I have a Presario CQ43 that won't wake up when I open the laptop. I have removed the battery and turned it on and off and I even plugged in an external screen. How can I wake it up? Is it the sensor that puts it to sleep when you close it?
  • 84 Answers
Have you tried holding the power button and escape down while powering on till it gets into bios or os options? It may be power plus repeated pressing of f1 to f12 buttons to force the computer to go into os options.
Posted on May 12, 2014
  • Laura Jane May 14, 2014
    Did not power on at all
Gateway NV52 won't wake up.
Is it clean? fan and vents? Unplug, remove battery, leave battery out, plug in, reboot. If that fails, Re Boot and try a System restore/recovery to a date before this issue. OR, Boot to Safe Mode, use this procedure to select Normal Boot: http://www.netsquirrel.com/msconfig/msconfig_win7.html When/If you get a Normal Boot, Open Control Panel, Power Options, select High Performance, select Change Plan settings, set plugged in both to Never, set advanced setting to your preference. Use this procedure: http://windows.about.com/od/customizingwindows/ss/set_power_options_all.htm Always shut down and unplug your laptop when not in use, remove battery when you use on AC, your Laptop/components will last longer, and will not be subject to possible power surge damage and the battery, IF it malfunctions will not cause a fire hazard.
Mar 01, 2013 | Gateway NV5214u Notebook
When I put the laptop to sleep, it won't turn on when I go to wake it up
Turn off the hibernation feature. The only way to fix this issue is to upgrade the firmware on the motherboard. Simple to do but you run the risk of ruining the motherboard is you do it wrong.
Dec 27, 2012 | Compaq Presario F767NR Notebook
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
Compaq Presario CQ61-313US Notebook PC won't power
try to remove first your battery and use only the adapter.
Sep 09, 2011 | HP CompaqPresario CQ61310USE Notebook
It keeps turning off, I have tried my friends power cord incase that was the problem but even with her cord it turns off, and just before that says that I need to plug the charger in even though it is...
ok sounds like your battery has gone bad.
try this test: remove battery plug computer into the wall.
boot computer if it boots up and stays on you will need a new battery.
Nov 13, 2009 | Compaq Presario R3000 Notebook
Compaq HP Presario F572US just turned off.
Remove the battery and plug laptop power into the wall (or power strip).
Turn ON laptop without battery.
It should start.
After Windows has settled, put battery back in and let it charge up.
Hope this helps!
Sep 08, 2009 | Compaq Presario F572US Notebook PC
My mac laptop doesn't wake up from standby/sleep
Check out these possible solutions:
http://www.christopher-chan.com/blog/index.php?/archives/588-Macbook-Pro-wake-from-sleep-problem.html
Jul 10, 2009 | Apple MacBook Pro 17 Notebook
Presario 2100US not powering up
remove power supplay
remove battery
press and hold power button for 1 min
release button
plug the power supplay
turn on laptop without battery
Feb 21, 2008 | Compaq Presario 2100U Notebook
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
