Question about Fellowes 2127c Paper Shredder
Fellowes 2127c blades not turning
The shredder doesn't work it just makes a noise and cuts out
  • 579 Answers
SOURCE: Fellowes Shredmate Cross Cut Shredder
Learn something new every day!
Posted on Dec 31, 2007
FixinFax
  • 3085 Answers
SOURCE: Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Posted on Jul 05, 2009
SOURCE: od700c shredder: motor spinds, blades don't move
Inside the motor assembly there are a series of nylon cogs , a large one of which interacts with a metal one.  This is the most likely place you have one or two teeth missing from the large nylon cog that drives the shredder blades.
Posted on Oct 05, 2009
  • 610 Answers
SOURCE: Shredder starts to shred, then makes a loud noise,
sounds like a couple of teeth on a drive gear may be broken. call Fellows at1-800-955-0959.
Posted on Dec 01, 2009
SOURCE: OD700C Fellowes Shredder blades don't turn
There is a screw hidden under one of the stick on labels. Remove that and the top comes just fine. I got it torn apart, completely cleaned of debris but the rollers still don't turn. I noticed an electrical arc when the switch is pressed so the unit is toast.
Posted on Mar 05, 2010
Testimonial: "Thanks. I found the hidden screw and was able to get inside. I know what's wrong with it now and hope to get it fixed. "
Fellowes c-480c squealing noise
Shredders get incredibly dirty with paper dust. There is also a lubricant that you are supposed to put on the blades. There is a basic guide here:
Mar 13, 2015 | Fellowes Manufacturing Powershred C-480C...
How do I stop shredder from spitting documents in and out?
Try cleaning the cutters well. This will require you UNPLUGGING the shredder. Turning it (the top feeding-cutting) part upside down and removing ALL paper and if you see paper clips or staples-REMOVE THEM! You will need to start the motor several times to move the cutting blades around for a complete cycle to make sure you have removed all debris from the cutting blades.
If this does not work you may have an electrical problem you will not be able to solve. Look for your shredder number in the link provided below and download.
Fellowes Shredder Manuals
Sep 12, 2014 | Fellowes Powershred SB-87Cs Shredder
Our C220c shredder does not shred, motor turns and blades turn but i think the blades are blunt. Can you get new ones or have the old blades sharpened?
There are 2 shafts that have the cutting blades on them and they both should turn. I have replaced many gears on this model and suspect that a gear is broken. Fellowes does not have many parts this model anymore. I would call a local shredder repair service or you can call Fellowes at 800-955-0959.
Sep 11, 2013 | Fellowes 220C-2 Shredder
Why is the fellowes blade still rotating even when there is no paper?
It is possible that a small shred of paper is lodged at the sensor underneath the cutting blade.
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers or use canned air and blow the edges of the blades.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse.
    • 3 Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Fellowes Intellishred PS-79Ci Shredder
Knocking noise when shredding paper
Cross-cut shredders require monthly oiling of the cutting cylinders to maintain proper operation. Failure to oil the blades regularly could result in excessive noise during operation.
Oiling Your Shredder's Cutting Blades:
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three times.
I hope the above helps....
Good luck.
Apr 13, 2011 | Fellowes DM8C Cross-Cut Shredder
Makes noise blades don't move
you have some teeth missing off of one of the gears, most likely the dual gear thats driven by the motor.
razors
Apr 23, 2010 | Fellowes 220C-2 Shredder
Shredder starts to shred, then makes a loud noise, and blades don't turn
Dec 01, 2009 | Fellowes DM15C Shredder
Fellowes MS-450Cs crosscut shredder quit
No, your shredder blades are dull. No replacement parts are available. Sorry
Nov 27, 2009 | Fellowes Manufacturing Powershred ...
Jul 05, 2009 | Fellowes 3011001 Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Fellowes 2127c Paper Shredder Logo
35 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
