18 Answers
SOURCE: canon ir2016 error E808
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the fixing drive motor.
- Replace the DC controller PCB.
- Replace the power supply PCB.
Posted on Jul 17, 2008
goodgold
  • 389 Answers
SOURCE: system error E808
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540 0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542 0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744 0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
Posted on Mar 23, 2009
  • 66 Answers
SOURCE: my canon ir 1018 displays this error code e808 and does not print
has the machine been serviced recently? if not, unplug machine for 10 mins, then plug back in. if the code comes back the fuser assembly will need to be replaced.
Posted on Apr 13, 2009
SOURCE: i have Canon iR 2016 it show E808 code error
i have canon Ir2016 it give 808 error code can u help me please
Posted on Nov 22, 2010
  • 525 Answers
SOURCE: i have an System ERROR E001 following Error E808
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
detected.
Posted on Feb 19, 2011
Error code E000110-0000 of the copier IR2880
Hi. That error is related to the laser unit . Mabye the shutter of the laser unit is malfunctioning
Jan 19, 2018 | Canon Office Equipment & Supplies
I have Canon iR 2016 it show E808 code error
That error is related with the fixing unit. Check the connectors or replace the fixing film assy
Mar 25, 2015 | Canon IR2016J
Canon ir2018 error e808 how to clear
To clear the E808 code unplug the machine for about 10 minutes. If the thermistors are bad the code will appear but will not reset until the fixing film assembly is replaced. If you have tried to repair this machine, make sure you have not left the connector unplugged.
Jul 30, 2014 | Canon Office Equipment & Supplies
Give solution for canon ir 5050 error code e808-02
See here.
http://www.copytechnet.com/forums/canon/53715-ir5075-e808-002-a.html
Jun 19, 2014 | Canon ImageRUNNER 3570 Copier/Printer
I have a canon ir2016i and it reads system error e808
E808-0000 DRIVE CIRCUIT FAILURE
A zero crossing signal cannot be detected.
A fixing drive motor failure has been detected.
- A fixing drive motor failure was detected.
If you are not a tech I recomend that you contact one in solving your problem.
Nov 17, 2010 | Canon Office Equipment & Supplies
Error 001, error 808
the e001 code is something is going with the fixing assembly. one of the thermistors could be going bad.
E808 is a Zero Cross error. We most commonly see power supplies or bad wall voltage cause this code.
The following information is coppied from the IR2016 Service Manual.
  • The heater does not turn on.
  • A fixing drive motor failure was detected.
  • Check the connector of the fixing film unit.
  • Replace the fixing film unit.
  • Replace the fixing drive motor.
  • Replace the DC controller PCB.
  • Replace the power supply PCB.
M201 - Fixing Drive Motor - FK2-1067 - J202 on the DC controller PCB - E007, E808
Power Supply - FK2-1074
Jun 14, 2010 | Canon iR 2016i Black and White Copier
May 29, 2010 | Canon iR 2016i Black and White Copier
Code E808
This problem was solved by turning off the unit and unplugging the power overnight. The next morning it worked fine.
Jan 15, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Canon ir2016 error E808
detected.
Apr 29, 2008 | Canon PC-940 Black and White Copier
22 people viewed this question
old marine
old marine
