Question about Konica Minolta bizhub Office Equipment & Supplies
What causes shadows on copies from a bizhub c550
Leaving dark images on paper
  • Konica Minolta Master
  • 6,674 Answers
The fuser (The Hot Part) replace it.
Posted on Dec 29, 2015
SOURCE: Can't Scan anything on a BizHub C550 to 5 pcs on the same network
Be sure that your Domain name is in the network settings on the printer. This can be done on the printer itself or opening a web browser. Put the IP address in the address bar of the browser, this will conect you to the machine. Log off the public domain that come up and log on the administrator area. Enter the password 1 2 3 4 5 6 7 8, unless it has been changed. There you will be able to set all of the network functions. The machine need this information in order to direct the scans to the correct place.
Posted on Jan 06, 2009
SOURCE: Socket Connect Error on BizHub C550
Select HTML on the Pagescope login page.
Posted on Mar 09, 2009
SOURCE: HP 2300d laserjet printer leaving dark backround shadows on paper
Probably a defective toner cartridge.
Posted on Apr 11, 2009
  • 990 Answers
SOURCE: I have a Xerox Copier XC1045. Our copies are
Hello sir; That problem not caused by toner, is by drum cartridge, replace it will take care your problem.
Posted on Apr 23, 2009
  • 17 Answers
SOURCE: The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Posted on Jul 07, 2009
I have bizhub c450 , printing time devoloper comin on edge of paper , my imaging units are nes
Removed all imaging unit then below you will see PCL in every imaging unit you must clean it with soft cloth completely. When PCL is covered with dust,toner,dev etc.. the developer from your imaging unit become to fall causing developer on edge of paper(dirty copies).
Dec 26, 2014 | Konica Minolta bizhub C450P Laser Printer
Konica minolta bizup c550 printing black copy what will i do?
The corona housing for the back drum need to be replaced. Get a new black image unit drum and developer units
Aug 15, 2014 | Konica Minolta Bizhub C 353, Bizhub...
Konica Minolta Bizhub c550, reads 2 codes 225B & 6751 I know it needs a power supply, but it makes a grinding sound, jams constantly, leaves imprint marks on paper, colors bleed & will not pri
Why do you need a Power supply? Neither codes deal with that. The 6751 is dealing with your scanner CCD which is located under the big glass on the right side that large black item. It could be bad or needs a alignment, the second deals with the Black image unit and or toner for black using 3rd party????? or OEM toners. Replace both he black image unit and black toner using OEM not 3rd party. As for jamming where does it jam? When was the last time the draw rollers where clean and or replaced? When was the last time the machine was cleaned, Gradation? and Registration? test done. Image units toned up? High end copier likes this needs to be keep up!!!!!
As for the imprints replace the FUSER UNIT (HOT PART) What color Ink bleeds replace that color image unit.
May 13, 2014 | Konica Minolta bizhub C250 All-In-One...
I have konica minolta bizhub c550,it showing me P21 and P6,what is the causes?and the black is not printing well
P6 : cyan image unit problem. P21 come after P6, and it's also too a cyan unit image problem. replace the cyan image unit.
Nov 18, 2013 | Konica Minolta Bizhub C550 Color...
How can i settle the problem of magenta developer finishing so fast. Magenter developer for Konica Minolta Bizhub C550 is getting finished so fast.
If the message Change Imaging Unit Magenta displayed refer to imaging unit with contents a developer.The Imaging unit life is 80.000 copies.
The imaging units located after front door when is located the waste toner box.
If the message M toner end/change the M toner displayed refer to toner cartridge
The toner cartridge life 15.000 copies 5% saturation.In full color mode the color saturation is 80% and the color toner life is 6.000-8.000 copies.
I think your problems is a toner not the developer.
Apr 11, 2013 | Konica Minolta Bizhub C550
Where can i find,please, Minolta bizhub c550 imaging unit chip reseter?
Imaging unit reset automaticaly if a new is in copier.If you enter in the service mode you have a posibility to change the image unit life duration standard to long life.
Jan 24, 2013 | Konica Minolta Bizhub C550
Konica Minolta dirty copies
remove the filter and housing from the i/u and vac out the spilt developer, do the same on the underside, if background/halo is still there increase the seconary transfer value by 2 for plain paper
Jun 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
